Isn't That Lean?
Old Aug 8, 2006 | 12:17 AM
  #256
RazorLab's Avatar
Really depends on when he went WOT. Also 23psi for 400rpm isn't much of concern, but those AFRS are.
At least from what I could unscramble from that Matrix recreation.
Old Aug 8, 2006 | 12:20 AM
  #257
Spec'd's Avatar
That pull was an off the shelf 91 map on a cool night.
I've since added about a point of fuel.
Old Aug 8, 2006 | 05:49 AM
  #258
jrsimon27's Avatar
Originally Posted by Spec'd
Might it be possible that Shiv is retarding the timing a bit as to
compensate for the leaner a/f ratios ?
Here's something scary from a 91 base map.
FIRST_LOG SATURDAY 08-05-06 3:00 am
Time,AFR,AFR Lambda,EGT,RPM,Boost
00:01.00,12.9,0.0,744.0,3418.0,6.3
00:01.02,12.9,0.0,746.0,3418.0,6.5
00:01.04,12.9,0.0,746.0,3428.0,6.8
00:01.07,12.9,0.0,747.0,3438.0,7.1
00:01.09,12.9,0.0,748.0,3438.0,7.4
00:01.11,12.9,0.0,749.0,3449.0,7.9
00:01.13,13.0,0.0,750.0,3459.0,8.1
00:01.15,12.9,0.0,750.0,3459.0,8.4
00:01.18,12.9,0.0,752.0,3480.0,8.7
00:01.20,12.9,0.0,753.0,3490.0,9.0
00:01.22,12.9,0.0,754.0,3501.0,9.5
00:01.25,12.9,0.0,756.0,3512.0,9.7
00:01.26,12.8,0.0,758.0,3522.0,10.3
00:01.26,12.8,0.0,758.0,3533.0,10.5
00:01.29,12.8,0.0,760.0,3555.0,11.0
00:01.33,12.8,0.0,761.0,3566.0,11.4
00:01.35,12.7,0.0,762.0,3566.0,11.8
00:01.37,12.7,0.0,765.0,3566.0,12.2
00:01.39,12.7,0.0,766.0,3600.0,12.8
00:01.41,12.6,0.0,768.0,3622.0,13.0
00:01.45,12.6,0.0,769.0,3622.0,13.6
00:01.45,12.6,0.0,772.0,3634.0,13.9
00:01.47,12.6,0.0,773.0,3645.0,14.5
00:01.49,12.6,0.0,774.0,3645.0,14.8
00:01.51,12.6,0.0,777.0,3645.0,15.3
00:01.52,12.5,0.0,778.0,3668.0,15.8
00:01.55,12.4,0.0,779.0,3704.0,16.2
00:01.58,12.4,0.0,781.0,3728.0,16.7
00:01.58,12.4,0.0,782.0,3728.0,17.0
00:01.62,12.3,0.0,784.0,3752.0,17.6
00:01.65,12.3,0.0,786.0,3752.0,18.1
00:01.66,12.3,0.0,787.0,3752.0,18.4
00:01.68,12.3,0.0,788.0,3764.0,19.0
00:01.70,12.3,0.0,790.0,3789.0,19.4
00:01.73,12.2,0.0,792.0,3801.0,19.7
00:01.76,12.2,0.0,793.0,3827.0,20.2
00:01.76,12.2,0.0,794.0,3840.0,20.6
00:01.79,12.1,0.0,797.0,3840.0,20.8
00:01.80,12.1,0.0,798.0,3865.0,21.3
00:01.82,12.0,0.0,799.0,3878.0,21.6
00:01.87,11.9,0.0,801.0,3905.0,21.8
00:01.87,11.9,0.0,803.0,3931.0,22.0
00:01.90,11.9,0.0,804.0,3945.0,22.2
00:01.92,11.9,0.0,806.0,3972.0,22.5
00:01.95,11.9,0.0,807.0,3972.0,22.7
00:01.95,11.9,0.0,809.0,3972.0,22.5
