Yeaaahhahah!!!!!!
Old Jun 6, 2005 | 11:41 AM
  #271
Racer1's Avatar
For those of us without an xede (yet), will it now be sold as a package or will I have to buy the xede and adaptive hardware seperately? Also, will this new software smooth out the lumpy idle from cams?
Old Jun 6, 2005 | 12:07 PM
  #272
Wrench's Avatar
Originally Posted by atlvalet
Yes, the SR-71 is quite fast. However, it ain't nearly as fast as the Aurora. Anyone have pics of that? Probably not since it's top secret
Google images is great.
Attached Thumbnails Yeaaahhahah!!!!!!-aurora-flight-1-.jpeg   Yeaaahhahah!!!!!!-cross-1-.jpeg
Old Jun 6, 2005 | 12:12 PM
  #273
Dustin@Vishnu's Avatar
It will be sold as a package for new buyers. The xede already smoothes out most of the lumpy idle.
Old Jun 6, 2005 | 12:13 PM
  #274
EV0lut10n_8's Avatar
Originally Posted by shiv@vishnu
Nope. You could even upload the map i posted up and run with it. All you need to do is feed a 0-5v output from wideband 02 sensor into Pin 9 of the Silver XEDE connector. This will provide you with the AFR signal necessary to run the active fuel control function.
For the active ignition control function, you will need to tap a wire into the knock signal wire (pink wire/Pin 4 in Black XEDE connector) and feed it into Pin 10 on the Grey XEDE connector. The the middle of the wire goes a little knock signal buffer circuitry that we made. This steps up the current of the teeny tiny raw knock sensor signal so that we can feed it into the XEDE without degrading it. We are in the process of making a bunch of these add-on buffer devices so hold off for now.
Also, the active fuel control only works if the wideband 02 sensor is calibrated just like the one we are currently using. If it is not, the desired AFRs will not be hit. Needless to say, we are in the process of settling upon a wide band unit so that all of us can play on the same field.
So maybe it's not a good idea to use the file I posted just yet
Cheers,
shiv
Nice I already have a wideband O2 sensor too!!!
Old Jun 6, 2005 | 12:25 PM
  #275
evowilling's Avatar
If you incorporate instructional tutorial seminars on DVDs into your plans, this would also be great for those of us who live in other regions.
Old Jun 6, 2005 | 12:44 PM
  #276
Wrench's Avatar
Shilvan Learning Centers up next?
Old Jun 6, 2005 | 01:47 PM
  #277
asasin79's Avatar
so is the Innovative LC-1 the final decision for the wideband?
Old Jun 6, 2005 | 02:14 PM
  #278
Jorge T's Avatar
looks like it
Old Jun 6, 2005 | 02:47 PM
  #279
Vishnu_Evo8's Avatar
the aurora isnt real is it? its all speculation still if it even exists.
Old Jun 6, 2005 | 02:51 PM
  #280
Terry S's Avatar
Oh the aurora is real. I'm typing this from the cockpit of the Aurora from my blackberry somewhere over durkdurkistan right now....
Old Jun 6, 2005 | 02:54 PM
  #281
moab3man's Avatar
Originally Posted by Terry S
durkdurkistan
hahahahahahahahahaha!! that cracked me up! that movie is so funny
Old Jun 6, 2005 | 03:18 PM
  #282
KazzEvo8's Avatar
Anxiously awaiting announcement for package contents and pricing - and recommended installers across the nation ... *Chuckle*
Old Jun 6, 2005 | 03:21 PM
  #283
Erik@MIL.SPEC's Avatar
I'm willing to bet it is real. There was mention of it when Sam Nunn was head of the Armed Services commitee in the Senate. They ended up striking it from the record, but yes "Aurora" was mentioned. Why else would they decommision the SR-71? The US government hiding something? No way
Old Jun 6, 2005 | 03:39 PM
  #284
Bump back to on topic
Old Jun 6, 2005 | 03:48 PM
  #285
gsujeff55's Avatar
well, hot damn....i gotta check evoM more often.
BUT, the question has to be asked.....HOW WILL THIS WORK WITH ALCOHOL INJECTIION? ive been fiending for some AI for months, finally got money for it.....will these new goods work with it? or will i need a custom map as well as the new vishnu goods?
Thanks shiv
