EVOLUTION VIII - 2.3 Stroker Project
Old Sep 26, 2016 | 03:30 AM
  #106
Kevin Troy's Avatar
This is how it looks now. Is just about to be mapped.
Hope to see some good results :-)
imageupload
Old Sep 26, 2016 | 05:11 AM
  #107
NJ9MR's Avatar
FCOTM Winner
Great work congrats!
Old Sep 28, 2016 | 08:42 AM
  #108
thepoint4life23's Avatar
What wheel is this and how do i get one?Name:  DSC06295%20Rezolucija%20ekrana_zpsysjwumjw.jpg
Old Sep 28, 2016 | 10:19 AM
  #109
Kevin Troy's Avatar
It's my from my college, OEM wheel, he obviously has flattened it a bit IIRC and did refurbished it with new leather & stiching. He did it here locally.
Old Oct 1, 2016 | 01:44 PM
  #110
Kevin Troy's Avatar
Ok, so, the last 24 hours or so have been really exciting for me.
Finally managed to prep the car to the stage for putting on the dyno for mapping, further bedding in and testing it to the max for current setup.
After 4 years in the making, after endless researches, endless consultations with colleagues & friends and my two independent mechanic and of course years of wife's support...
here are some first frugally results;
Propelled on 100oct pump gas we managed to max-out the Aeromotive Stealth 340 fuel pump (with hardwired kit) with cca. 68PSI at boost and the injectors at 76%.
The FP Black pulled at 3000 rpm 1 Bar (14,5PSI) and at 3500 rpm 1,5 bar (21,7PSI) and held on til 7500 1,6 bar ( 23,2 PSI).
It showed 506 HP (451 WHP) and 533 Nm of torque (393 ft/lb)
I'm happy how the car behaves, it's a real difference from before.
As next possibility I see walbro 450 fuel pump and further optimization of the setup.
Old Oct 1, 2016 | 04:22 PM
  #111
Erik@MIL.SPEC's Avatar
Nice.
I can't believe you put all that heat shielding on but didn't coat the exhaust manifold lol
Old Oct 2, 2016 | 12:39 AM
  #112
Kevin Troy's Avatar
I don't feel like spending 400€ on proper ceramic coating.
Old Oct 3, 2016 | 09:38 AM
  #113
Twylyt's Avatar
This is an amazing build! Great thread to read and be inspired by. My two year build doesn't seem so bad now. lol. Anything you regret or would do differently?
Old Oct 5, 2016 | 11:41 AM
  #114
Kevin Troy's Avatar
Thank you for the support and kind words of encouragement.
Glad to see someone to be inspired!
So far I have no regrets.
Would do all the same things again but in next life
Maybe some minor things would do different... but nothing special.
always the question of budget
Old Oct 7, 2016 | 09:38 AM
  #115
Kevin Troy's Avatar
I was very curious hot it would do the compression test so today I checked that to.
Also was happy to see that the FP turbo was NOT leaking any oil.
Because some users had issues with that and the most cause was excessive crankcase pressure witch had to be addressed/solved.
Here are the results after mapping, 5 oil changes and covered 1100km;
All 4 cylinders have same compression at 10 Bar (150PSI).
Also some pic of the plugs which are almost the same looking.
Once again thanks to Norris designs for constructing this awesome engine for me, my 2 local mechanics who put all this together and thanks to my wizard mapper
Old Oct 21, 2016 | 08:57 PM
  #116
astral's Avatar
Went through this whole thread. Absolutely brilliant!
Old Oct 27, 2016 | 08:20 AM
  #117
Kevin Troy's Avatar
Thanks
Old Nov 3, 2016 | 08:52 AM
  #118
mrhussain's Avatar
such a clean build man, awesome quality parts and very well documented. I want your car maaan
Old Nov 3, 2016 | 09:26 AM
  #119
Kevin Troy's Avatar
hehehe thanks a lot man
It is very important in my opinion to document every single step and carefully choose parts for the build. Also keeping in mind for what purpose it is being build.
Stay tuned, updates are on the way (again )
Old Nov 4, 2016 | 08:39 AM
  #120
Kevin Troy's Avatar
No more PCV restrictions.
Managed to custom made this peace of fitting.
image ru
photo uploading
image hosting 5mb
image uploader