00:01.97,11.9,0.0,810.0,4000.0,22.7
00:01.99,11.9,0.0,811.0,4013.0,23.0
00:02.00,11.9,0.0,812.0,4042.0,23.1
00:02.03,11.9,0.0,813.0,4042.0,23.1
00:02.04,11.9,0.0,815.0,4085.0,23.0
00:02.06,12.0,0.0,817.0,4099.0,23.1
00:02.09,12.0,0.0,818.0,4114.0,23.1
00:02.11,12.0,0.0,819.0,4129.0,23.3
00:02.15,12.0,0.0,822.0,4143.0,23.5
00:02.17,12.0,0.0,823.0,4158.0,23.6
00:02.19,12.1,0.0,824.0,4173.0,23.4
00:02.23,12.2,0.0,825.0,4189.0,23.5
00:02.23,12.2,0.0,826.0,4189.0,23.4
00:02.25,12.2,0.0,829.0,4219.0,23.3
00:02.26,12.2,0.0,830.0,4235.0,23.2
00:02.29,12.2,0.0,831.0,4250.0,23.2
00:02.30,12.2,0.0,832.0,4266.0,23.1
00:02.33,12.2,0.0,834.0,4298.0,23.1
00:02.34,12.2,0.0,835.0,4298.0,23.0
00:02.36,12.2,0.0,836.0,4330.0,23.0
00:02.38,12.2,0.0,838.0,4347.0,23.0
00:02.41,12.3,0.0,838.0,4347.0,23.0
00:02.43,12.3,0.0,839.0,4363.0,22.8
00:02.45,12.3,0.0,841.0,4396.0,22.7
00:02.48,12.4,0.0,842.0,4396.0,22.7
00:02.49,12.4,0.0,842.0,4430.0,22.7
00:02.51,12.4,0.0,843.0,4447.0,22.3
00:02.53,12.4,0.0,844.0,4447.0,22.2
00:02.55,12.4,0.0,845.0,4465.0,22.2
00:02.57,12.4,0.0,847.0,4482.0,22.3
00:02.59,12.4,0.0,849.0,4500.0,22.3
00:02.61,12.5,0.0,849.0,4517.0,22.2
00:02.65,12.5,0.0,850.0,4535.0,22.2
00:02.66,12.5,0.0,851.0,4553.0,22.1
00:02.69,12.6,0.0,853.0,4571.0,22.3
00:02.72,12.6,0.0,854.0,4589.0,22.3
00:02.74,12.6,0.0,855.0,4608.0,22.0
00:02.76,12.7,0.0,856.0,4626.0,22.0
00:02.79,12.7,0.0,858.0,4645.0,22.1
00:02.80,12.7,0.0,860.0,4663.0,22.0
00:02.82,12.7,0.0,861.0,4663.0,21.8
00:02.82,12.7,0.0,863.0,4682.0,21.8
00:02.86,12.7,0.0,864.0,4702.0,21.6
00:02.88,12.7,0.0,866.0,4702.0,21.5
00:02.90,12.7,0.0,867.0,4721.0,21.6
00:02.92,12.7,0.0,867.0,4760.0,21.5
00:02.94,12.7,0.0,868.0,4760.0,21.4
00:02.96,12.7,0.0,869.0,4800.0,21.4
00:02.98,12.7,0.0,870.0,4800.0,21.3
00:03.00,12.7,0.0,872.0,4820.0,21.2
00:03.02,12.7,0.0,872.0,4840.0,21.2
00:03.04,12.7,0.0,873.0,4840.0,21.3
00:03.06,12.7,0.0,873.0,4881.0,21.3
00:03.08,12.7,0.0,874.0,4881.0,21.3
00:03.10,12.7,0.0,875.0,4902.0,21.2
00:03.13,12.7,0.0,876.0,4902.0,21.2
00:03.15,12.7,0.0,876.0,4923.0,21.1
00:03.18,12.7,0.0,877.0,4965.0,21.1
00:03.20,12.7,0.0,879.0,4965.0,21.1
00:03.22,12.7,0.0,880.0,4965.0,21.1
00:03.24,12.7,0.0,880.0,4987.0,21.1
00:03.26,12.7,0.0,881.0,4987.0,21.2
00:03.27,12.7,0.0,881.0,5008.0,20.9
00:03.29,12.7,0.0,882.0,5052.0,20.9
00:03.32,12.7,0.0,883.0,5074.0,20.9
