EVOLUTION VIII - 2.3 Stroker Project
Old Feb 24, 2016 | 08:35 AM
  #61
Howulikemyevo's Avatar
Did you get on the Dyno yet?
Old Feb 25, 2016 | 07:31 AM
  #62
Uhuru's Avatar
His not finished buying parts yet, so he is far away from assembling the engine
Old Feb 26, 2016 | 04:52 PM
  #63
Cool
Oh ok. Can't wait to see what that car make!!!!
Old Feb 27, 2016 | 11:13 AM
  #64
Uhuru's Avatar
Me too
Old Mar 25, 2016 | 08:35 AM
  #65
Kevin Troy's Avatar
Final order for shipment is going in beginning of next week. There are about 150 peaces (bolts, nuts, covers, plates, injectors, turbo oil lines, turbo water lines, brackets, arp flywheel bolts, aux tensioner, balancer, oil filterhousing, timing cover, fluidamper, crank angle sensor, front mount, kiggly HLA, magnus fuelrail, pulleys, waterpipe, washers, gaskets, arp harmonic crank pulley... and about 100 more parts) Can't wait no more to getthis****done
After that it will all be put in one peace, torqued down to spec, tripple checked everything and it will be ready for swap.
stay tuned
Old Apr 16, 2016 | 11:37 AM
  #66
Kevin Troy's Avatar
Today I had a really nice ride on Croatian coast.
Here are 2 songs you should not listen to while driving an Evo:
image upload no compression
Old Apr 18, 2016 | 09:37 AM
  #67
GollieBuilt's Avatar
That car is clean. Thats a nice build and the exhaust system look sick!
Old Apr 28, 2016 | 07:15 AM
  #68
Kevin Troy's Avatar
So, here are the last few parts I have ordered from Ross Sport.
I'm just missing the middle section of the timing belt cover which is on the way thanks to urgent intervention of Ross.
Hopefully I can now finish my build and torque down the engine components and put it to work.
Once again thanks to Walker from Ross Sport for organizing the big order and being patient with me :-)
Old Apr 29, 2016 | 04:19 AM
  #69
NJ9MR's Avatar
FCOTM Winner
Congrats! Some choice-looking parts there! Good luck with the build!
Old Apr 29, 2016 | 04:02 PM
  #70
Rectzero's Avatar
Wow this build sure isn't missing any details on parts
Old May 2, 2016 | 07:59 AM
  #71
project_skyline's Avatar
Super sweet build with lots of good detailed pictures. But.... that brass fitting on the valve cover is taking it from a 10 to a 6 lol. You should get a aluminum fitting and run some braided hose.
Old May 4, 2016 | 10:09 AM
  #72
Kevin Troy's Avatar
Yes, I agree, the brass fitting (color) some how dose not fit
Got the last 2 missing parts, Belt tensioner and the middle cover.
Also in the meantime managed to galvanize the water inlet pipe and powdercoat the 2 brackets.
I think I got now all the parts
Water inlet pipe:
Old May 7, 2016 | 11:36 PM
  #73
Kevin Troy's Avatar
So, yesterday we had torque party in the shop.
We managed to finally put the engine together in one peace and torque everything to it's spec.
All parts are brand new, bolts, washers every single thing.
Also we put spacers for the magnus fuel rail which I did not have but my mechanic did
Turned the engine few times over, belt is tight and everything is in clearance.
stay tuned...
Old May 14, 2016 | 02:22 PM
  #74
Kevin Troy's Avatar
So, here is the billy bad arss which should power up the evo.
I hope soon it will be fitted
upload pic
Old May 14, 2016 | 06:18 PM
  #75
JRally's Avatar
Be careful with that Manley crank. They're a bit weak. I cracked one at about 9000 miles making 430whp.
But my setup is about the same as yours. 2.3 with an fp black.
