Case Study: Road "Tuning" vs Dyno Tuning (Merged)
Originally Posted by pyrovice
I thought Warrtalon did alot of his own tuning at the track?
Originally Posted by IE Evo
True on race gas but his 93 oct toon is all Al and it did 12.2 at 110 mph w/o cams. Not bad! His race gas time and trap is his warrs tuning.
Ladies and Gentleman,
This thread has been "pruned" to clean up the personal insults and off topic comments. I am in no mood to do it again. Any off topic comments will be removed without warning and you will be assigned to answer all "why can't I post in the for sale forum" PMs. Flaming will result in you and and your dance partner spending the next 3 days in time out.
Now, if ANYONE has an issue with fairness, bias or really offended because your post was removed then PM me. Please include your IP address and where you would like you mail forwarded.
Speedlimit...
Speedlimit...
Originally Posted by jj_008
On topic question:
Does a load bearing dyno put more load on the car then the road when using 4-5th gear? I noticed that I always hit higher load cells when I am going up hills in 4th gear.
Basically, will a load bearing dyno simulate the highest load up the car will ever see(5th gear road pull) in a 3rd gear dyno pull? That way I could interpolate the data into the lower cells and get it all done in one shot.
Thanks Speedlimit for cleaning and re-opening the thread.
alright cool, how does he revert to al's flash though? Like does he save the settings on his AFC or something?
This will no longer matter, though, because the SMC kit just got installed today, and I will get tuned for full-time 24-25psi on 93+alky next weekend. I won't need to worry about race gas anymore.
For reference, since Gruppe-S is where this car was first dyno'd and shown to have issues, here is a Gruppe-S dyno day from the summer:
http://www.gruppe-s.com/DynoDay/DynoDay.htm
Notice where the Dynoflashed cars sit in comparison to the other cars. These are all road tunes by Al that then went on the dyno a few weeks later, whereas some of the other cars have dyno tunes from other flashers. This shows the typical results of a Dynoflash on an VIII.
I do not have any such references to show that IX road tunes are equivalent or better than other dyno tunes yet.
Originally Posted by Jon H
I think Al was referring to this graph?
Originally Posted by DynoFlash
Hard to reach any conclusions about MIVEC tuning unless the boost was identical
I would like someone to address the first comparison of the dyno curves that have similar boost. It is easy to understand that more boost = more power, but when that is taken out of the equation how do we explain the first comparison?
What I also hope to learn from what could be a productive discussion between vendors is the different tuning results as far as powerband placement goes between the different tuners if any is intended. I've heard different people say that DynoFlash is more drag racing vs road racing with Vishnu. Maybe the AUTC is more important for Vishnu and peak or upper rpm power is more valuable to the DynoFlash camp?
It looks to me that Shiv is saying that with his tools (a dyno, his software, tuning, etc.), that he is able to improve on a base map - thus the higher boost on subsequent runs. Part of what I glean from Shiv's posts is that his method of using a dyno to tune is more accurate and appropriate for this early stage in development of tuning the Evo 9 than a road tune. Maybe with more data both teams will improve?
In response to the parts discussion - again from my limited reading here - the stock intake seems to be an important factor in Vishnu tuning. If I remember correctly from the initial post, the intake that was removed wasn't a Buschur product, it was HKS right? Maybe that was the largest part of the issue? I'm just trying to brainstorm here...
Rgds,
Adam
Rgds,
Adam
I don't see this as bashing Buschur products. I did see that he had a problem w/ the downpipe, but I am sure Buschur would of replaced it free of charge. Hopefully, he calls Buschur anways to get his DP replaced.
The real issue comes w/ the way the customer was treated. He felt his tuning experience w/ Al wasn't very good. So customer calls Vishnu for their service. Vishnu tells the customer that he can make same/better power w/ the stock parts. Customer is happy, because he can sell his parts (regardless if they were Buschur, RnR, AMS, JDM, etc.) The customer didn't like the sound of an intake so regardless the stock intake was going back on.
Either way, the customer is happy and Al needs to address his customer service.
I agree. Here is what I wrote on the other thread.
something on this I can agree with. the rest is of not much use. sort of I do not belive the stock downpipe will make more power that DBs downpipe.[/QUOTE]
Actually, the DB dp was replaced with a Works dp, not a stock one.
Speedlimit...
Speedlimit...
-shiv
I also think that the Evo IX ecu has a lot to do with that happened. It's much more advanced then the VIII's and I think Al wasn't prepared for it. I'm sure he has no problem tuning the VIIIs.
