Utah Evos
Old Mar 1, 2005 | 09:35 AM
  #2611
jid2's Avatar
Jake,
Try and get your stuff as soon as possible. The gauge and fuel pump are SUPER easy. The boost control is the hardest. It would be good to have it done by friday so you aren't rushing saturday.
Old Mar 1, 2005 | 12:31 PM
  #2612
vtsnake's Avatar
Old Mar 1, 2005 | 12:55 PM
  #2613
scott88vr6's Avatar
Were ****ed now!
Old Mar 1, 2005 | 12:59 PM
  #2614
vtsnake's Avatar
Originally Posted by scott88vr6
Were ****ed now!
yeah. we'd be better off if they showed 100% chance of snow.
btw, if it does snow, i'm gonna slash all of your tires scott and guys from idaho. last weekend was the weekend I wanted to do the tune. yep and it was 50+ degrees and no clouds in the sky.
Old Mar 1, 2005 | 01:14 PM
  #2615
UT_Evo's Avatar
I have the gauge sitting here now, it's one like Zach's CF one it's currently reading -2psi, but Scott said that usually goes away when you start the car and turn it off again... The fuel pump is suppossed to be here Thursday or Friday, so I'm crossing my fingers for Thursday, I told the guy I needed it ASAP... The K&N I'm still pretty sure I can handle myself, but it should be here by Friday... I hope... and then Al is bringing the MBCs
Old Mar 1, 2005 | 01:35 PM
  #2616
jid2's Avatar
Boy, install that gauge. There are instructions in the how-to section.
Old Mar 1, 2005 | 01:58 PM
  #2617
UT_Evo's Avatar
I'll break it!!! Ok, maybe I'll try, after guitar so I have like 4 hours...
Old Mar 1, 2005 | 02:09 PM
  #2618
UT_Evo's Avatar
fuse tap, drilling the firewall, and cutting vacuum lines? I don't even know where the vacuum lines are Instructions in the how-to section.. I want instructions that say:
"open box"
"plug it in"
"turn it on"
Old Mar 1, 2005 | 02:12 PM
  #2619
scott88vr6's Avatar
There is a hole already in the firewall over by the glove box
Old Mar 1, 2005 | 02:20 PM
  #2620
bullfrg's Avatar
It is so easy Jake, just give it a try. Your car likes it when you put your hands on it
Old Mar 1, 2005 | 03:55 PM
  #2621
UT_Evo's Avatar
OVER BY THE GLOVE BOX??? how long of ooo, I already have to run the hose that far anyway, just on the other side... that could work... now all I need is the extension of the electrical stuff, a T-Fitting, a 1/8 connector, and a guide to where to cut the vacuum line... and like 10 hours of work time Oh yeah, and that fuse thing again... what's that called Scott?
Old Mar 1, 2005 | 04:01 PM
  #2622
UT_Evo's Avatar
This thing has a plastic hose that came with it, do I need a rubber one, or will this work as long as I have a 1/8' connector for it to the T-Fitting?
Old Mar 1, 2005 | 04:02 PM
  #2623
UT_Evo's Avatar
And we're all sure the -2 psi it's reading right now is gonna be okay?
Old Mar 1, 2005 | 04:07 PM
  #2624
UT_Evo's Avatar
Duh, I need like everything to install this... I need a self-tapping screw for the ground wire... I'm gonna need to sodder or crimp and electrical tape, I guess just electrical tape might work, two wires together to extend the wire for the power... and in the end, it won't work...
Old Mar 1, 2005 | 04:48 PM
  #2625
UT_Evo's Avatar
ok ok, after shopping, I now think I have most of what I need... I still need a way to ground the grounding wire... and I'm not sure what gauge wire the wire on the uh gauge is... and what size vacuum T do I need for our lines?
