Passive Boost Solenoid Emulator help
I received all the bits and pieces for my recently purchase v390 over the last couple weeks, and am getting ready to make the big install tomorrow with the help of a mechanic friend.
2 things I could use help with:
Where do they usually package the "Passive Boost Solenoid Emulator"? I've got everything unpacked and spread out on the floor and am yet to see this little plastic guy. I'm hoping there's some clever, safe spot that I haven't noticed which they usually hide it?
If I don't have one, is this something that can be acquired from say, a NAPA or Pep Boys type store? and what would it be called in laman-speak?
I tried calling Vishnu just now, but the guy that picked up acted weird like he didn't know if he was Vishnu, put me on hold a minute, then said call on a week day :-(
If I have to wait to get one from Vishnu, will it be bad to drive my car with everything installed but the Passive Boost Solenoid Emulator?
TIA for any help,
a n00b
TIA for any help,
a n00b
The Passive Boost Solenoid Emulator is used to bump up the boost 2-3 psi higher to take advantage of your new V390 set up. You'll be fine getting everything installed and then driving it afterward. You just won't boost as high as you should be able to. The only thing that hurts is the fun factor .
Again, thanks for the help
That's good to know! Should I bother to take out "the pill" now? Or just wait until I have the emulator to install? I'm leaning towards leaving the pill in to prevent from boosting too much and having a potentially bad situation (at least I'm thinking that this is how it works).
i recently got the v400 package... my Passive Boost Solenoid Emulator came taped to the top of my ecu when it came back from vishnu....its a very small black plastic tube tapered on both ends and it has a small hole on one side. keep a close eye out for it, it will be very easy to miss!!
Thx again for the feedback guys
The evo 8s no longer need the emulators, only the evo 9s. You need to remove the brass pill in the boost hose by the solenoid still. If you want to see instructions on how to do this, go here...
http://www.vishnutuning.com/evo_install_pill3.htm
Instead of installing the emulator, just plug the hose back onto the solenoid once the brass pill is out.
BTW, very strange about the guy picking up. We aren't open on the weekends, and no one is around the office that I know of.
Thanks for clearing this up for me; we wound up taking the pill out and the cars feels reeeeeeally nice. What a difference... the thing kicks harder than my old WRX did with $10k worth of mods.
I called the number on the bottom of your site, (925) 648-7863 as 12:31PM (west coast time). Is that the correct number?
jpierson77
13
Sep 1, 2009 10:51 AM
LaXGSR
Jun 8, 2009 12:50 PM
