Camp Lejeune/Jacksonville Evos (NEW)
I would do more research on the subject just to verify, but I believe it's a bolt-on affair. As far as I'm aware the turbos are the same minus the hotside. Again I would verify this though.
It never fails. You fix one problem with your car and gett it running good and another problem shows up.
I was picking my wife up from work last night, driving normal, and than it happens, right on Highway 17. The clutch master cylinder goes out. So my car is down again. Ill be ordering the SSP Upgraded Clutch Master Cylinder and putting it in this week.
Hopifully things are done breaking on my car.
If not im driving the car into a lake
I just wanted to post up a follow up on my headstud 1x1 method. I changed the oil today, and everything is good to go. No coolant in the oil, or anything odd for that matter. I know some people have a dreaded fear of doing the studs 1x1, but the method suggested to me has worked...so far. Basically, install the studs in the proper order. Tq them with the supplied moly lube from arp. I think the important part of this install is the following: Drive the car about 50-80 miles, or through several heat up/cool down cycles, then pull the valve cover and re-check the torque. I had 1 or 2 that budged very little, but I think it's the checking that has kept everything in tact. I have been doing 32-33psi pulls, and all is well.
I have done a hand full of head studs that way without any issues. As long as you go in the correct order or something similar and torque the **** out of them until they are all swapped out, you cant go wrong. Glad to hear the car is doing well. Hopefully be seeing you guys soon.
car is done! hopefully i can pick it up today
update: it was the freaking wheel bearings...Man my car sounds like a normal car again..
On a side note I'll be down at Fort Jackson this weekend until mid June so I might head down to the Jacksonville area one weekend
