Wheatley's 6262 build
Old Apr 12, 2013 | 10:42 PM
  #616
Wheatley's Avatar
Thanks, I have room when the wifes car is outside. Ive been having to pack it all back up so she can park inside since its hail season up here. I finally got everything done for the time being on the inside of the car so I could put it up on the lift to work on it and keep it out of the way. I really need another 6 ft in depth but it was to large for my zone. With the drum fan and a spare furnace I cant park two cars deep and the other door isn't accessible due to my trailer. Maybe one day I'll get everything situated but I think we are just going to move instead so we can have some land and I can have a garage to myself.
Old Apr 13, 2013 | 05:48 AM
  #617
FathouseFab's Avatar
This thing is gonna look great with everything back in! Looking forward to seeing it go down the track!
Thanks Matt!
Fathouse
Old Apr 14, 2013 | 05:49 PM
  #618
ExtremeDSM's Avatar
Pretty hardcore!!!
Old Apr 14, 2013 | 08:28 PM
  #619
Wheatley's Avatar
Finished up the exhaust and battery box with the help of my buddy Newbspeed.
I'll start with the battery box since its the least involved and pretty basic. I wanted to get it knocked out friday but was watching my son, so during his naps I was able to get something that sort of resembles something that might hold a battery, at best. I switched to a small lithium this year but wanted the battery box to also fit a pc680 in case I ever needed a battery in a pinch. It'll be mounted on the frame rail up front out and away from the passenger compartment.
Tape should hold it right?
We had been planning to do a 4" aluminum exhaust for the evo for some time now but just hadn't gotten around to it. We knew going into it that the situation was going to be challenging to say the least. We started late evening on Saturday and worked pretty late into the night and part of Sunday finishing it and the battery box. The situation was that I had the room and the lift with no tig and he had a tig and no room. Being that his tig is as tall as I am and two of me wide it wasn't going to be moved. Shes a big welder to say the least. My setup is in no way fab oriented but I can usually get by in a pinch, he brought a hand held band saw that we chucked into the vise that worked really well with a two man team operating it. If you follow me on Instagram then you got to see some of what I'm talking about.
Love this place!
In this shot you can see how we cut the entire exhaust at my place and after tacking the vband and the cone were able to make some steel and clamp jigs to hold it all in place to transport from my shop to his. This worked out extremely well. It was time consuming but made for all the pieces fitting together very nicely and great fitment in the end.
I cut the 2 bolt flange off my 3" SS down pipe and replaced it with a 3" male/female vband to 4" aluminum cone we cut down for the transition. This was the most time consuming part trying to get the overall angle correct and getting the pipes to properly meet at the cone. We ended up inserting the 4" end into the cone and I used a quick shot of primer to coat the area to be removed and then cut it from the inside with a cutoff wheel. It also clears the floor, and drive shaft loop on all sides.
Routing
Ground clearance for days even with the 4", tucked it very tight.
Old Apr 14, 2013 | 09:07 PM
  #620
LGshow19's Avatar
That thing is nasty! Love that last pic you took, showing off the angle of the exhaust... keep it up man.
Old Apr 14, 2013 | 09:30 PM
  #621
Wheatley's Avatar
Thanks!
Old Apr 15, 2013 | 05:15 AM
  #622
batty200's Avatar
So how does it sound?
Old Apr 15, 2013 | 05:22 AM
  #623
AngryEvo8's Avatar
That is a awesome workshop! I need replace my crappy ams battery they just don't last over a year even if you have them on a trickle charge inside.. might be looking into a lithium one here soon.
Also I like how the exhaust came out! Mighty meaty
Old Apr 15, 2013 | 06:12 AM
  #624
badev0's Avatar
Very nice progress Matt. Looks like you've been eating your Wheaties
Old Apr 15, 2013 | 06:27 AM
  #625
Wheatley's Avatar
I've had the same pc680 since 2009. I don't trickle but I do remove them from the car when stored. They really aren't that good for these cars and I don't have high hopes for the lithium.
Batty- I don't know I'm waiting on some fuel stuff to fire the car.
Old Apr 15, 2013 | 06:28 AM
  #626
Wheatley's Avatar
Thanks scott, time is running out!
Old Apr 15, 2013 | 07:20 AM
  #627
Evosick2332's Avatar
That exhaust looks straight up rowdy man lol. Cant wait to hear a sound clip of it
Old Apr 15, 2013 | 07:34 AM
  #628
Wheatley's Avatar
Thanks, are you racing in may in Ohio?
Old Apr 21, 2013 | 09:27 PM
  #629
Wheatley's Avatar
Finally put the glass back in tonight, so happy to not have it sitting around the shop paranoid I'm going to break it. The rear view ended up just barley fitting! Very excited how everything is turning out!
Old Apr 22, 2013 | 05:54 AM
  #630
06MREvo's Avatar
Cage is tight! Exhaust looks good, everyone is switching to aluminum now! Looking forward to a sound clip of your car. I ended up getting the same battery too, I blame it on EvoDan, haha...
