Evo VIII MR World Time Attack Challenge Build From Australia
Few more bits done, I cut the rear wheel well out and also got my new exhaust system made. It’s a 3” one piece with v band that connects to the downpipe the whole system weighs 12kg which is super light.
Some more carbon turned up, new boot lid and some tunnels for my new splitter I’m making.
Benny
Benny
So a few big decisions have been made in the past few weeks. I’ve decided to go down the route of a full re wire of the whole car using a Motec m150 and Motec pdm15.
Also getting a pedal box and will be installing Bosch abs in the car.
And I’ll also be painting the car oem electric blue on the outside and then Ferrari Nurburgring silver on the inside.
Benny
Benny
A few more parts turned up:
SSB Rear Control Arms
SSB Front Uprights
PWR Racing Extruded R Fin 55mm Rad
Sydney Composites Carbon Splitter End Plates
Sydney Composites Carbon Dash
The dash is super super light at only 2.6Ib
The rear SSB uprights should rock up soon as well.
Benny
SSB Front Uprights
Benny
Fitted the front uprights and also fitted the radiator.
Radiator was a super tight fit but it fitted none the less!
Also my T45 FIA WRC Cage finally turned up from the UK!
Benny
Benny
Started stripping the car for the re wire, new brake setup and the roll cage, I removed:
Complete Wiring From The Car
Oem pedals and abs system
All interior bits and pieces
Glass
Engine Bay Firewall Sound Deadening
Benny
Glass
Benny
Stripped the car of all the panels, makes it easier for me to paint them whilst the cage is getting done.
loaded the car on the trailer and took it to my fabricator mate to have the cage installed.
Benny
Benny
Cage install is going well, I’d say he’s about half way with the cage itself.
Once the cage is done he’ll weld the new seat mounts in & weld the steering column brackets to the dash bar.
Benny
Benny
Next year I will build the motor and go for more power, I wanted to get absolutely everything done first before the engine.
Benny
