how does Shiv feel about the 20GIX turbo
Old Mar 2, 2006 | 01:25 PM
  #106
fury656's Avatar
An upgraded wastegate actuator is crucial with these turbos. The dif in boost response/stability before and after is major (mine is set to 17psi spring pressure). Atleast that was the case with my WR-8.
Old Mar 2, 2006 | 01:32 PM
  #107
Ted B's Avatar
FWIW, the WG that is affixed to the 20G-9 is claimed to be an 'upgraded' unit.
In order to tighten the WG, I presume that I'd remove the cotter key, and screw the turnbuckle such that I'm effectively shortening the rod? That would seem to require more diaphragm travel against the spring to get the same degree of WG movement.
Likewise, I'm guessing that the max boost pressure when the WG is actuated entirely mechanically should match the pressure rating of the spring. If this is the way to 'calibrate' the WG, that seems logical enough.
Old Mar 2, 2006 | 01:46 PM
  #108
shiv@vishnu's Avatar
Correct... going to soft on a wastegate and relying on your boost control system to raise boost to the desired level is going to impact boost stability. It may be more spike prone under dynamic conditions. However, it should have no effect on power just as long as the desired boost pressures are achieved. On Ted B's dyno graph, there is no evidence of boost instability. Just a bit more lag and a lot more high RPM boost.
Shiv
Old Mar 2, 2006 | 01:49 PM
  #109
fury656's Avatar
With FP's unit they gave an approximate idea of where to adjust it but thats basicalyl the procedure. Just remove the cotter pin and adjust the rod to where it fits easily onto the turbine housing, than remove it and turn it in 3 or 4 turns in and fit it back onto the turbine housing. To save you some time, the way i usually do it is i remove the intake pipe/aux fan and than loosen the bolts where the WG mounts to the turbo so you can move it around a little,loosen the lock nut on the arm and set zero preload holding it flush to the turbo with your hand, then turn the top of the rod in 3 or 4 turns, tighten the lock nut and put the arm on the WG, than tighten the bolts where it mounts back up, and replace the pin.
Old Mar 2, 2006 | 01:51 PM
  #110
That is correct. The shorter rod also adds a bunch of pre-load to the wastegate (keeps it shut). Just be careful and make sure that your mechanical boost pressure (0'd out boost table) isn't too high since the new wastegate setting will be the lowest boost pressure you can attain. I'd set it to 20-22psi and then use the boost map in the XEDE to dial things up from there. But since you are already running so much boost as shown in your dyno graphs, I don't see the purpose of this excercise. Maybe Dave Buschur can explain it to me. Dave?
Shiv
Old Mar 4, 2006 | 08:39 AM
  #111
Cloud's Avatar
I'm also skeptical about the power of the 20G.
If you look at this thread
https://www.evolutionm.net/forums/sh...4&page=1&pp=15
4TUN8's sig says "The REAL 20g /////// 396awhp 343ft-lbs"
A couple of posts down, Blue Evo 8's sig says
"TurboTrix tuned, Stock 05 Turbo,
***380.47 AWHP, 409.17 TQ***"
Im not sure of either of their mods, I ASSUME, on the sameTurboTrix dyno.
I'd rather have the stock 05 turbo with his numbers then the REAL 20g with 60 less tq. Maybe Blue Evo 8 was running race gas? But the tq seems pretty low in comparison to the hp for the 20g. Just my thoughts.
Old Mar 4, 2006 | 08:46 AM
  #112
David Buschur's Avatar
Shiv,
Ted's dyno chart does show high boost but look at the boost curve and you will agree that is is very odd. The boost comes up, goes flat and then rises. This is not at all normal. As you know, typically, the boost will come up instantly with the spike that they have and then work it's way down to a lower level. The "20g's" and the stock turbos both like a high boost in the low/mid range and then fall off up top. The turbo stays in a very good efficiency range doing this. You can actually find this efficiency range if you move the boost around while you are tuning and watch the AFR's. This is particulary true using the AEM and the boost correct tables.
Ted's problem, from what I can see on his graphs, is the initial boost is not hitting as it should. IF it it, for example, 28 psi right off the the bat and then fell he will then see his torque come back and the power go up.
David Buschur
Old Mar 4, 2006 | 09:03 AM
  #113
Cloud's Avatar
Originally Posted by davidbuschur
Shiv,
David Buschur
Dave, do you have any dyno numbers with your 20G? Does your 20G not have the tq problem? Trying to see if there is a good "middle ground" between my stock IX and Shiv's stage II.
Old Mar 4, 2006 | 09:47 AM
  #114
Dyno4mance's Avatar
Shiv,
David Buschur
Hi David
I am not trying to be argumentative, but Ted's car did not seem to get any stronger no matter what boost pressure was used....here I have overlayed a previous run from the same session when we used about 2 psi more and it is clear no gains were made...It has been suggested that Ted has an older 6 bladed compressor wheel and this is the reason for the turbos poor performance ....is this the case in your opinion?
Attached Thumbnails how does Shiv feel about the 20GIX turbo-file0050.jpg   how does Shiv feel about the 20GIX turbo-file0051.jpg
Old Mar 4, 2006 | 10:35 AM
  #115
Take a look at the boost line on that car. It is not right, that is my point. Lay the stock turbo graph across that boost graph and I think you will find the stock turbo'd graph has more of a peak in the boost rather than that flat line you see pictured there. That is why the turbo looks like the wastegate is not adjusted to make the turbo "hit".
My RS has no torque problem As a matter of fact on our dyno the car just put down 410 whp and 450 ft lbs.
It will be run on a Dynojet on Tuesday to get some higher numbers
David Buschur
Old Mar 4, 2006 | 10:42 AM
  #116
Cloud's Avatar
David Buschur
Is your RS using your 20G? Also is the 410/450 on your mustang dyno?
Old Mar 4, 2006 | 10:46 AM
  #117
Yes, the RS is using our EVO9-20G. Yes, those numbers are on OUR AWD MD.
David Buschur
Old Mar 4, 2006 | 10:56 AM
  #118
jj_008's Avatar
If both turbos are running the same pressure, then why doesn't the 20g make more power? I don't see why the wastegate would need to be adjusted either. It seems like its hitting 26-27psi and holding it for ~2000rpm before it starts tapering.
I have upgraded 2 turbos. Both have made more power at the same psi just bolting them on and adjusting the AFR's. I wonder if TedB has a defective turbo.
Old Mar 4, 2006 | 10:58 AM
  #119
Erik@MIL.SPEC's Avatar
You need to research more. 4TUN8's numbers are on PUMP. I am sure the 380 is not on straight 93.
  #120
Cloud's Avatar
Sup Jermey, how's the beast holding up? It could be a bad turbo because BR's 20GIX is making much more power and a lot more tq then Teds...
