Yeaaahhahah!!!!!!
Originally Posted by Quickshifter
I've heard this is a scam. From good resources I was told an SAFC would do all of this for me and more........while making much more power
Originally Posted by shiv@vishnu
It will be displayed in the a newly revised XMAP screen which will look something like this (rough design sketch)
water spray controll=methanol spray controller
Shiv
Shiv
Originally Posted by Event-Horizon
Shiv what is the life-span of a wide-band O2 sensor?
I've heard that using a WBO2 on a daily driven car will cause it to go down south rather quickly... < 10K miles?
Originally Posted by zstryder
+1.
1.) you are using race gas (read: leaded)
2.) you don't have it wired right, and it doesn't receive power to pre-heat the sensor when you start the car
3.) you are running extremely rich for extended periods of time
4.) it is mounted too close to the turbo - the excessive heat will not only potentially give inaccurate readings but will shorten the lifespan of the sensor
5.) it is mounted below the horizon - i.e. if 12 o'clock is the top of the exhaust pipe, the sensor shoudl not be mounted below the 9 o'clock - 3 o'clock line
AFAIK a properly mounted wideband sensor is:
a.) mounted as close to 12 o'clock as possible (pointing straight down)
b.) as close to the cat as possible
c.) is removed when using leaded gas
l8r)
Sam
Originally Posted by EvoSam
I'm curious, do you know why the orientation would matter? I had a bung welded into my DP before I installed it so I could plug in a WB O2 sensor for tunes and such, the shop that was doing the dyno tune opted for the side of the pipe rather than the top for the bung placement. I imagine it's because it's easier to get the sensor in and out from under the car when it's only going into the side rather than the top, but no mention was made of the "correct" orientation at that time.
Sam
Sam
l8r)
It is my understanding that if you mount it below the horizontal, condensation can collect on the sensor and corrode it. If it is mounted above the horizontal, any condensation will only collect on the tip and drip off. This was per Klaus at Innovate.
l8r)
l8r)
