"Project Hard Park"
Old Feb 22, 2017 | 02:42 PM
  #331
V.8MR's Avatar
No its like a rubber mat with a kind of fiberglass insulation behind it.
Old Feb 22, 2017 | 03:20 PM
  #332
kaj's Avatar
kaj
That sounds not fun. Any tips or tricks, or just start pulling?
Old Feb 22, 2017 | 03:36 PM
  #333
Pal215's Avatar
Liquid nitrogen instead of dry ice.
-pal215
Old Feb 22, 2017 | 03:43 PM
  #334
kaj's Avatar
kaj
I have neither LOL
Old Feb 22, 2017 | 04:07 PM
  #335
V.8MR's Avatar
The inside firewall mat came out easy. Its just like a "rug" whcih has bolts and stuff holding it up against the firewall. Getting to all those plastic bolts/clips is the challenge. I just cut it out in sections.
The sound deadening on the floor and driveshaft tube I'll need dry ice or as mentioned LN lol
Old Feb 22, 2017 | 05:44 PM
  #336
kaj's Avatar
kaj
I was able to chip the asphalt from the floor. It came out a lot easier than I thought it would. There are a couple little bits left behind that I need to go back and get.
I suppose dry ice would have helped?
I will be tackling the firewall carpet pretty soon. Do you feel it weighs enough to justify removal? Anything over 3 pounds, I figure will add up eventually.
Old Feb 22, 2017 | 07:21 PM
  #337
V.8MR's Avatar
It was surprisingly heavy. I gotta remove the one on the engine side of the firewall also.
Old Feb 22, 2017 | 10:42 PM
  #338
kaj's Avatar
kaj
My engine comes out this week. I wonder if there's much heat transfer.
Old Feb 23, 2017 | 09:41 AM
  #339
V.8MR's Avatar
Looking for meaningful feedback here.
Since Ive got the motor out I am thinking of removing the head. It seems no catch-can and having EGR has left some build up on 1 or 2 of my valves.
I am contemplating pulling the head, getting more porting + polish, valve job, and swapping cams to Kelford 272. I also think welding the EGR port IN the runner could be possible. Also doing full EGR delete, phenolic spacer which I ordered from English, and ARP stainless studs/bolts.
Here are the images of each port on exhaust. Need input here.
Old Feb 23, 2017 | 09:43 AM
  #340
V.8MR's Avatar
Intake
NOTICE BUILD UP HERE
SAME PORT AS PREV IMAGE, DIFF ANGLE
  #341
LetsGetThisDone's Avatar
looks pretty fine/normal.
Old Feb 23, 2017 | 10:22 AM
  #342
RazorLab's Avatar
Looks normal to me too. Catch can won't do much more than that.
Old Feb 23, 2017 | 02:10 PM
  #343
V.8MR's Avatar
No benefit from what I was planning? Just feels like I should do as much as i can while i have an opportunity. I dont like intake cylinder ones gook on the valve. Plus welding of the egr from the runner, better cams, and further port n p. I will be doing new timing belts water pump, and whatnot too.
Old Feb 23, 2017 | 02:43 PM
  #344
heel2toe's Avatar
Do you have to pull the motor as well as all the crap bolted to the firewall to get the engine bay firewall mat out? I was hoping to do that as a simple project by cutting it out in pieces but seems like its actually more involved than just cutting it out.
Old Feb 23, 2017 | 02:46 PM
  #345
V.8MR's Avatar
Havent started on engine side yet. But ya motor out will sure make it easier.