00:03.34,12.8,0.0,883.0,5074.0,20.8
00:03.36,12.7,0.0,885.0,5074.0,20.8
00:03.38,12.7,0.0,886.0,5097.0,20.8
00:03.41,12.7,0.0,886.0,5097.0,20.8
00:03.43,12.7,0.0,886.0,5120.0,20.8
00:03.45,12.7,0.0,887.0,5142.0,20.8
00:03.48,12.7,0.0,887.0,5165.0,20.9
00:03.50,12.7,0.0,888.0,5189.0,20.8
00:03.52,12.7,0.0,888.0,5212.0,20.6
00:03.53,12.7,0.0,888.0,5212.0,20.6
00:03.55,12.7,0.0,889.0,5212.0,20.7
00:03.57,12.7,0.0,891.0,5236.0,20.6
00:03.61,12.7,0.0,891.0,5260.0,20.5
00:03.63,12.7,0.0,891.0,5284.0,20.5
00:03.65,12.7,0.0,892.0,5308.0,20.5
00:03.67,12.7,0.0,893.0,5308.0,20.4
00:03.69,12.7,0.0,894.0,5308.0,20.5
00:03.71,12.7,0.0,895.0,5333.0,20.5
00:03.73,12.7,0.0,896.0,5333.0,20.5
00:04.26,12.8,0.0,896.0,5333.0,20.5
00:04.26,12.8,0.0,899.0,5358.0,20.5
00:04.26,12.8,0.0,899.0,5383.0,20.5
00:04.26,12.8,0.0,900.0,5408.0,20.5
00:04.26,12.8,0.0,901.0,5433.0,20.6
00:04.26,12.8,0.0,902.0,5433.0,20.6
00:04.26,12.8,0.0,904.0,5459.0,20.7
00:04.26,12.8,0.0,906.0,5459.0,20.8
00:04.26,12.8,0.0,907.0,5485.0,20.6
00:04.26,12.8,0.0,908.0,5485.0,20.6
00:04.26,12.8,0.0,910.0,5511.0,20.6
00:04.26,12.8,0.0,911.0,5511.0,20.5
00:04.26,12.8,0.0,912.0,5511.0,20.5
00:04.26,12.8,0.0,913.0,5538.0,20.4
00:04.26,12.8,0.0,915.0,5565.0,20.3
00:04.26,12.8,0.0,917.0,5592.0,20.3
00:04.26,12.8,0.0,918.0,5592.0,20.2
00:04.26,12.8,0.0,918.0,5619.0,20.1
00:04.26,12.8,0.0,918.0,5647.0,20.0
00:04.26,12.7,0.0,919.0,5619.0,19.8
00:04.26,12.7,0.0,920.0,5647.0,19.7
00:04.26,12.7,0.0,921.0,5647.0,19.6
00:04.26,12.7,0.0,921.0,5674.0,19.5
00:04.28,12.6,0.0,921.0,5702.0,19.4
00:04.28,12.6,0.0,921.0,5702.0,19.3
00:04.32,12.6,0.0,921.0,5731.0,19.2
00:04.34,12.6,0.0,923.0,5731.0,19.2
00:04.34,12.6,0.0,923.0,5760.0,19.2
00:04.36,12.6,0.0,924.0,5788.0,19.2
00:04.38,12.6,0.0,924.0,5788.0,19.1
00:04.42,12.6,0.0,924.0,5788.0,19.1
00:04.44,12.6,0.0,925.0,5788.0,19.1
00:04.46,12.6,0.0,925.0,5818.0,19.1
00:04.48,12.6,0.0,926.0,5818.0,19.2
00:04.50,12.7,0.0,927.0,5877.0,19.3
00:04.52,12.7,0.0,927.0,5877.0,19.4
00:04.53,12.7,0.0,929.0,5877.0,19.4
00:04.57,12.7,0.0,929.0,5877.0,19.4
00:04.59,12.7,0.0,930.0,5907.0,19.4
00:04.61,12.8,0.0,930.0,5907.0,19.4
00:04.63,12.8,0.0,931.0,5938.0,19.4
00:04.65,12.8,0.0,931.0,5968.0,19.4
00:04.67,12.8,0.0,931.0,6000.0,19.5
00:04.69,12.8,0.0,932.0,6000.0,19.5
00:04.72,12.7,0.0,932.0,5968.0,19.5
00:04.73,12.7,0.0,932.0,6000.0,19.5
