CT9A Resurrection and Innovation
Old Apr 12, 2016 | 01:45 PM
  #271
Sleepless's Avatar
Originally Posted by PAdutch
Bad news. If you want a bad rear diff to go along with that i have one too.
You got mail!
Old May 10, 2016 | 06:09 AM
  #272
electron bom's Avatar
Front Mount Controller Cooler
Its not as beasty as a FMIC, but I had to position it up front to keep the evo look. This is a radiator for a Yamaha UTV made by Mishimoto.
Old May 10, 2016 | 07:04 AM
  #273
mrfred's Avatar
How cute. People who know what an Evo is will be baffled by yours.
Old May 10, 2016 | 12:20 PM
  #274
ogrenator's Avatar
amazing! cant wait to see her tear it up!
Old May 10, 2016 | 01:06 PM
  #275
bakuro117's Avatar
So strange to see the firewall thru the grill and know that there is a motor in there. LOL
Old May 16, 2016 | 09:35 AM
  #276
CLEAN
air is important to me. Given that this was a smoker's vehicle once, I decided to remove the HVAC motor unit and air handler apparatus for inspection and a thorough cleaning. Removing the plastic mass resulted in 16 lbs of weight savings, although I intend to reinstall it later this year.
Old May 16, 2016 | 09:56 AM
  #277
First Drive Test Approaching
Here is the to-do list before a drive-way test is possible. The driveway test will be a simple ordeal, but hugely significant. It will confirm the functionality (albeit at low speed) of several used parts: gear box, motor controller, rear diff, hall effect pedal assembly, etc.
Beginning fabrication of a very simple, yet sturdy mount. I will replace the hose barbs with -6 AN fittings for the coolant plate. It is entirely unnecessary, but I think AN coolant lines will look cleaner.
Old May 19, 2016 | 08:01 AM
  #278
Metal shavings everywhere
Bracket construction in full swing.
Cutting angle iron for FMCC bracket.
A sundry lot of AN fittings for the cooling system. I removed the Mishimoto 'M' from the radiator core, looks better IMO.
Weld in AN fitting for feed and return lines.
Old May 19, 2016 | 08:13 AM
  #279
Controller Mount
Simultaneous construction of controller mount with the intent of minimizing clean up time.
A hodgepodge of aluminum and iron brackets held together by M6 bolts with locking nuts and generous applications of JB weld. The bracket is about 1/2 done and will have 4 points of contact and a total of 7 bolts anchoring it to the engine bay. I'm thinking it might deserve a nice wrinkle black finish once complete.
This design should give me a short route from the controller to the motor terminals, thus reducing length and consequently the resistance of the motor cables.
Old May 19, 2016 | 08:33 AM
  #280
bakuro117's Avatar
That controller looked a lot smaller in other pics... I imagined it being little. Now seeing it in the bay really messed with my eyes. LMAO
Old May 19, 2016 | 09:00 AM
  #281
It's LxWxH in inches is 9x7x4.5 and its the smaller of the two controllers made by Manzanita. It's big brother will handle 2000 amps and is only about 6" longer. I find it amazing that this little green box weighing 15lbs will handle 470hp.
Old May 19, 2016 | 10:10 AM
  #282
Epyon's Avatar
Weren't you planning on putting a second motor in the engine bay still? To me it looks like the controller would get in the way of mounting another motor on top of the first one. Have you done dimensional checks on that yet?
Old May 19, 2016 | 01:21 PM
  #283
Yes, a second motor is in the future. Maybe its the angle of the pics, but the controller mount is positioned in front of the gearbox and will not interfere with a second motor. When the second motor goes in, it will sit about 2"-3" directly above the current motor.
Old May 19, 2016 | 09:43 PM
  #284
JRally's Avatar
But where does the turbo go?
Old May 20, 2016 | 03:51 PM
  #285
I'm thinking like this
