Yet Another Direct Port Thread
Old Dec 22, 2009 | 08:08 PM
  #46
Jeff H's Avatar
100% meth causes weeping issues with push fittings, even if cut square. I've tried many different types, some are better than others, but it's usually only a matter of time. Water seems to be fine with the quick connect fittings. This is why the Aquamist systems have been changed over to 100% compression fittings. Custom peices are being fabricated for the "Y", "T" and other such fittings to complete the product line.
Old Dec 22, 2009 | 10:21 PM
  #47
Labonte MotorSports's Avatar
There are a lot of cheap low cost push connect fittings out there that are not rated for the pressures and will lead to leaks. Problem with compression fittings is if you get the ferrule slightly cocked during assembly it will score or deform and leak.
Had some compression fitting fail on my dishwasher a while back, leaked all over after 2 years of service. Replaced them with push connect fittings and problem solved
I think one thing people are not considering with direct port injection is that you have constant spray. This can result in fluid accumulation on a closed inlet valve. Port Fuel Injectors are timed to the opening of the inlet valves and so should the meth injection if doing this option.
Old Dec 23, 2009 | 06:39 AM
  #48
esevo's Avatar
^^^ BINGO!
This is why smaller jet sizes are better. After market IGNITION systems are a must. With 100% meth corrosion to the valve seat can and will happen much faster.
As for the line, with 100% meth I have seen a need of replacing the line every 6 months or so to help with this weeping issue. A new square cut line wont leak, but over time and heat it can and often does. Just one of the many issues with a 100% meth mixture. More maintenance.
Evan Smith
Old Dec 23, 2009 | 09:18 AM
  #49
mt057's Avatar
It's to bad your dishwasher doesn't run on methanol. It would seem that push style fittings need to be installed correctly to not have issues as well...I guess I will keep everyone posted on how long they last.
I have not even thought meth accumulation on a closed valve. Do you feel that it would not be an issue normally?, if a system was oversized?
Old Dec 23, 2009 | 09:53 AM
  #50
Ev0ikon's Avatar
I think push connect is better if there isn't much vibration like this application in cars.
I am looking to change all mine to compression fitting.s
Old Jan 5, 2010 | 11:49 AM
  #51
1fastevo99's Avatar
quick connect is definitely better. once that ferrule crushes it's on the line for good. only way to fix a leak is to cut it off and install another ferrule.
Old Jan 5, 2010 | 12:02 PM
  #52
Richard L's Avatar
There are basically two types of compression fittings:
One uses a ferrule and the other uses a "squeeze action" between a hosetail and nut. The ferrule type is quite an old design in the pneumatic industry.
Old Jan 5, 2010 | 12:09 PM
  #53
1fastevo99's Avatar
the hosetail type that i've used have also crushed and locked onto the tubing. maybe i'm stronger than i thought.
Old Jan 5, 2010 | 12:29 PM
  #54
Richard L's Avatar
You must be Mr ironman!
Here is what they look like:
Old Jan 6, 2010 | 12:10 PM
  #55
1fastevo99's Avatar
lol i must be thinking of something else. nm.
Old Jan 6, 2010 | 12:23 PM
  #56
Richard L's Avatar
must be the type with ferrule?
Old Feb 26, 2010 | 06:17 PM
  #57
JHowerton@Aquamist's Avatar
To update an old thread, here are the production pieces on their way across the pond.
Attached Thumbnails Yet Another Direct Port Thread-manifold.jpg   Yet Another Direct Port Thread-manifold2.jpg
Old Mar 3, 2010 | 08:58 PM
  #58
mt057's Avatar
Wow, the finished product looks great! About how much are they going for?
Any updates on the direct port setup?
bilt2run
15
Apr 29, 2015 03:02 PM
peanutcracker1
Aug 11, 2014 06:44 AM
rcheung
Dec 12, 2012 03:14 AM
MacGyverGT
Jul 26, 2012 11:48 AM
tlsole
11
Apr 15, 2011 09:17 AM