00:04.76,12.7,0.0,932.0,6000.0,19.6
00:04.77,12.7,0.0,933.0,6031.0,19.8
00:04.80,12.7,0.0,934.0,6063.0,19.8
00:04.82,12.7,0.0,934.0,6063.0,19.8
00:04.84,12.7,0.0,934.0,6063.0,19.9
00:04.86,12.7,0.0,934.0,6095.0,20.0
00:04.88,12.7,0.0,936.0,6127.0,20.0
00:04.90,12.8,0.0,937.0,6095.0,20.0
00:04.92,12.8,0.0,938.0,6127.0,20.0
00:04.94,12.8,0.0,938.0,6095.0,20.1
00:04.97,12.9,0.0,939.0,6127.0,20.0
00:05.00,12.9,0.0,939.0,6160.0,20.0
00:05.01,12.8,0.0,940.0,6160.0,20.1
00:05.03,12.8,0.0,940.0,6193.0,20.0
00:05.05,12.8,0.0,940.0,6193.0,19.9
00:05.07,12.9,0.0,942.0,6227.0,19.8
00:05.11,12.9,0.0,943.0,6227.0,19.8
00:05.11,12.9,0.0,943.0,6227.0,19.7
00:05.13,12.9,0.0,944.0,6260.0,19.8
00:05.17,12.9,0.0,944.0,6260.0,19.7
00:05.19,12.9,0.0,945.0,6295.0,19.7
00:05.21,12.9,0.0,945.0,6295.0,19.7
00:05.23,12.9,0.0,946.0,6295.0,19.5
00:05.25,12.9,0.0,948.0,6295.0,19.4
00:05.26,12.9,0.0,949.0,6329.0,19.4
00:05.28,13.0,0.0,950.0,6364.0,19.2
00:05.32,13.0,0.0,950.0,6329.0,19.2
00:05.34,13.0,0.0,950.0,6400.0,19.2
00:05.36,12.9,0.0,951.0,6400.0,19.3
00:05.38,12.9,0.0,951.0,6400.0,19.2
00:05.40,12.9,0.0,951.0,6435.0,19.1
00:05.42,12.9,0.0,951.0,6435.0,19.1
00:05.44,12.9,0.0,952.0,6435.0,19.1
00:05.46,12.9,0.0,953.0,6435.0,19.2
00:05.48,13.0,0.0,955.0,6471.0,19.3
00:05.52,13.0,0.0,957.0,6471.0,19.4
00:05.53,13.0,0.0,958.0,6508.0,19.4
00:05.55,13.0,0.0,959.0,6508.0,19.4
00:05.57,13.0,0.0,961.0,6508.0,19.4
00:05.59,13.0,0.0,962.0,6508.0,19.5
00:05.61,13.0,0.0,963.0,6545.0,19.5
00:05.63,13.1,0.0,964.0,6545.0,19.7
00:05.65,13.1,0.0,964.0,6545.0,19.5
00:05.67,13.1,0.0,965.0,6582.0,19.5
00:05.69,13.1,0.0,968.0,6582.0,19.5
00:05.72,13.0,0.0,968.0,6582.0,19.6
00:05.75,13.0,0.0,969.0,6620.0,19.6
00:05.77,13.0,0.0,970.0,6620.0,19.6
00:05.79,13.0,0.0,971.0,6658.0,19.5
00:05.80,13.0,0.0,971.0,6658.0,19.4
00:05.82,13.0,0.0,971.0,6658.0,19.5
00:05.84,13.0,0.0,972.0,6658.0,19.4
00:05.86,13.0,0.0,972.0,6658.0,19.1
00:05.88,13.0,0.0,972.0,6658.0,17.3
00:05.92,13.0,0.0,971.0,6471.0,14.3
00:05.94,12.9,0.0,968.0,6329.0,11.5
00:05.97,12.7,0.0,962.0,6295.0,9.1
00:06.00,12.4,0.0,955.0,6364.0,6.9
00:06.03,12.3,0.0,948.0,6545.0,4.9
00:06.03,12.5,0.0,944.0,6816.0,3.1
00:06.05,12.9,0.0,939.0,6816.0,1.4
00:06.09,13.1,0.0,933.0,6816.0,0.0
00:06.11,13.0,0.0,927.0,6776.0,-2.9
wow friend you are very lean was this a 3erd gear pull???
