LR 2.4 and MAP EF4 build thread
Old Dec 2, 2011 | 01:04 PM
  #136
Svendiesel's Avatar
I asked Aaron for a choppier idle, thats how
Im pretty sure its just MIVEC advance at idle really and controlling the AFR
Is your idle high?? Mines at like 1050ish RPM or so
Old Dec 9, 2011 | 01:45 AM
  #137
ezz-e's Avatar
Originally Posted by JohnBradley
Idles like stock with S3s on a 2.0L?
aaron
Yes im on a 2.4L and the dam thing only idle ruff the first 20 min after the cam install, after that it always starts up and idles like a car that has a very soft cam, no ruff idle to it just kinda normal
Old Dec 19, 2011 | 07:54 PM
  #138
Wheatley's Avatar
Nice build and good looking car!
Old Dec 23, 2011 | 10:43 AM
  #139
Svendiesel's Avatar
So last night I was highly motivated and put my turbo setup back together. Went to drop everything into the car, of course everything was in the way of everything else and a simple task of dropping the setup into the car took way longer than it should have.
I began tightening the manifold to the head and I ended up dropping my wrench, it bounced like 3 times and of course ended up falling into my downpipe. And, of course, it isnt reachable by a magnet. So I gave up for the night Probably gonna take my downpipe off tonight, get my wrench back, and finish it up. Maybe. Hopefully. Probably not tonight.
Old Dec 23, 2011 | 10:49 AM
  #140
AWD96's Avatar
^I have dropped a keeper in the head before and had to break it all down again to get it, so the wrench in the downpipe sounds Heavenly to me haha.
Old Dec 23, 2011 | 11:48 AM
  #141
Svendiesel's Avatar
Oh man that REALLY sucks, I'd be very unhappy if that happened haha.
Of course I had every other possible hole taped up or covered so I didnt lose anything, except the downpipe.
Old Dec 23, 2011 | 04:01 PM
  #142
Wheatley's Avatar
Ive lost keepers down to oil pans, nuts in down pipes, things in combustion chambers etc etc. I now cover everything as it seems I have slippery hands!
Old Jan 11, 2012 | 12:57 AM
  #143
Svendiesel's Avatar
Time for an update.
Car has been back together now for about a week or so. The turbo has been refreshed and is in great working order, and thanks to Bob from MAP for tweeking it a bit to spool up faster
Email tuning is currently underway, I sent Aaron logs last night and I got a new tune earlier today that I also just got back from logging, and I have sent him those logs.
My friend installed my new boost gauge tonight, an Autometer Phantom -30/0/45, and Im disappointed at how dim the LED bulb is that I bought for it. Its nearly impossible to see. I need to find a brighter amber bulb for it. I had a peak/warn Prosport -30/0/30 which I loved, but I needed a higher reading gauge. I asked them a few times if they could make me a gauge with vacuum that read up to 45psi and they said they couldnt
Anyone who comes in the car with me still cant get over how smooth and responsive the car drives. The best part is how violent the car is once it hits full boost. It's a lot of fun and 2nd gear is a bit of a handful, and a 3rd gear is getting to be a bit interesting. I like to stick by the motto that spinnin aint winning, but its fun to break the tires loose in an AWD car once in a while
Old Jan 11, 2012 | 09:44 AM
  #144
mrfred's Avatar
Boost gauges are overratted tools. No time to look at the gauge when a car is making big power. Better to rely on failsafes such as boost cut load. A really nice failsafe that Aaron told me about when I was at English Racing a few days ago is to tie the BOV/DV boost hose into the fpr boost hose, so if the fpr boost hose pops off the fpr, then it instantly opens the DV and kills boost. Very nice failsafe.
I'm easily spinning all four in 2nd gear with a measily 425 ft-lbs. I imagine that you'll be able to spin all four in 3rd by the time Aaron is done with your Evo.
Old Jan 11, 2012 | 11:53 PM
  #145
Drill_Sergeant's Avatar
Veteran: Army
Did you track down your oil leak?
If not and you think it's coming from under the lower timing cover...
I had the same problem, slight leak causes it to drip onto the oil filter housing. I noticed this when I was redoing my timing belt. Turned out to be leaking from where the BS belt tensioner was bolted in. I have the OEM delete gear. I grabbed one of the hybrid rubber/brass washers from master gasket kit, fitted it to the bolt, and put the bolt back in its place. No more leak.
Congrats on a great build.
Old Jan 12, 2012 | 12:30 AM
  #146
Svendiesel's Avatar
Some interesting numbers I found while looking at one of my logs. I started my 3rd gear WOT pull at 2583 rpm and stopped the pull at just about 8000rpm, this took exactly 5 seconds to run through. My 70-90mph time took a half second (0.5).
A DSM buddy of mine told me they use a formula to find their trap speed, which is 152 - (T * 16.735) = Trap speed where T = 70-90mph time. The number I got from that was 143mph. Granted, for our cars that formula is going to be off a few mph for sure due to the DSM guys gearing being different. I presume with the power the car was making on that pull my potential trap would be around 135ish.
Thats true about the boost gauge for sure, the only reason I really installed it is to glance at it while going thru the tuning process to be sure that boost isnt making huge jumps as I turn the MBC up.
Interesting idea too with the failsafe on the FPR vac line. I loaded in my new tune today, and I only floored it in 3rd for about 2 seconds and the car REALLY felt amazing. 35psi appeared in no time and the torque kick was nuts.
Thanks man. I havent actually pinpointed the leak yet. Its definitely coming out of the lower timing cover, theres oil EVERYWHERE from my oil filter housing, to a few bolts on my oil pan, axle boot (from slinging I assume) my subframe, and onto my exhaust as well. its a pretty big mess on the entire passenger side underneath the car. Hopefully my issue isnt serious and can be easily fixed like yours. I do lose quite a bit more oil than Id like to and have to keep topping it off.
Old Jan 12, 2012 | 03:58 AM
  #147
Veteran: Army
I guess it's time to take that cover off
Old Jan 12, 2012 | 06:31 PM
  #148
Acree's Avatar
Good luck with the traction issue. You eventually just learn to live knowing that spinning all 4 at 60 mph is normal.
-Acree
Old Jan 12, 2012 | 08:56 PM
  #149
Svendiesel's Avatar
Haha absolutely. I raced a 418ci/h/c Camaro Z28 last year and I was the one who spun during one of the pulls and that was with a terrible tune.
Old Jan 14, 2012 | 10:46 AM
  #150
skochur's Avatar
Vbox time!!!!
