"Project Hard Park"
Old Aug 18, 2017 | 01:16 PM
  #481
yellowevo82's Avatar
Awesome build so far!!!! Great job
  #482
heel2toe's Avatar
I never bothered measuring it. Quite frankly, as long as you turned the motor over a couple times let it sit for like 15 minutes and you can still easily slide the grenade pin in and out then you're fine.
Old Aug 20, 2017 | 05:41 PM
  #483
V.8MR's Avatar
Starting to come together. But I think I'm going to remove the valve cover and reseal it. Reflection of American flag was not intended but still pretty sweet!
Old Aug 21, 2017 | 05:41 AM
  #484
Eric SlowEvo8's Avatar
badass pic with the reflection and nice looking engine there
Old Aug 30, 2017 | 02:27 PM
  #485
V.8MR's Avatar
Still doing little projects. Installed Kiggly HLA, removed exhaust studs and replaced with ARP SS stud kit.
Got the oilpan cleaned. And I received 2 tubes of mitsubond and new ruber gasket for the valve cover and plugs wells.
Should have the new pan and Tomei baffle installed in the next few days.
Not sure if I wana do the AN addapter "mod" on the valve cover and run a sealed catch can. Still undecided on that...
Old Aug 31, 2017 | 04:50 PM
  #486
V.8MR's Avatar
Installed Tomei crank scraper and Racefab wetsump. Cleaned top of valve cover. Made for good photo. Getting close to putting motor and 5spd in the car!
Old Sep 1, 2017 | 06:05 AM
  #487
Abacus's Avatar
Nice build.
You may want to check the oil passage near some of the exhaust studs. Iirc there are two that come close to going thru when you replace those exhaust studs.
If they are screwed in too much it can push aluminum shavings into the engine. Some loctite on those two studs is also recommended.
Old Sep 1, 2017 | 07:38 AM
  #488
V.8MR's Avatar
Almost all the lower studs go through and touch oil return holes in the head. With the junk oilpan and no baffle installed I bathed the head in oil several times to wash anything down into the junk pan. I also ran a tap down all the threads to clean them up. Ive read not to use loctite and only snug the studs. The torque from the bolt when installing the manifold is all thats needed. But I am not sure.
Old Sep 1, 2017 | 07:41 AM
  #489
V.8MR's Avatar
More concerned my oil pan is sealed at the moment. Sprayed a lot of oil in the head over night. Will check in a little if there are any leaks around the block/pan
Old Sep 1, 2017 | 01:45 PM
  #490
LetsGetThisDone's Avatar
Its the two big outer studs, and the middle stud on the bottom row that go through to the oil returns.
Old Sep 2, 2017 | 03:06 PM
  #491
V.8MR's Avatar
Had to redo the oilpan due to some seepage on the opposite of the timing side.
And I've now flushed a good 10 or 15 quarts of cheap Oriely's 10w30 through the top side of the motor and drained the pan multiple times.
I guess I can wait on the valve cover mod and get the clutch and trans bolted up and put back in the car.
Not sure what else I can do while the motor is out.
Old Sep 3, 2017 | 07:55 AM
  #492
Abacus's Avatar
If any metal went into the engine it's going to stick on the walls of the head or block. If it were me I would take the head off and clean it and the block. It sucks to do but you've spent a lot of time and money to this point, you don't want to have any issues
Old Sep 3, 2017 | 09:19 AM
  #493
V.8MR's Avatar
That would also involve removing the rotating assembly. Seems excessive... and i just put it all back together. I can see down all the returns while on the stand. I have a pump and tube and am forcing oil with pressure down each one. And I've repeatedly washed out the head with this and let it all drain back into the pan.
I'm going to do so maybe a few more times for good measure. And will change oil excessively once it starts the first time again.
But for these reasons it actually occurred to me to just get a new OEM shortblock and build off of that. May yet do so if this one dies.
Old Sep 7, 2017 | 02:20 PM
  #494
V.8MR's Avatar
Well after losing sleep over it... I had a chat with the guys at Boostin Performance. I think im gonna drop the whole engine off for a fresh 2.0 rebuild and head work. I dont wana leave anything to chance and after the money on the driveline, I think the motor deserves equal love. Updates to follow.
Old Sep 8, 2017 | 09:45 AM
  #495
But why lol? Pop the rod caps and see how the bearings work.
