Case Study: Road "Tuning" vs Dyno Tuning (Merged)
Originally Posted by DynoFlash
Doing a straight a head pull in 3rd gear takes you to the mid 70 mph range which IMHO is very safe in proper locations which is why I am careful to choose good locations
Its really idiotic to think that some guy with say a BR stage One will need to have a compeltely different tuning map than some other guy with the same identical mod combo
I would be much more inclined to believe that there are major differences between individual cars which would make it very unlikely that you could develop a cookie cutter tune that would yield big power gains in any EVO. I think that the factory tune is the best compromise that the engineers at
came up with after who knows how many thousands and thousands of hours of work and tests which would produce the best, safest levels of performance for all the cars taking into account their differences.While I'm willing to believe that off-the-shelf flashes can modify things like the rpm cut-off and other such things, I don't believe that there is any way that a universal high power recipe can be made that will work safely or effectively in all cars. That's exactly why people like yourself and others travel around the country performing custom tunes..........
when Al talkes about road load conditions what does he mean?? air,terrain,ambient??
i dont see a lot of car manufactures going to other countries to road tune a car example:
like me for instance i bought my car from japan and no japanese guy came here to tune my car for the roads we have in our country they just sended me the car!! what i say with this if road tuning would be so important they would have sended someone from the factory to tune my car to the roads we have!!
also in the brochures that i have from the evo they present dynos sheets of horsepower and torque and most car manufatcures do this!! so i assume they do dyno testings!
so in my opinion i prefer a dyno sesion then a road sesion tune where you dont have any base runs nor after runs only our butts dynos!!
also not every aftermarket part will give you the gains they claim!! cmon its marketing they do the best!! so i prefer stock parts most of the times!!
Isnt that a rather back wards and silly way to try and resolve anything ?
Just becuase the car makes X amount of power on a dyno what does that mean when you drive on the road ?
Is the tuner who is able to make the most possible WHP the "best" tuner - would that mean he wins?
I THOUGHT that I verified my claims by having probably the best record of engiune saftey and long term reliability of any of the major tuners out there and by having many happy customers who have gone fast driving the cars on roads and tracks.
Is the only way to "verify" my product to make more whp on a given dyno than some other tuner ?
What if the margin of saftey and RELIABILITY were some of my MAIN objectives ?
IF I WANTED to make tunes which were primarily SAFE and RELIABLE - would not the actual data I collect be more relevant than a dyno figure? For reference, I log TPS< IDC, Knock voltage, MAP, A/f, Ignition timing, knock retard of stock ecu, and RPMS
Wouldn't the a/f and knock be more "important" to a customer who wants to have his car last for 5 years than peak whp ?
Does it seem odd that the car in this thread is being run on such high boost and lean a/f on 91 octane fuel on the dyno logs ? IS 23 PSI OF BOOST AT 12/1 A/F a safe and good manner of tuning on 91 octane CA gas ?? What is the MARGIN of saftey left with a tune like that ? What happens when he picks up a bad tank of gas ?
Did you guys know that I tune ALCOHOL injected cars at that kind of boost levels on 91 octane
Does that make me a bad tuner IF I am more cautious?
Tell me why the Evo is so slow when its brand new - is Shiv a better tuner than
- is
a buntch of loosers ?
- is
A road tuned car is faster on the road than a dyno tuned car - NO MATTER HOW MUCH power the dyno measures becuase in many cases if you tune a car for max whp on a dyno it will knock and pull timing as soon as you drive it on a road
Those who are interested in the subject of the use of dynos to test modern cars should read this interesting article
http://dinancars.com/whitepapersFile.asp?ID=9
l8r)
One more note ... it is also incorrect to assume that a custom tune is "better" than an off-the-shelf type tune. Generally speaking (and there are, of course, exceptions), but generally speaking a custom tune will get as much performance out of your car as your current level of mods and the safety margin of the tuner will allow. For those of us, living in climates where there are significant temperature changes over the year, this generally means that we get a a kicka$$ tune for when it's warm. However, once it gets cold, that wonderful summer tune has a tendency to overboost and therefore becomes a very "bad" tune unless it's adjusted.
l8r)
Al, also car manufactures use dynos for most thats why they use it in there brochures so customers see the graphs so i think for them its more important the dynos sesions!
