Stephens 2.4L evo 9 build
Old Apr 7, 2012 | 09:25 AM
  #46
tscompusa's Avatar
and heres the remainder of random pics i wanna share from the build.
Old Apr 7, 2012 | 09:28 AM
  #47
4g63evoeight's Avatar
good **** Tom! what did you gap the rings to?
Old Apr 7, 2012 | 09:37 AM
  #48
tscompusa's Avatar
20/24 top/bottom read the first post its in there.
Old Apr 7, 2012 | 10:11 AM
  #49
Blue91lx's Avatar
You sure the motor won't need more ventilation than that little breather filter?
Otherwise, looks good!
Old Apr 8, 2012 | 08:13 PM
  #50
tscompusa's Avatar
my evo has a 5/8 (-10 AN) connector.. if i feel we need to open the ventilation more on his valve cover ill help him do it.
that breather was there from before.. i just put it back on. that's his own stuff from before.
Old Apr 10, 2012 | 05:54 AM
  #51
VIIIdriver's Avatar
Hey guys! could you share info on what water pump you guys used for this build? i hear the regular 4G64 is too tall and i don't want to use a spacer for my 2.4,any help would be greatly appreciated.
Old Apr 10, 2012 | 07:11 AM
  #52
tscompusa's Avatar
we used the stock waterpump for the car and the Maperformance waterpump spacer.. it worked great. you put the 4g63 gasket to the side of the gasket that touches the waterpump and the 4g64 gasket to the block side.
we also used stock cam gears and stock timing belt. if you want i can post pic of the timing marks also..
but the notch on the cams goes 1 tooth after the original timing marks on the valve cover.
Old Apr 10, 2012 | 02:13 PM
  #53
CurseDSM's Avatar
If you don't wanna use a spacer then your only option is to pay English Racing 250 bucks for theirs.
Old Apr 10, 2012 | 02:57 PM
  #54
tscompusa's Avatar
having direct experience with a good well machined spacer like MAPS i can say that modifying the waterpump is a waste of $.
the spacer is no where near the waterpump blades.. and there's no way the spacer is going to flex and hit the inner part of the blade..
so until i see that happen on this car, then i will not recommend avoiding spacers.
Old Apr 10, 2012 | 03:04 PM
  #55
Blue91lx's Avatar
...The issue lies in the fact that the pump is spaced out too far, thus shredding serpentine belts.
Old Apr 10, 2012 | 03:51 PM
  #56
CurseDSM's Avatar
Uhh Tom? you quoted the wrong person hahaha.
Old Apr 10, 2012 | 03:54 PM
  #57
CurseDSM's Avatar
Not really, I shreaded my serpentine belt with a stock water pump. Has alot to do with how tight the damn thing is on the car. In my case I didn't do it origionally, but whoever did made it so the aftermarket pully get warped and ended up snapping it.
Old Apr 10, 2012 | 03:59 PM
  #58
tscompusa's Avatar
show me a link on the forum to a shredded serp belt from a spacer.
the only pic I've ever seen pertaining to the spacer being bad was the grind marks on the spacer cover before.
i highly doubt 1mm if that, is going to effect the belt.. i know 700whp+ cars running spacers with no issues.
that said.. now that you said that ill thoroughly inspect his belt to see if i see anything.
Old Apr 10, 2012 | 04:05 PM
  #59
tsidrift1's Avatar
Looking good Tom! Where is my Tscomptuned Decals??? haha
My built block is surprisingly quieter at idle compared to my old stock block too.
Old Apr 10, 2012 | 04:07 PM
  #60
Blue91lx's Avatar
I'm using the same adapter as you are. I'm just speaking in terms of the overall longevity of the belt. Have I seen one shredded on an Evo? No. Have I had cars in which my accessory pullies were out of line a few mm (adapter and extra gasket) shred serpentine belts because of it? Yes.
Not hatin as I run the same thing. Just curious to get your thoughts on the matter.