Old Aug 8, 2006 | 06:41 AM
  #259
nj1266's Avatar
jrs,
Could you please edit your post and remove the long quote? I put Spec'd data in an Excel graph to make it easier to see.
Old Aug 8, 2006 | 06:44 AM
  #260
nj1266's Avatar
Did you back off the boost a bit? Your hitting 23.6 and only tapering to 19 by redline. That MIGHT be too high on 91 pisstane gas.
Old Aug 8, 2006 | 07:44 AM
  #261
Jeff_Jeske's Avatar
At 13:1 AFR you are killing your motor.
Old Aug 8, 2006 | 09:42 AM
  #262
Spec'd's Avatar
I know and I've learned that it's the responsibility of each Evo owner to
monitor and fine tune thier own cars. Just because it's off the shelf doesn't
make it safe.
I love pisstane gas. But seriously, I turned the boost down and enrichend
the mixture.
That looks real good, I need to find my Excel disc.
Originally Posted by jrsimon27
wow friend you are very lean was this a 3rd gear pull???
Yep it was a third gear pull with scary results.
Old Aug 8, 2006 | 11:14 AM
  #263
jrsimon27's Avatar
specd was this the 05map or the 03 map for 91oct and for what kit??
Old Aug 8, 2006 | 06:14 PM
  #264
Spec'd's Avatar
It was a 91 Octane, 05 Map, V330+, Version 3.2.
Old Aug 8, 2006 | 06:33 PM
  #265
Jeff_Jeske's Avatar
It doesn't matter what maps you download they are all very aggressive.
YOU NEED TO MONITOR YOUR OWN AFR WITH A WIDEBAND!!!
Old Aug 10, 2006 | 04:01 PM
  #266
nj1266's Avatar
That is too general a statement. It depends on what you look at. If you look at the AFR by itself, then it does look too lean. But if you look at the timing and the boost, then the settings are tame compared to other tuners out there. I have now done enough logs to see the real timing and boost on the TBE maps.
Below is a table of five boost logs in 3rd gear. These are the boost logs before I changed. These are averages and not max and min. As you can see the boost is very tame. It is stock like boost.
I have also logged enough timing maps to tell that the timing is also tame compared to the timing that I have seen others post on the forums. Below is a typical timing map with the off-the-shelf maps.
I think it is possible with this retarded timing and the tame boost to run an AFR at 12:1. But you would need constant monitering and using all the protective features in the Xede.
Attached Thumbnails Isn't That Lean?-shiv_boost_5.jpg   Isn't That Lean?-93_timing_9.jpg   Isn't That Lean?-93_timing_14.jpg
Old Aug 10, 2006 | 04:10 PM
  #267
RazorLab's Avatar
You should be able to run more timing at 3600 rpm then that. With a very nice torque increase. Espically if your boost is only 20psi.
Old Aug 10, 2006 | 05:01 PM
  #268
nj1266's Avatar
Ahhh...But that defeats the MTBT approach to tuning The whole idea is to retard the timing, back down the boost, and run your AFR at close to optimum burn as possible.
Right now I have upped the boost on my car and I am peaking around 22-23 psi. But this is only because I am running 11.4-11.5:1 AFR. Once I get my EGT gauge installed and logging, I will back down the boost to a max of 21 psi at peak, lean the mix to 12:1 and make sure that the EGTs are around 850*C.
Old Aug 10, 2006 | 05:08 PM
  #269
RazorLab's Avatar
The EGT isn't going to tell you anything about what's going on at torque peak. They don't react fast enough, it's mainly for tuning higher RPM and sustained WOT (track, top speed, etc)
EGT would have to react like a boost gauge to give you any information at torque peak.
I also think you will have a hard time with your EGT readings since you will be running alot less timing then everyone else to be able to run 12:1 which could be raising your EGT's.
If I where you and really wanted to do the 12:1 tune, I would do it on a dyno with det cans.
Old Aug 10, 2006 | 05:43 PM
  #270
TTP Engineering's Avatar
Anyone that makes claims that an AFR and timing is safe and compares it to others internet posted logs is an idiot.
Anyone that does not use the $15 Evoscan program to log actual ECU reported knock counts at a blazing sample rate is pissing in the wind. My .02c to the supertuners.
