Case Study: Road "Tuning" vs Dyno Tuning (Merged)
Originally Posted by DynoFlash
YOUR CAR which I vividily remember has qucik trip gas and was knocking very badly when I started testing it
A quick dose of octane booster arrested most of the knock - diagnosis bad gas
When I encounter guys like you now - I just send them off for a 5 hour drive to burn off all the fuel and retune them on a good tank of gas - lessons learned
Sure you can, I am not talking about throwing in a ecu and going at it you need a base but you can tune a car from the pits lap after lap with several ecu's
Originally Posted by Cloud
Positive manner ae? >__>
It seems like you need to chill with the flame tosser Al. Your lucky you pay to be on this forum because if anyone else said committed this type of burning, they would be banned. "Vishnites, Vishnu Clown." Thanks for being the father of the equivalent to racism here at EvoM.
Forgive me if I'm wrong, but could you accurately tune on a roadrace track?
Your constantly changing the load, throttle, accelerating, decelerating rapidly, ect.
I don't think that would be the best enviornment to tune a car. I think tuning on a dyno and testing it on the track would be the best IMO.
BTW. Speedlimit. My hawks are going to kill your patriots if they make it, but I think Payton is finally going to get his revenge before they get a chance.
Ok its 479 posts about 1 - Al's tuning ability or 2 - Road tuning not being accurate...
Can anyone prove that road tuning is not accurate? If you can, please go tell all these stupid race teams that they need to use a dyno or they will never reach their full potential.
Also you can spell check me or take something I said and make it sound different if I do not write a whole book on what I really meant.
We still have not seen anyone prove road tuning to be unreliable at the track with Et and Mph...... I will bet there are cars with slightly higher dyno numbers and slower E.T. Mph
Originally Posted by jrsimon27
do you have prove of this??
also car manufactures they dyno the engine off the car(chasis) on a bank and they get Base horsepower thats how they tune it!
Originally Posted by Event-Horizon
The mods will add very little if nothing at all without proper tuning. How will you know if the expensive parts you bought and installed on your car made any more power? What if it made less power? You butt dyno may be missleading you. Say you buy a turbo kit that claims 50 more hp. Do you just assume that its going to make that power on YOUR car? If you dyno'ed the car you could verify the claims of the product. If it didnt put the power down you could call the manufacturer and get a refund. However, with your logic you would never know if it produced the numbers it claimed. A dyno not only allows for the tuning of a car, but allows you to verify the claims of other tuners and parts.
I'm sorry but dyno numbers have a direct relationship with that speed and trap time you will put down at the track or what times you run around a road course.
Its not late in any game
If you know the answer why
has tuned the stock evos so weakly them please share it with your fellow Vishunu haters here and enlighten us all
has tuned the stock evos so weakly them please share it with your fellow Vishunu haters here and enlighten us allLast edited by razorlab; Jan 11, 2006 at 06:57 PM.
Originally Posted by poormansracecar
It is know that factories give false hp figures because of federal and insurance reasons. I know for a fact my Buick Grand National made more than 245 hp stock. Everyone always says the Skyline hp is way underated. I think Mazda got a lawsuit from their Rx-8 not making the claimed hp.
Originally Posted by andrew20195
As stated before in this thread, F1 teams are constantly fine tuning the engine management based on track data.
It may not the best environment to get a "base tune", but for exactly the reasons you state, it is the best environment to fine tune the car for the conditions it will see on raceday. Keep in mind that F1 teams log EVERYTHING, because they have half a billion dollars a year to spend, and they will do whatever they think they need to win.
When at the track they measure the weather conditions and load in the map that they developed on the dyno.
They do the same thing with the chassis, the car is put on a 8 post rig that perfectly replicates the track and loads the chassis will encounter and they run through controlled simulations testing every variable.
See the pattern, on the dyno (weather engine or chassis) you can isolate the variables and absolutely control the conditions of the test. F1 drivers don't even get to choose the set-up of the car anymore, they log the data and send it via satellite up link to the factory where they run simulations on the 8 post rig and come up with the solution which the beam back to the team at the track (I kid you not).
