Stephens 2.4L evo 9 build
Old Jun 12, 2012 | 11:41 AM
  #76
NewEvolutionIX's Avatar
Yeah I miss read the paper. That 6th ring that came with te prisons was a spacer for the oil rings that went on the bottom of the oil Expanders. And I know about the gaps I have everything perfect now! Thanks for the help
Old Jun 20, 2012 | 12:55 PM
  #77
J_Striker's Avatar
I'd like to see some other pictures of it all timed up if you have any more.
Thanks
Old Jun 24, 2012 | 02:35 AM
  #78
tscompusa's Avatar
I have pictures ill find them and post them up for you but off memory you make each gear a half tooth advance with the regular evo 9 4g63 belt & gears.
Old Sep 3, 2012 | 12:24 PM
  #79
tscompusa's Avatar
I would say this build turned out very successful.
1. the car burns all but no oil.
2. the car has no blowby.. he never had his dipstick budge yet. still on stock ventilation setup.
3. the car got 300 miles to a tank going from pa to ohio.
4. the car trapped 127 on mild power on stock cams, stock intake/tb, and fp black.
The car now has i believe 8000 miles or more on it.
below is some info on what the car done so far:
MPG on e85 tune: (interstate driving)
and heres a race between my 2 customers Will & Steve. Steve bogged launch, Will out drove steve entire time, but Steves car is on e85 Will's on 93.. plus wills not 100% dialed in.. so not fair lol. (both cars on stock ecu and speed density)
and heres the video Steve made himself:
heres the timeslips (the one on the right he missed 5th gear):
So for the very first engine i ever put together from bare block on up, id say i did pretty good.. this thing is a very strong engine. so feel free to use the clearances i used when assembling this engine because they work.. just dont try to break the engine in fast.. do it slow since the tolerances are alittle tighter.
Old Sep 3, 2012 | 01:01 PM
  #80
Jos_iQRacingEVO's Avatar
Lightbulb
Originally Posted by tscompusa
looks good right? well its not! the rod cap hits the block..
we had to tear down the entire engine and now we have to shave the block
for clearancing..
Oh now I see and now I understand, how and from where do you was so sure about your answer to the question I made to you, when my crankshaft wasn't turning 360degrees; and you told me that you was sure that: ''it was the rod or something hitting the gridle...''
Now I see that you also experimented that nightmare!!! Jejejejeje!!!
Old Sep 18, 2012 | 07:07 PM
  #81
tscompusa's Avatar
more track results for this car.. we are installing GSC S3 tomorrow in it and will be back to trap even higher and most likely dip into the 10's.
Heres some footage of his runs:
Heres all of his runs combined:
His cars very strong for being stock cams, stock intake mani, stock ported exhaust mani, etc..
engine has what maybe 12k on it now? this cars daily driven.. and runs like a top.. i am very happy with the results of this car considering
its the first shortblock ive ever assembled.
Old Sep 18, 2012 | 07:15 PM
  #82
Don475's Avatar
It's about time someone made a tutorial on this.
Old Sep 18, 2012 | 07:42 PM
  #83
jmcmill3's Avatar
damn, im jelly of his traps
Old Sep 18, 2012 | 07:44 PM
  #84
tscompusa's Avatar
if you dont trap more then his car with your setup im gonna kick you in the nuts.
Old Sep 18, 2012 | 09:23 PM
  #85
morellana's Avatar
Good luck
Good luck man looks really nice looks like everything should go well
Old Sep 19, 2012 | 03:39 AM
  #86
jmcmill3's Avatar
Lol thanks for the motivation
Old Sep 26, 2012 | 11:01 AM
  #87
tscompusa's Avatar
went 11.2 @ 112 lifting in 80F.. easy 10 second car here. hitting up Cecil soon again with both cars. the car trapped over 104mph in the 1/8 so its moving out.
Old Dec 14, 2012 | 01:26 AM
  #88
tscompusa's Avatar
just updating this build thread.. this cars doing really good things so far.
here's the most recent power graph it produced along with the track times to back it up:
Old Dec 14, 2012 | 09:14 AM
  #89
jmcmill3's Avatar
damn
Old Dec 14, 2012 | 04:07 PM
  #90
XxLANCERxX's Avatar
sick car what's the horsepower on that evo
Posted from Evolutionm.net App for Android
