04-06 Ralliart Engine/Drivetrain (no forced induction)
Lancer Engine Damper
Old Aug 10, 2005 | 12:18 PM
  #61
ambystom01's Avatar
Originally Posted by robert5995
Amby - I'll make sure it does.
- Rob@Zaklee
Wicked, I'm sure there will be a bunch more interested when it comes out as well.
Old Aug 10, 2005 | 12:27 PM
  #62
ProjectR#69's Avatar
yeah, PM me when you get it finished I would really be interested in this!!!
Old Aug 10, 2005 | 01:00 PM
  #63
PR_Mivec's Avatar
Originally Posted by WoRkZ
BTW Rob, why does it have to be mounted on the side of the engine? Wouldn't that induce a twisting motion to the block? Can't it be attached to the middle of the engine? I can't see where though, but you're the engineering guru.
and why on just one side and not sold as a pair.. on on the side on in the middle or this is just overkill?
Old Aug 10, 2005 | 01:08 PM
  #64
WoRkZ's Avatar
Exclamation
Ooops... I feel like I just oppenned Pandora's box or something.
Old Aug 10, 2005 | 01:24 PM
  #65
PR_Mivec's Avatar
^^nah
the stiffer the better....
Old Aug 10, 2005 | 04:22 PM
  #66
DiamondWhite's Avatar
HAHAHA thats what she said.
Old Aug 10, 2005 | 05:36 PM
  #67
AdamRA's Avatar
Thats a good question I don't think it supplies the engine with enough damping to cause a harsh twisting of the engine. Remember it's still mounted.
Companies like Ingals and J's Racing have been using these for quite a while now.
Almost always just one side of the engine.
Old Aug 10, 2005 | 07:09 PM
  #68
robert5995's Avatar
Lancer Drivetrain Damper
WoRkZ -
The determinant for locating where the damper goes is where under the hood is a solid piece of real estate to mount the non-engine end to. On the Evo, it's the shock tower, which would be the preferred location for any car.
The reason that one works just fine is that at least with my shock absorber, the resistive force isn't enough to do anything crazy like twist the block. Blocks are designed to be way stiff in torsion. The way things are now, the tranny is trying to twist the engine off the engine mount on the other end of the motor, so actually the damper will modulate that effect some.
- Rob@Zaklee
Old Aug 10, 2005 | 07:13 PM
  #69
WoRkZ's Avatar
Thumbs up
Thanks for the info... it all makes more sense now!
Old Aug 10, 2005 | 09:30 PM
  #70
PR_Mivec's Avatar
right
Old Aug 10, 2005 | 09:50 PM
  #71
Azure's Avatar
I SO hope this gets taken care of, as I'm hugely interested! (for the 2.4, not the 2.0).
Old Aug 10, 2005 | 10:05 PM
  #72
AdamRA's Avatar
Yes, I'm in for this I bought the weapon r one a long time ago but obviously it didn't fit
Old Aug 11, 2005 | 07:00 AM
  #73
otter's Avatar
EvoM Administrator
I can be a guinea pig if you need one, drop me a PM when you're ready to go
Old Aug 11, 2005 | 08:05 AM
  #74
RalliartCA's Avatar
I would also be very interested in this. Keep us posted.
Old Aug 11, 2005 | 08:15 AM
  #75
Daddymac's Avatar
Ditto!
