Utah Evos
Old Apr 2, 2007 | 06:56 AM
  #10246
eficker's Avatar
Originally Posted by UT_Evo
I didn't mean too small for what we use it for, I just meant the main cause of the taper is too small of a turbo, not a BOV, or tune, or some other thing like many others seem to believe. I wouldn't go bigger than a 20g either, midrange ftw (hence the S1s instead of some crazy 280s), and I'm still leaning towards just a TME 6.5.
Maybe you shouldn't let Joe work on it anymore then eh Brandon?
Whats up with the tme 6.5? I haven't read much about that.
Originally Posted by VIIImylunch
yeah but when you are running as much VTECH as I am. Things will catch on fire.
Dooood, with the sick s2k vtech, it is just too much powa, you will blow your rear diff fo sho.
Where do you think it will catch fire? MSM cut some tasteful holes on the side of the hood over the exhaust mani that look pretty good, and evacuate heat.
Old Apr 2, 2007 | 07:07 AM
  #10247
DJ Brett B's Avatar
Anyone on here interested in a brand new Aquamist HFS-5 kit with DDS3 gauge? Its brand new in box and sells for $850... I will sell for $800 and do it for local pick-up here in SLC... I am sad to have to sell it since it just showed up today, but my clutch blew up over the weekend and I wont have money for a new one unless I sacrifice my kit
Here is some more info on it:
https://www.evolutionm.net/forums/sh...light=aquamist
I also posted it in the for sale section along with my used K&N panel filter (used for 5000 miles, hoping to get $50 OBO for that) so if you or anyone you know is interested please feel free to PM me or call Brett @ 801-856-4256- thanks!
Brett Baker
Old Apr 2, 2007 | 07:53 AM
  #10248
UT_Evo's Avatar
Direct bolt-on swap just like the 20g and others, it is what Ray had in his car, spooled up INSANELY fast and just held boost a bit better than the stock one, really the 20g-9 and the FP Green may be the better choices now but they're both slightly larger than stock. Don't think its any bigger (except the hotside) than our 16gs but it just has things like titanium ball-bearings better turbine blades and a polished housing... But with the 20g and the FP Green it is a hard comparison, they can all be had for right around 1k and they're all bolt on swaps instead of hard to install complete turbo-kits.
Old Apr 2, 2007 | 07:59 AM
  #10249
Kodiak's Avatar
Congrats to MSM_2K for winning the pole yesterday @ MMP.. To bad he did'nt race though (Ran out of Brake Pads?). Laura set a new track record in the TORQ Evo(Vesko's) by 2 seconds. Would have like to have seen her and MSM go @ it.
Old Apr 2, 2007 | 08:04 AM
  #10250
UT_Evo's Avatar
Battery... uh... issues.
Anyone know what time Solid opens?
Old Apr 2, 2007 | 11:01 AM
  #10251
MSM_S2K's Avatar
Thanks Mr. Bear. I appreciate your help with the car. The list of issues and hassles for the weekend is a LONG one. All preventable had I had a shop working on the car that paid attention to the obvious stuff.
It was frustrating to watch the race from the hot pits. I think it would have been a very exciting race. Not sure if I could have kept first on the start against the Evo. Previous day during practice starts, the yellow Evo pulled on my pretty hard down the front straight; though it had the pole position or I might have been able to take the first turn. A second start on Sat against the yellow Evo, I got a very good start by anticipating the green and took first going into turn one.
My qualifying time for pole was a 1:41.xx. That was my only clean lap during qualifying because, well, I spun in turn one on the first lap under green (d'OH) and then spent the almost all of the qualifying session getting out of traffic. On Sat I had 3 laps at sub 1:39 ... good enough for the record had it been in the race.
The S2K feels great. Quite a few nuasance issues that need to be addressed, but I'm pleased with the setup choices.
To Utah Imports. Please disregard recommendations I previously made. It's a good group of guys; but at the end of the day they seem unwilling or incapable of paying attention to simple details ... or using a torque wrench.
