Utah Evos
Old Jul 17, 2006 | 07:36 PM
  #8236
jid2's Avatar
801-dill-weed.
I'm from Seattle, so is Sunne - it's just time to go home. I've got a job up there and Sunne is looking to work for the Sonics.
Old Jul 17, 2006 | 11:47 PM
  #8237
UT_Evo's Avatar
So no more free days for you at the track?
I'd take the intercooler, if it wasn't 400 dollars at the same time I want cams that are the same price... Call the suby guys from that meet... they thought that it was the leet roxorz.
Old Jul 19, 2006 | 02:06 PM
  #8238
slcEvo8's Avatar
Registered User
So does any one know if there is a oem boost controller or something like that? IN certain gears at around 55-6600 rpm theres a wierd air/venting sound and the car seems to loose boost a sort of slows a little through the top of the gear, its not a BOV i know that but it seems like its a boost silonoid or something, any one care to help me out?? The car is totaly stock.....and the dealer i bought it from said the first owner had some sort of boost controller put in but for the life of me i cant find one any where on the car!!!
I live in midvale (72nd and 20th E) if any slc evo heads wants to take her for a spin with me and help me figure it out....id be willing to pay for help too.
preston
Old Jul 19, 2006 | 03:14 PM
  #8239
jcnel_evo8's Avatar
I'd start with the easy solution and make sure your boost system is nice and tight. Second I'd make sure your boost recirculation valve is ok.
Stock, there is a definate flat spot up top as the turbo is 'told' to stop making power there, but where its starting at 55-6600 rpm that seems a little low. The flat spot seems to start at about 6500rpm on an '03. If I remember, Mitsu programmed the '05s to not drop the boost so they would get higher "horsepower" numbers. So yes, on your '05 you may have a problem.
Other than that, I'm not quite sure if you have enough information to for somebody to say "ah hah!"
Any knowledgable '05ers around?
~j.
Old Jul 19, 2006 | 05:23 PM
  #8240
slcEvo8's Avatar
Registered User
me and my buddy just did a full on boost leak test all the way through and she held really nicely....its just a quick little wooosh sound for like a second and then just goes away, it sounds and FEELS like something some where is venting some boost pressure when it builds to a certain point.....very mysterious!!
^^ and by boost recirculation valve you mean Blow off valve right?
Old Jul 19, 2006 | 09:37 PM
  #8241
UT_Evo's Avatar
Maybe the boost solenoid is bad like it was in my car, you should just buy a MBC and boost gauge and set it up that way. Also make sure it isn't an intercooler hose.
Old Jul 20, 2006 | 09:38 AM
  #8242
jcnel_evo8's Avatar
EVOs have a valve that "blows off" into the intake of the turbo. Typically Blow off valves refer to Vent to Atmosphere (VTA). EVOs are not that way. A stock(ish) EVO setup measures the air before it makes it to the turbo, and in order not to run extremely rich after a throttle lift (plus some other things) they vent the boost to the front of the compressor. Most people refer to this valve as a recirculation valve.
The question of the day is, is the woosh followed by a 1sec. drop in power output?
~j.
Old Jul 20, 2006 | 01:47 PM
  #8243
bullfrg's Avatar
My car is officially totaled now. I am now waiting for the financial evaluation of my car to get this thing settled and find another car. Not sure if I should just buy Scotts car or an Evo 9 or something completely different, trying to evaluate my options but limited because I do not know what I will be settling for.
Old Jul 20, 2006 | 03:42 PM
  #8244
scott88vr6's Avatar
I think you should buy mine, not that I am biased in anyway
Old Jul 20, 2006 | 04:51 PM
  #8245
jwhy's Avatar
scott88 sent you a pm about your car.
Old Jul 20, 2006 | 07:57 PM
  #8246
MSM_S2K's Avatar
Sorry about your car.
I wouldn't buy Scott's. He kept it far too clean and pampered it too much ... now it's a car only suitable for a wussy.
Old Jul 20, 2006 | 10:17 PM
  #8247
bullfrg's Avatar
Yeah and there is no carpet in my garage
Old Jul 21, 2006 | 09:56 AM
  #8248
scott88vr6's Avatar
I'll even throw in the carpet
Old Jul 21, 2006 | 04:35 PM
  #8249
vtsnake's Avatar
mike... how was skip barber? i didn't get a chance to come over there and say hi. oh well, you suck anyway.
good job today jake! he was the fastest out there in his group in the last session. btw, daddy big bucks, jakey poo needs new tires! better pull out the credit card!
and while i'm at it, ben you suck too! hurry up and get home! i don't have all day!
Old Jul 21, 2006 | 09:15 PM
  #8250
MSM_S2K's Avatar
First day of the Skip Barber school was a BLAST! The Formula Dodge is a lot of fun to drive ... I think I need a 1400 lbs car! Rachel will need a car for high school soon .... I wonder if she will prefer the red or the yellow?
