Utah Evos
Im going to have to get you to help me GEAR with that patch, I want to do it bad, just still am not 100 percent sure about doing somethings. Once I see it or have someone walk me thought it its all easy and I am sure I could but I dont want to mess anything up.
You have to download one of the tephra patched ROMs & load it into the ECU
Check this thread...
https://www.evolutionm.net/forums/ec...d-v5-10-a.html
gear I will send you a few logs I have run over the last couple days let you take a look at them and such. pm me your e-mail and I will get them over to you. So far things look good. Little knock in places but not really at all. I know u were saying would need to work on the knock sensor adjustments because its a no balance shaft 2.3L and what. Lap top dings at 3 counts of knock and it happens very little.
Yes sir, I just tested the patch for the '05 cars, There is also one for the evo9's as well. I think it is still untested, but based on the one I just tested it should work well.
I'll find out what the plans are exactly and see what kind of parking we'll be using. I'll call you if I should change my mind, that way we could use it as an anti-theft.
I used the Valet at Huka bar before and was like don't even try to go anywhere with my car it wont go over 3,000rpms
I was on the old *** tephra patch forever until you helped me out and got me on the new
thx againThat map I sent you already has it yo...well the older non alt-map switching
since I can buy/resell/install aquamist and your good with all the ecu boost wiring etc..
Or "I" mode. Loser
You valeted your car? I valeted the Porsche at the Mariott downtown when I went with my ex on our two-year anniversary. Every time we got it back it smelled like clutch
That is and will always be the only time I valet a manual car. Hell, I insist on watching the idiots at automatic car washes pull it in and out. Most of them are stupid kids who don't know what they're doing. Unless it is extremely difficult to park my car normally and walk, I will never valet. And thankfully that occasion hasn't ever happened. At least never enough that the cost of valet parking is worth it.... The valet at Gateway would be nice, but it is usually like 7 bucks! Which is why you can usually find really nice cars parked there
