3rd Build, lets hope this is the final...Evo8
Old Mar 11, 2024 | 12:02 PM
  #151
osetsky's Avatar
Transmission issues suck.
Not as bad as electric though, so silver lining?
Old Mar 13, 2024 | 06:13 AM
  #152
blackline's Avatar
5 Year Member
probably the fork is bent or needs a new clutch master cyl? braided line ( i cant remember if it had rubber hoses)? IIRC theres a restrictor/pill in the clutch line also
Going to look through the inspection hole to see if anything looks off. I've been debating on changing the clutch slave cylinder just for ****s since it's the original one(it does move when depressing the clutch pedal). Not sure how to test the master cylinder. I've got the SS line going from the master to the slave.
maybe, just maybe.
Old Mar 13, 2024 | 07:17 AM
  #153
jagboy125's Avatar
You should inspect your clutch pedal assembly some times they are known to crack and cause engagement issues
Old Apr 2, 2024 | 06:56 AM
  #154
blackline's Avatar
5 Year Member
Update.
Clutch assembly is good.
Replaced Master and Slave, still locked out of all gears while the car is started. Going to jack up and peek though the inspection hole but will still end up dropping the trans to inspect everything. Wont be able to get this done until June ;(
michaelrc51
63
Jan 29, 2015 09:01 AM
superbovine
Southeast Region
Sep 5, 2014 03:51 PM
lowevo8
Mar 20, 2012 05:19 PM
wtf_is_a_evo
Sep 14, 2011 05:55 AM
