Yeaaahhahah!!!!!!
Originally Posted by SuperHatch
Just in case you were serious about that question...
And the jurys out about the increased ramp in noise at the extreme upper RPM range.
And my questions... I have a custom 93 Octane map and 100 octane map. Will this new hardware automatically make my maps adaptive, or do I need to send you the map files for some changes? Also, do I even need 2 maps anymore? Or should I just run the 93 map all the time and the XEDE will adapt for the race gas when I put it in?
- Steve
- Steve
We have found that the race gas map and benefit from more aggressive Adaptive maps. By "more agressive", I mean maps which allow more autorithy range for ignition advance. In some parts of the Adaptive timing map, you'll see as much as 4-5 degrees of advance added in at partial throttle for a fraction of a second or so at a time (resulting in HUGE drivability improvments). With the pump gas maps, I've limited these Active map changes to max out at 2-3 degrees just because I never saw any condition which allowed more advance than that when running pump gas.
What is unreal is that these Active maps basically do the job of a 8 hour custom tune on a load bearing dyno (tuning to the safe power threshold for every single load/rpm point). Moreso, it does it for constantly changing conditions. So instead of tuning for different load/rpm with regards to worst-case-scenario, we are tuning for load/rpm/condition. Prior to this, I had to go super conservative on portions of the map that weren't tested sufficiently or got historically troublesome when conditions took a turn for the worse. These days are over. So much, in fact, that now we can finally start adding in power went conditions get good. So, in effect, not only have we fixed a problem that existed with tuning these cars, we are solving a problem that we NEVER though of even addressing. It is requiring us, as tuners, to completely rethink the way cars want to be tuned and what we should expect from them. Never before have we realized that we, and everyone else for that matter, have been leaving so much power on the table that was up for free gabs. We just needed to find out how to get our hands on it! And we did
Shiv
Originally Posted by Daveyd
Any before/after dyno results?
Yes, but full throttle/single gear 2000-7800rpm dyno pulls will only show you the 5-10lb-ft gains, here and there, where the Active maps fill in dips and smoothens out the humps. It wont show you the 30-40ft-lb gains at partial throttle during dynamic driving conditions. It's the kind of thing that needs to be experienced, first-hand, to recognize. What I'm going to try to do this upcoming week is capture some normal road driving conditions (on/off load, partial throttle, etc,.) on the dyno. The tough part is keeping this behavior reasonably consistent between tests. In the end, you need to drive it yourself to see the difference.
shiv
When can we get this???????? My Doctor told me if I carry a "Chubby" for over 4 hours, I need to seek Medical intervention!!!!!!!! I've got 1 hour to go.......... so spill it, when can I/we get it!?????????
Originally Posted by jfh
I have been a Vishnu fan from the day I purchased my Evo in March 2003 and participated in the 93 Octane Xede map development sessions shortly thereafter when Shiv first came to the East coast. I too am very stoked about this exciting new development but have a few questions.
Most importantly, when will it really be available for those of us that do not live conveniently close to your shop to be test mules? No offense, but historically your new product announcements have routinely been followed by months of delays prior to public release if they are ever released at all. Remember original announcements for v3, Stage 2, rear sway bar, etc.... I understand the rationale for delays and I'm just trying to put this new development into perspective.
Finally, how much will it cost to upgrade existing Xede? Please provide pricing both with and without wideband sensor (assuming the AEM UEGO is compatible).
As always... waiting patiently to upgrade.
New upgrades/updates will always been tested on local cars first. Then in Dyno Days. Then, finally, fully released to everyone. That's the only way we can catch little glitches and make further enhancements before the flood gates open to everyone under the sun. We put A LOT of time into designing and refining this Active system so none of us are going to risk having it not work like it can/should when it hits the street on other cars. The difference between this upgrade and other much-delayed upgrades is that we've been working on this for a very long time without ever telling anyone. We all knew how important/revolutionary it is and we didn't want to let the cat out of the bag. So rest assured that you're learning it about very close to its public release date.
Shiv
Originally Posted by shiv@vishnu
Ok.. back to business.
As of now, here's was the "Autotuning" upgrade package will include:
Wideband o2 controller (with Bosch sensor)
o2 sensor bung
Knock buffer circuitry
C-Reader OBD-II diagnostic tool
IDC wire
o2 sensor bung
IDC wire
Ok... here's the more info:
Price for the Adaptive package listed above should be around $400. Exact price will depend on the final design of the knock buffer unit. Due to popular demand, it looks like we're going to go with the Innovative LC-1 wideband controller. They (Innovative Motorsports) are out of stock until the 15th which gives us time to make the knock buffer units. We fully expect to be updating locals by the end of the month. Then to SoCal'ers in 4 weeks. Then it's out to everyone else, everywhere else.
We'll make an announcement within a few days with regards to when we're ready to take orders.
If you already have another wideband controller, it's up to you whether you want to keep on using it or trade it for the unit that we will be supporting. All of them work a bit differently and offer different calibrations. The differences are significant enough to cause issues with the active fueling system that will need to be addressed by the user. It's up to the user to determine if they want to deal with this.
The C-Reader is a necessary component to this system. It only costs $50-60 so please go with it. It helps us support you. Just the fact it supresses the PO300 code when left plugged in should be enough reason to use it.
More info to come...
shiv
l8r)
Shiv, as part of an upgrade kit, please consider offering a full plug-n-play harness. It would make it easier to just unplug the old harness and replace it with the new one and eliminate the likelihood of tapping into the wrong wires or connecting to the wrong pins.
Regarding Upcoming Dyno Days
Due to this recent change in tuning functionality, the format of all DYNO DAYS to come will be changed.
As discussed in the SoCal dyno day thread, we are in the process of changing the way we do things. I would like to slowly shift away from tuning cars towards showing YOU how to tune YOUR car. With the adaptive features, this is finally feasible... even to those who have no prior tuning experience and no (or limited) access to dynos. So instead of me tuning 10 cars/day for 2-3 days in a row, I would like to tune fewer and use the time left over to conduct a tuning clinic/demonstration for those who want to learn how to tune. We'll try this format out in Socal and see how it works.
How does everyone feel about this?
Cheers,
shiv
Cheers,
shiv
