Utah Evos
Old Mar 31, 2007 | 10:42 AM
  #10231
wesside's Avatar
Originally Posted by MSM_S2K
To Mr. Fick and Mr. Vesko for their help today!
Damn I bet your car is a monster on the track
Old Mar 31, 2007 | 07:50 PM
  #10232
eficker's Avatar
No problem. Hopefully you were able to get running today and turn some laps.
Originally Posted by DJ Brett B
Awesome! Yeah, I would like to see what kind of power I'm making for sure! I'll definately post the butt-dyno results and hopefully I can get a real dyno to post some numbers eventually too- I have a Works p2e brain flash, so my boost is set at 21-22psi currently on a conservative tune- BUT I plan on switching to a Profec b-II when I install my aquamist HFS-5 I just ordered... that may take a little bit but with about 27psi I will be REAL stoked to see some numbers!
For MMP I would run 19psi max, with NO timing and LOTS of fuel. No boost FTW! The fastest evo guys there run about 17psi (or stock everything). Most of their cars run Tein super racings and stock sways. Boost != speed.
21-22 psi is anything but conservative on pump gas w/o h2o or alky. Its on the ragged edge of the knock threshold.
Old Mar 31, 2007 | 07:58 PM
  #10233
MSM_S2K's Avatar
The race Evos are only running 17 PSI?
Yes, Vesko got it fixed by about 11 AM. I was out turning laps after lunch.
Old Mar 31, 2007 | 08:13 PM
  #10234
eficker's Avatar
Thats so sweet. Hopefully the temp fix keeps you out there all day tomorrow too!
Lara's black car is running 17, the rest are bone stock powertrain (at least the ones setup by our favorite bulgarian). Soon to be ficker flashed...LOL!
Old Mar 31, 2007 | 09:12 PM
  #10235
UT_Evo's Avatar
This is 17 and holding to redline right? The way I understood it (and it may have been wrong) is that the main problem with 21-22 is if you have it hold, whereas mine tapers to 16-19 around redline. Heck, that's how Christian explained it to me when he was talking about an EBC in my car cuz he said maybe just 18 psi and I was confused and he said it would hold to redline and that the higher psi aren't safe at the higher rpms.
Old Mar 31, 2007 | 11:13 PM
  #10236
VIIImylunch's Avatar
what kind of heat issues are you having?
Old Apr 1, 2007 | 05:31 AM
  #10237
evodrivesme's Avatar
hey im about to move out to utah slc or pc area i think im going to be looking for a job, im about to finish school and im taking engine theory and engine building along with tuning. I was woundering if you guys could name off some shops in the slc area for me that i could get in contact with to send some resumes to thanks guys! oh and hope to see you all on the road soon!
Old Apr 1, 2007 | 07:29 AM
  #10238
gear head's Avatar
Where in PA are you from?
Old Apr 1, 2007 | 08:10 AM
  #10239
eficker's Avatar
The stock turbo will never hold 20+psi to redline. If it were going to, it would do so with an MBC, but as we all know it does not. Mine runs up to about 19, then back down to 17ish. Anyone that says their stock setup holds 20 to redline is lying.
High psi at high rpms isn't necessarily a bad thing (but is harder on the motor), but above 21 at any rpm is reaching the limits of pump gas.
Mitsubishi sized our turbos so they would taper off at higher rpm, probably on purpose. I mean if you are unable to run max boost at redline, that will eliminate some warranty claims (not that they honor them anyway!).
Old Apr 1, 2007 | 09:08 AM
  #10240
I am from the Latrobe, Pittsburgh area.
Old Apr 1, 2007 | 10:01 AM
  #10241
UT_Evo's Avatar
COBB is your best bet evodrivesme
And "temp" is temporary not temperature Brandon
Ah, I always wondered how mitsu set it up to taper, so the turbo is just too small?
Old Apr 1, 2007 | 01:10 PM
  #10242
eficker's Avatar
Yeah, sorry, temporary, not temperature. VTECH FTW!!
Well, that depends on how you look at it. The turbo is perfect size for mitsu and their goals (imo). Its too small for flowing the air needed to keep 20psi to redline if that is your point of view. Its also great sized for spool up and mid-range power, which is great for the kind of racing we do.
I might go a touch larger, like the FP or some variant of the 20g, but thats big enough for me. I dont want to loose any area under the power curve.
Old Apr 1, 2007 | 02:28 PM
  #10243
you know you want a 42r for all those freeway pulls you do every friday and saturday night.
oh and mike besides your temporary problems, have you had any issues with heat? I am paranoid about catching my car on fire.
Old Apr 1, 2007 | 02:43 PM
  #10244
UT_Evo's Avatar
I didn't mean too small for what we use it for, I just meant the main cause of the taper is too small of a turbo, not a BOV, or tune, or some other thing like many others seem to believe. I wouldn't go bigger than a 20g either, midrange ftw (hence the S1s instead of some crazy 280s), and I'm still leaning towards just a TME 6.5.
Maybe you shouldn't let Joe work on it anymore then eh Brandon?
Old Apr 1, 2007 | 10:01 PM
  #10245
yeah but when you are running as much VTECH as I am. Things will catch on fire.