Issues:
1. Significant focus of 4 months of winter projects was prepping car to pass SCCA tech. Car failed due to simple issues. Most frustrating was an expired harness. Vesko came through for me, giving me a harness he had around the shop. Mr FickerFLASH himself was kind enough to do the install for me.
There was another issue with a need to have a bulkhead between driver and rubber hoses running to gas tank. Less obvious; though not the deal breaker. Again, Vesko came through with some aluminum tape that satisified tech for this event.
2. Silcone tube connecting the turbo to the intercooler was directly touching the exhausting manifold. Vesko spotted it with his first glance at the motor. A quarter sized hole had already burned all the way through the tube. Vesko came through again and offered to fix it temporarily for me so I could run on Sat & Sun. He had the car ready to go for me by 11 AM on Sat. Exceptional customer service considering he discovered the issue at about 11 PM on Fri.
3. No heat shield between the turbo/exhaust manifold and the battery. The battery melted and stopped working. When I asked Utah Imports why they didn't put the heatshield back in, the response was it didn't fit. You think they might just have fabricated it or something else or at least told me. I'm the mechanical idiot ... that's why I had them do all the work in the first place.
4. EGT sensor was hanging loose with a nice hole where it should be installed empty.
I should not have trusted someone else to pay attention and ensure the basics where covered. It's extremely frustrating.
to Vesko and FickerFLASH for the help.
Old Apr 2, 2007 | 01:12 PM
  #10252
SolidAutoEvo's Avatar
We open at 9 a.m.
Old Apr 2, 2007 | 01:40 PM
  #10253
bryant's Avatar
Where is the camera crew? I wanna see pictures of you guys out at the track.
Old Apr 2, 2007 | 01:44 PM
  #10254
UT_Evo's Avatar
Originally Posted by SolidAutoEvo
We open at 9 a.m.
and your email system is broken? Did you guys work at Modern for too long? Oh well, I'll give you a call in a few I suppose.
Old Apr 2, 2007 | 01:47 PM
  #10255
MSM_S2K's Avatar
LOL ... I've got video of me spinning in front of about 20 cars at turn 1 on the first green lap of qualifying. When I get back home this week I'll post it.
Watching the video over and over again ... I can't figure out why the car spun? It doesn't even look like I'm changing steering input ... than wham-o ... I'm facing the wrong way with a gaggle of Miata's, bimmers and a couple of Evos headed straight for me.
Fortunately, I did the "... if you spin, both fit in" ... so I was able to quickly get the car down to the inside out of the way.
Who owns Solid?
Old Apr 2, 2007 | 02:00 PM
  #10256
jid2's Avatar
Sounds like they just put parts together, kinda, and didn't bother to think how things would actually work in a race envirnoment. The IC pipe on the exhaust and no heat shield for the battery is classic. "It fits...sweet, nice turbo install (high 5's)".
Old Apr 2, 2007 | 02:05 PM
  #10257
UT_Evo's Avatar
Both feet in, nothing fits in
Dunno who the owner is but Noah and Paul are the head honchos.
Old Apr 2, 2007 | 06:05 PM
  #10258
eficker's Avatar
Congrats to MSM and Lara. They are both fast drivers. Vesko has done some amazing things with the suspension on that Torq evo. Just in case anyone is wondering, its running Tein Super Racings and a completley stock engine bay (okay, intake and exhaust), ftw!
Although, it hasn't been FickerFlashed yet (tomorrow it will be), so expect it to be a few seconds faster next race!
Old Apr 2, 2007 | 06:16 PM
  #10259
eficker's Avatar
You ARE the camera crew! Where you at?
Old Apr 2, 2007 | 07:25 PM
  #10260
MSM_S2K's Avatar
WOW ... a FlickerFLASH is worth a few seconds? Sign me up for 3!
Lara raced ... I watched.
Looking at the work work-in-process on Lara's original Evo she's going to be un-touchable for my VTECH 'mobile.