MY POINT IS that having a tune set up for MAX WHP ON A DYNO is not what makes a "good" tune for the street
IN EVERY case where I have tuned cars on dynos I detune pump gas cars SIGNIFICANTLY off the theroertical max limits
If good = MAX POSSIBLE WHP you can make on a given set of mods then you don't want my product
I say this and meanwhile I have more customers in the 11's than any other reflasher - my product is very fast and very safe - it is NOT THE MAX WHP YOU CAN MAKE
I tune to reach the proper compromise between power, saftey and smoothness which is a matter of judgment and discretion of the tuner and not something you can measure on a dyno
If the car could max out at 375 whp at a given level of boost - it may be prudent to tune it at 340 - 350 whp to allow for variation in fuel and climate for instance
A dyno is just a measuring tool like a ruler
Cars are driven on the road
The cars I tuned are tuned to make very good power gains over a stock tune and also maintain near stock like reliability
The reason why I ask if Mistsubishi are loosers is I query why the Evo comes do detuned and makes so little power on Shiv's dyno ? Maybe they should hire shiv to tune the cars at the factory with the exede ?
Originally Posted by KevOVIII
By the way, can you please get back to me regarding the question(s) I had through PM? It's been almost two days (1.5 days to be exact) since my last reply (you confirmed reading 2 PM's but haven't confirmed reading 2 of the same ones that I reforwarded because you haven't responded).
I've been patiently waiting for your reply since I've seen that you've been on and posting quite often:
https://www.evolutionm.net/forums/se...nduser&u=13943
If you do not wish to communicate via PM, then please let me know here. Thank you.
Ok, why do stock evos make such little whp on Buschurs dyno?
They are both low reading dynos. If I didn't understand your question correctly, please rewrite it so more than 2% of the population can understand it.
- gasoline quality (detuned)
- altitude (detuned)
- emissions (detuned)
- Japanese "honor system" for car hp - i.e. keep it under 300 hp (detuned)
- atmospheric conditions (detuned)
Furthermore it seems to me that stock Evos read low on all Dyno Dynamics dynos as well as a lot of Mustang dynos. Again, why bother asking rethorical questions?
l8r)
Originally Posted by Ludikraut
Actually there are a few areas where "one-size-fits-all" flashes can be developed, and that is in specific octane tuning. A stock Evo ECU is tuned for the worst-case scenario, which might look something like: 91 octane (R+M/2) gas, at an altitude of 7000 feet, during blizzard conditions at -10 degrees fahrenheit. So, conceivably, you could develop an off-the-shelf flash that would work for 93 Octane gas and still leave enough room for the other worst case scenarios and have it work for all Evos (let's say 99.9%). Something like that would probably be worth about 10 whp...
tune is for worst case scenario, but still there are cars out there (for instance my old EVO according to Al) which are at the margin even with the
tune.... Imagine what happens to a car like that with cookie cutter tune that removes that small factor of safety.....
One more note ... it is also incorrect to assume that a custom tune is "better" than an off-the-shelf type tune. Generally speaking (and there are, of course, exceptions), but generally speaking a custom tune will get as much performance out of your car as your current level of mods and the safety margin of the tuner will allow. For those of us, living in climates where there are significant temperature changes over the year, this generally means that we get a a kicka$$ tune for when it's warm. However, once it gets cold, that wonderful summer tune has a tendency to overboost and therefore becomes a very "bad" tune unless it's adjusted.l8r)
. Also, I know all about the need to re-tune when the weather gets cold.... Now, that brings up yet another issue. How does a "road tune" address that change in temperatures? I guess one would have to have the "road tuner" make another set of runs and adjustments each time the weather changes.....Now, isn't a fact that the stock
tune works for all situations? Even allowing for lower octane gasoline? Seems to me that everyone with any sort of custom tune needs to visit their tuner at least twice a year..... Also, if those off-the-shelf reflashes are in effect changing those maps for a more aggressive tune, would it not become more dangerous as the conditions change? After all, do brand X, Y or Z reflashes allow for more power under all the conditions that the OEM maps do? Something has got to give... I don't see how one can have it both ways...
Originally Posted by razorlab
What? If I am understanding this correctly, which is hard, you are wondering why stock evos make such little whp on shiv's dyno?
WHY are stock evos so weak on every dyno?
WHY can most tuners reflash the ecu and make much more power so easily ?
WHy is the tune from
so weak?