The point is that they do gather ridiculous amounts of data, all so they can better simulate those conditions under control on the dynos. The track is not for tuning it is for data gathering, the dyno(s) are used for tuning.
We did the low budget version in Word Challenge GT the last couple of years. Cosworth would dyno the engines under all possible conditions and load all those maps into the laptop we'd get to the track check the weather and load the right map, then monitor the car to check to make sure the engine was running properly, if it wasn't the map wasn't changed the engine problem was diagnosed and the parts (sensors etc.) were replaced. The map was always trusted because it was made under controlled and verified conditions.
Umm. What does that have to do with road tuning not being accurate? Also the GN makes close to 300 hp. So its way off. And what does the heavy skyline trap at? I'm sure its more than 15 hp off.
Yes, toplevel teams tune at the track, especially in drag racing. No, with only dyno tuning back home at their shop, they will not be optimized, due to having to rebuild engines between rounds. Toplevel teams have to tune at every single track they go to. Elevations change, temps change, etc. There are a ton of variables from day to day and minute to minute. They must always adapt to the changing conditions. This does not matter in this discussion. We are talking about which methods we prefer our cars to be tuned with and with methods we feel are best for our cars. We are not looking for every single horsepower nor are we going to get tuned 47 times a day for changing conditions.
What this whole thread comes down to is personal preference just like most everything else. We all have our opinions as to what we think are the best ways to do things. You have to find a tuner whose tuning methods, philosphy on tuning, etc are inline with what you like. I like what Shiv has done with my cars. I agree with his methods and how he does things. What Shiv does is best for me. I have more criteria than who makes the most power and what not. Having a good working relationship with my tuner is also important to me.
Who is better? That can't be answered the same by everyone. For me its Vishnu and not Al. Nothing against Al, but I personally will not be a customer of his for many reasons. In fact if a certain shop had EcuTek capabilities, Shiv wouldn't be tuning my car either. Nothing against Vishnu, but I think a certain someone is as good and is local to me.
I am guilty in some of my earlier posts of trying to get some poop started, but its time for all that to end. We each have to answer the questions of who is better for us individually. This thread will never answer that for us. We might as well be trying to figure out which subwoofer is best. JL, OZ, Kove? I hate JL, but we can argue all month long as to which brand is best.
Originally Posted by chronohunter
No way I have to call BS on this one. F1 teams do not tune at the track, it has been said here wrongly several times now. They have the most sophisticated dynos in the world with the engine doing the exact same lap for the next race hooked up to the gearbox a computer and in a controlled sealed dyno room where the control the atmospheric conditions exactly. The can control altitude (baro pressure), humidity, temperature etc. The engine is tested under these controlled conditions through the range of weather conditions that they may face. It is all done on the dyno, all possible conditions all loads simulated over and over by the computer running the engine till they are satisfied.
Thanks for all that interesting info. Now all of that is needed to simulate what? REAL WORLD CONDITIONS.... So now I'm guessing all these "other" dyno shops have the same thing so they can replicate the "Real world".... Or maybe the real world would be more accurate if you do not have a 1 billion dollar dyno to tune with... And I was being serious when I thanked you for that detailed information.
they use the track to gather information so that they can tune it on a dyno!
The Good:
- Tuning at the track has you driving your car in real-world conditions
- As long as nothing goes wrong, you end up with a good 1/4 mile tune
The Bad:
- When tuning at the 1/4 mile strip, you only get a full pull in 1st gear, all other gears won't get below 5000 rpm. Not exactly what I'd look for in a "tune"
- No chance to map partial throttle at all, since you're at WOT all the time
- Not exactly optimal to tune for other conditions, such as road-racing ... i.e. you are not stressing the engine long enough
- You cannot monitor more than a few things at a time, and the faster you go, the fewer things you will have time to monitor (read: keeping the car in control will start taking 100% of your time if you're fast enough).
The Ugly:
- If something goes wrong, things can get really dangerous, really fast. When you're hauling *** down your lane at over 100mph and your boost suddenly starts to climb, you're very unlikely to be in a position to react in time.
Depending on the track layout, tuning on a circuit race track would be more appropriate when tuning for daily driving.
Tuning on public roads, IMO, is not only not accurate enough but also irresponsible.
l8r)
