Evo IX 2.3 Liter Build FP Black Build
Old Nov 19, 2016 | 08:58 PM
  #121
Pal215's Avatar
Originally Posted by lonestarr20
Sounds like a fighter jet, CONGRATULATIONS, and be safe with it..
Thanks brother
I'll do my best. Tuner said I need to get some wider wheels and tires asap haha!
-pal215
Old Nov 19, 2016 | 09:39 PM
  #122
G20's Avatar
G20
Very nice build. RRE is a great shop. Enjoy the car.
Old Nov 20, 2016 | 02:13 PM
  #123
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
The bad news is, the rear diff is toast
Are you sure it's not the TC? Ran into this exact issue with my car, sounded like it was coming from the rear after getting off the dyno. Ended up being my TC.
Regardless, awesome results, a BEAST
Old Nov 20, 2016 | 09:19 PM
  #124
Pal215's Avatar
Thanks!
You never know, it could be the T-Case. It would be pretty sad since I bought a "so called" built by TRE, 0 miles T-case off a member on here and haven't launched the car once. In fact, the car was driven very conservatively since I installed it and it never made any noise until after the dyno tune. If it does end up being the T-case, I will have to down the car for at least 3 months until I save enough money to send it out for yet another rebuild. Would be a shame if that ends up happening
When your tcase went, did it end up being the ring and pinion or diff?
-pal215
Old Nov 20, 2016 | 10:51 PM
  #125
Pal215's Avatar
Just drained the transfer case out of curiosity and found no big chunks of metal or scary left overs. Just fine metal particulate and exactly .63 quarts of Mitsu SAE 90 Diaqueen LSD oil.
-pal215
Old Nov 21, 2016 | 11:09 AM
  #126
LetsGetThisDone's Avatar
Send the diff to TRE, get it taken care of. Those Weir 12 plates aren't that great, they don't last long.
Old Nov 21, 2016 | 12:10 PM
  #127
Pal215's Avatar
I was definitely thinking about it, right now I'm just trying to be 100% sure it was the rear diff so I have another one on the way. If I install it and the noise is still there, I don't know what I missed
Out of gear, the noise is not there, only when the drivetrain is engaged. I wonder if the diff pinion gear bearing can make such a noise.
-pal215
Old Nov 21, 2016 | 12:20 PM
  #128
-pal215
That sounds like a rear diff, typically* the tcase will make noise no matter what, while the rear diff is load dependent (whether its accel or decal load). Sometimes gears just get galled and they get noisey, and unless you clean everything really well, and take a good up close look at the pinion, it can be hard to tell.
Old Nov 21, 2016 | 12:37 PM
  #129
Pal215's Avatar
I hope so my friend, it would be a nice relief this Thanksgiving.
-pal215
Old Nov 21, 2016 | 10:30 PM
  #130
SLVRNBLK's Avatar
Thanks!
Same exact issue with me on a built TC as well. Ended up being the ring and pinion. Noise was very audible only when drive train engaged, very loud on freeway.
Old Nov 22, 2016 | 10:00 AM
  #131
Pal215's Avatar
I see. With the car in the air and in gear, I can rotate a front wheel in one direction while the other turns the opposite. I'm thinking this indicates that the diff is still good and that if there is a problem at the TC, it will be the ring and pinion. Fingers are still crossed that it's the rear diff of course
-pal215
Old Nov 22, 2016 | 10:32 AM
  #132
If you put a brand new TRE tcase on the dyno, you may have killed it. He has very stringent brake-in instructions for his gears. No WOT for 500 miles, and the first 100 miles vehicles speeds shouldn't go over 60mph. It's very important to follow this because of how he sets the up, and the shot peening that he does.
That being said, hopefully its just the rear diff.
Old Nov 22, 2016 | 10:53 AM
  #133
Pal215's Avatar
It should have been fully broken in once it hit the dyno. I broke in the engine, transfer case, and clutch all at the same time. Basically very soft, regular driving for 1000 miles with lots of vacuum pulls and less than 1/4 throttle lol. My God was it boring..
-pal215
Old Nov 22, 2016 | 11:08 AM
  #134
Gotcha. I'm sure the tcase is fine then.
Old Nov 22, 2016 | 11:13 AM
  #135
Pal215's Avatar
I hope so bro,
On a brighter note, I got to ride in a 650hp GTR last night. It was disgusting! You could almost hear the tarmac screaming for mercy! My friend even used launched control to really kick our asses into the seat It pulls so hard from a dig that you feel the same G's as if it was about to hit it's peak torque from a roll. Yesterday, inertia did not exist!
-pal215
