Extreme Tuners U.S. Evo Build
Old Jun 21, 2012 | 10:01 PM
  #721
project_skyline's Avatar
Their website is wack as hell!!!
No information of any kind just a bunch of pictures of F1 cars. EPIC FAIL!
Old Jun 22, 2012 | 04:30 AM
  #722
GraphiteEvo9's Avatar
Originally Posted by bostonhatcher
How is a wastegate gonna fit on the shorter wastegate runner?
https://www.evolutionm.net/forums/10219004-post569.html
Old Jun 22, 2012 | 06:22 AM
  #723
CurseDSM's Avatar
Originally Posted by TommiM
If it works, it works. I dont want to hate on it because Im sure OP payed good bucks for this piece.....BUT, looking at ET boasting about exotic materials he uses, I was honestly expecting something like the cbrd F1 out of titanium or some other exotic material.
Oh I agree with you. If it works it works but still they should have done a better job on that mani. And it still doesn't explain why the transitions and welds werent cleand up though. I mean you could have at least coated it to hide how terrible the mani's appearence is and that way it would hide half the clean up on the welds.
Old Jun 22, 2012 | 06:30 AM
  #724
David Buschur's Avatar
Originally Posted by GraphiteEvo9
It's all good guys, I like discussing various topics!
Exhaust Mani is here!
I'm just going to say that I would find it extremely hard to believe that you can even REMOTELY pleased with that after the long wait. It's not nearly as nice as the vendors stateside make, Shearer, Full Race, Toxic Fab, it's not even as nice as one I personally build and I weld about once a year when I get a bug up my *** to build a header. There are people, regular DIY guys on the forums that do better work. It's not terrible mind you but certainly not the quality he makes it out to produce. Just a note, I called him out long ago on putting pictures of other people's work up on the forums and claiming it was his, this is just the nail in the coffin in that topic.
I hope you didn't pay more than $1400 for that header, 02 housing and both dump tubes for the wastegate, if you did, hire a lawyer.
Old Jun 22, 2012 | 07:48 AM
  #725
MOREPSiTEHBETT4's Avatar
if u look carefully, it does look pretty bad, sorry to say.. diff size id sections connected due to heat not being controlled in welding.
Old Jun 22, 2012 | 08:04 AM
  #726
CurseDSM's Avatar
Yeah I saw that too. I mean I do not want to bash the op, or the vender, but as I said if that were mine and I dished out the funds for that I would be very very unhappy with that.
Old Jun 22, 2012 | 06:33 PM
  #727
kouzman's Avatar
to the OP:
Since DB mentioned it, did you get the o2 housing, downpipe and dump tubes?
Old Jun 22, 2012 | 07:17 PM
  #728
khmerpimpin's Avatar
Can you guys educate those who don't know what to look for when judging welds and build quality of welded parts? Any pointers are welcomed, heck even take that pic and make some marks.
Old Jun 22, 2012 | 08:15 PM
  #729
240Z TwinTurbo's Avatar
From an integrity standpoint the welds are likely fine. As long as the manifold was purged or Solar Flux B was used there should not be an issue. The pipe edges are bevelled so it is practically impossible not to get full penetration.
It definitely doesn't look like ToxicFab made it, but that is an aesthetics issue. Good luck with the build. If ET sells you an expensive fuel pump with the pressure bypass punched then you should start to worry.
Old Jun 22, 2012 | 08:18 PM
  #730
R/TErnie's Avatar
Prep work prior to welding.
Like cleaning the sharpie marks off the tubes before welding them.
Polishing the bends before welding.
Making a nice bevel prior to welding.
The tack marks are larger than the welds and stand out.
The majority of the welds were not completely shielded by argon.
The beads are not evenly spaced, the same width, and not all are slightly convex. (proper amount of filler)
Furthermore you can see where the heat is inconsistent in the weld by the HAZ.
You can see where they welded the inside and outside of the wastegate flanges as well as on the head flange. This causes porosity in the weld (trapped air) when the manifold gets hot it will expand and cause a crack.
The wastegate tubes where they join the collector were welded too hot and looks like they welded these inside and out again... porosity city. It will fail here most likely.
They welded on some bracing on the wastegate tube to support the gate, I don't think this is necessary and that weld will crack for other reasons that the amount of weight they have hung off it.
They designed a manifold around TiAL V44 gates and not MVRs? What is this 2010?
The turbine inlet flange is not surfaced.
The head flange is not fully surfaced.
The collector is not ported/fabricated very well.
(congrats you actually ported the runners!)
The manifold is not flow balanced (same degrees of bends per runner) and probably isn't equal length judging by runners 1 & 4.
You can see where the wastegate flange arc'd to the table and left a weld POCK mark. Picture #2
Carbide slipped on Picture #3 and weld across the flange while they were deburring their flame cut head flange.
And there is a runner that is retarded close to the valve cover.... I hope they sent a heat shield or some crazy high temp gasket!
That's what I see wrong with the manifold.
Old Jun 22, 2012 | 08:45 PM
  #731
rascal's Avatar
extreme-tuners.com
The IP address for this site, or lack of seems to be in Germany.
A little odd??
Old Jun 22, 2012 | 08:48 PM
  #732
tscompusa's Avatar
damn i feel bad for the guy now.. i know on my toxic fab i cant even see where its welded really after it was ceramic coated.
and anyone that needs to see the work R/TErnie does, just look at his build thread.. his welds are as good as toxic fabs.
Old Jun 22, 2012 | 08:53 PM
  #733
EvoJoeIX's Avatar
damn. i just looked at it and thought to myself, that thing looks ugly.lol
i never imagined so much could be wrong
Old Jun 23, 2012 | 04:20 AM
  #734
user 72082032's Avatar
Ok, but apart from a couple of minor issues you pointed out it all looks good yes
Old Jun 23, 2012 | 05:31 AM
  #735
redleg225's Avatar
