04-06 Ralliart Engine/Drivetrain (no forced induction)
Lancer Engine Damper
Old Dec 6, 2005 | 11:24 AM
  #196
matute's Avatar
GR8
Old Dec 6, 2005 | 05:27 PM
  #197
SpEeD_dEmOn's Avatar
That sounds good, let us all know how it feels cause i dont know if i can bear that engine jerk any longer. although its winter and no running the car until maybe spring. i just would like to know its there for when i take my car out of hibernation. whats the price on it also? By the way good job Rob on the project i always new you was going to make it happen.
Old Dec 7, 2005 | 12:07 AM
  #198
chowetime's Avatar
Excellent work there on the dampener but I have one or two questions and please don't take offense on this... just trying to understand how and why, firstly I see that you have it mounted on the opposite side of were the gearbox and drive side is - I know that on that side there is not much space and clearance over the air box but would the best results be found on that side as it would stop a lot of the torque and lashing that the engine does from this side or is it because the design of the dampener is to only slow it down rather than stopping it ...
Old Dec 7, 2005 | 08:42 AM
  #199
DangerousDan's Avatar
chowetime- I am not saying I know the answer, just that with the motor mounts where they are it would be difficult for the drivetrain to twist the motor. With this damper it would stop nearly all of the roll created under hard accel and decel. If you want to stop all engine movement you have to go to harder mounts.
Old Dec 7, 2005 | 08:47 AM
  #200
PR_Mivec's Avatar
im in the works of making the front mount in metal... ill let you know how that goes
Old Dec 7, 2005 | 08:12 PM
  #201
robert5995's Avatar
My Main Man in Denver, Ralliart50 and I will do a test fit this weekend, as long as it gets above -5F, which it is right now. After that it's more vendor work. Patience!
Chowetime - I haven't posted any pics yet, so you must be thinking of someone else. However, mine is in the same place. It's by far the easiest place to limit engine motion, and D Dan is right in that if you want to totally eliminate engine motion, you have to go to the way hard mounts. I'm thinking that you all don't want the vibration of hard mounts, but would love it if a tangible amount of the engine motion were eliminated. I saw on the dyno one day that engine lash is contributed to by all the engine mounts, so tying down just one won't eminate all engine lash, but certainly should put a significant dent in it.
- Rob@Zakleecorp.com
Old Dec 7, 2005 | 11:18 PM
  #202
chowetime's Avatar
I have had harder mounts before and did not enjoy them at all ... but yeah Isee what you are saying now that if you remove all movement then general driving will not be as nice etc and the diffulculty of applying a different style is not going to be easy
Old Dec 8, 2005 | 01:17 PM
  #203
Ralliart50's Avatar
Amen!!!! It's not to fun when you walk outside and you snot instantly freezes so you can't breathe through your nose!!!! Sorry, just thought I would through that in. It's supposed to be 45 on Saturday so we should be good to go!!!
Old Dec 10, 2005 | 03:23 PM
  #204
Ralliart50's Avatar
Ok, Rob and I got the test fit done on the damper. He has to make a few changes to it to make it a perfect fit. He has to extend the bottom bracket and cut off a part of it where it mounts so that you only have to take two of your motor mount bolts out to put it on instead of all three. He also has to re-angle the top bracket so that it is a little more aligned with the bottom one and then notch a small part of it out so that it doesn't block or interfer with the low-side A/C line fitting. Other than those small changes it should be ready to go. Rob will have to give a time frame right now as to when we can expect a final product but I do know that I will be meeting with him for another fit before he starts selling them. I'll keep you all up to date when I hear anything new.
Old Dec 10, 2005 | 03:50 PM
  #205
robert5995's Avatar
Kyle -
Thanks!
Old Dec 11, 2005 | 03:20 AM
  #206
amg_dragon's Avatar
Is this mounting to the motor mount points or the strut tower? I only ask because most of them seem to mount to the strut tower and head. Thanks for being the test mule! That's one of the clearest, most concise reports I've heard from a beta tester!
Old Dec 11, 2005 | 05:30 AM
  #207
robert5995's Avatar
Dragon -
Although all three engine mounts contribute to engine lash, the passenger side engine mount is by far the easiest place to mount brackets, and what's more the strut tower is right there. Brackets have to be designed and fabricated for both, as well as a link between them that provides anchoring and damping.
Old Dec 11, 2005 | 08:43 AM
  #208
amg_dragon's Avatar
Cool. I just wanted to make sure that it really was the engine mount. It sounds like the best place (like you said) after all. It sounds like it'll be in production before too much longer. I can't wait, well okay I can wait untill it's above 40 degrees. Thanks for the update!
Old Dec 12, 2005 | 01:40 PM
  #209
Ralliart50's Avatar
No problem. I just try to make it as clear as I can so that everyone knows where things stand with a new part that they are waiting on. I just hope Rob gets some buyers on this part because he is putting a lot of time into this so that everything is perfect and the install is easy. This will work great for people who want to eliminate most of their drive train lash but don't want to go through the hassle of replacing the motor mounts. Plus this won't cause nearly as much vibration at idle as the hard motor mounts do.
Old Dec 12, 2005 | 01:42 PM
  #210
Ralliart50's Avatar
Kyle -
Thanks!
No problem Rob. Thanks for getting more quality parts on the market for us.
