Evo How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
DIY COP Coil On Plug Setup
Old Jun 2, 2017 | 05:11 AM
  #76
JD's Avatar
JD
Originally Posted by llDemonll
JD Customs kit linked above is using very cheap chinese connectors and is missing a washer to keep the coils level on the mounting plate.I wouldn't buy this kit if I were you
I would guess the cost of his parts is close to $60 and he's selling them without any assembly done
I'd reach out to Matt @ Spoolinup, tell him you're not located in the US, and ask him about shipping you some connectors
had my COP kit for over 3 years now, no issues.
The kit in the link mentioned above uses high quality connectors and it also comes with the washers to keep the coils level on the mounting plate. Hundreds have been sold with absolutely zero complaints. The kit is very comparable to the Spoolin' up kits, but priced more affordable. If you can cut, strip, and crimp wires, you can easily make your own cop kit.
Old Jul 6, 2017 | 06:12 PM
  #77
Ho Wa's Avatar
Thickness how many mm
Old Jul 7, 2017 | 05:18 AM
  #78
JD's Avatar
JD
Are you asking how thick the mounting pate is? I'm not sure what you're asking.
Old Jul 7, 2017 | 09:46 AM
  #79
llDemonll's Avatar
1/8" aluminum is what I used
Old Sep 26, 2017 | 06:40 PM
  #80
jlcann1's Avatar
Great write up
Old Sep 27, 2017 | 06:41 AM
  #81
JD's Avatar
JD
Originally Posted by jlcann1
Great write up
There is an even more detailed write-up on this website: < snipped; it's not a great write-up if you're plagiarizing to promote your business. >
Old Jan 28, 2018 | 08:35 AM
  #82
pre2dat's Avatar
Finally sat down and put the entire COP setup together. Had to piece together some hardware for Lowes and Home Depot to get the coils mounted to the plate but it was only a few bucks extra. The binding posts provided from Spoolinup for some reason did not fit the coils I ordered them for. Oh well, I'm not complaining. I ordered the wrong sleeving from Spoolinup too and had to settle with the flex tubing. Back story is that I literally pieced together the set up individually down to the mounting plate that had to be drilled, then rattle can painted. I followed the DIY this post to the T! Crossed my fingers when I turned the key, but the Evo started right up! Now I just need to clean up the routing a little bit!
Attached Thumbnails DIY COP Coil On Plug Setup-20180127_162145.jpg   DIY COP Coil On Plug Setup-20180127_160058.jpg   DIY COP Coil On Plug Setup-20180127_155659.jpg
Old Jan 31, 2018 | 09:23 AM
  #83
XSivPSI's Avatar
Anyone know if AN099700-213 denso coils will work? I can't find info on their dwell time but I was able to get a set with pigtails.
Bueller?
Old Feb 4, 2018 | 09:11 AM
  #84
gpdriver's Avatar
Nice write-up!
Old Feb 12, 2018 | 01:23 PM
  #85
2006EvoIXer's Avatar
So far, has anyone experience a coil failure yet? Many of you have used this for years and operated with wasted sparks.
Old Feb 12, 2018 | 09:03 PM
  #86
llDemonll's Avatar
Had mine on the car for almost five years now, no issues at all. different harness than when i started but same coils
Old Feb 13, 2018 | 09:29 AM
  #87
Thank you for the update! I picked up 2 sets of Honda COPs from local salvage yards. I got a set from Civic 1.5L and then found a set from Accord 4 cylinder afterwards (and can't return my Civic set). I'll use the Accord set since it's the same as the ones used in 2004-2005 S2000 (6732301). I like the 2000-2003 COPs (6732300) better because of their 9000 rpm redline, but no luck finding those used. I am impressed that they still work and last with our evos running them twice as hard.
Old Feb 13, 2018 | 09:35 AM
  #88
By the way, I plan on bridging the ground and power wires from both connectors since we are firing 2 coils from each connection. By bridging them, I can use both power sources to reduce the load at each. I can't think of any issues with doing this and want to see if anyone here can think of any.
Thanks for any inputs!
Old Feb 13, 2018 | 09:43 AM
  #89
On second thought, I'll run the power and ground on drivers side to cylinders 3 & 4 and passenger's side to 1 & 2. Trigger will remain the same (1 & 4 and 2 & 3). This way, the current draw will be more continuous on both sides.
Can anyone think of any problems with doing this?
Old Feb 13, 2018 | 12:14 PM
  #90
llDemonll's Avatar
Why? It was designed the way it is for a reason. If you're a better electrical engineer than what Mitsubishi can employ, by all means go for it.
All you get is a more complicated wiring harness.
