2013 STU Discussion!
Old Jun 26, 2013 | 06:35 AM
  #181
piknockout's Avatar
Originally Posted by Bassicfun
Look at the registration Ryan, you and I are the only EVOs currently... 10 in STU though.. heavy hitter with Luster showing up.. we'll see though he dropped out of the Toledo Pro.. tsk tsk.. :P
Looks like Shane just signed up for Wilmington as well, this will be the largest STU crew we've run with this year at a National event. Now to decide if I want to keep running the old Rivals or run one of the new sets. Hmm...
Who dropped out of Toledo? Wasn't me unless someone accidentally knocked me off the list.
Originally Posted by Construct
I ordered my BFG Rivals back in February, and they finally arrived last Monday. I'm excited to try them out.
I'm coming from Z1 Star Specs. Should I expect to make any big changes in tire pressure, car setup, or driving style?
With the Rival being a bit softer than the Z1, you might be able to run a touch more rebound perhaps to help get a little better response out of the car. Otherwise I haven't had to change anything really, ended up running similar tire pressures as well compared to the Z1. Just be prepared that the tire reacts a little later, but allows you to be a bit more aggressive with the car. First few runs will kind of suck until you can get the mold release off, but afterwards you should be alright.
Old Jun 26, 2013 | 07:23 AM
  #182
Bassicfun's Avatar
strange i have looked at the list about once a week just tracking friends and others, you weren't showing at one point.. sure are there now... too bad STU is tiny for this event.
Old Jun 26, 2013 | 07:38 AM
  #183
piknockout's Avatar
Yeah, looks like it's probably bump class for us combined with HS and BS, although I'm assuming that Barbato is on the wait list to co-drive with Justin Lau, so they might be okay. Pretty much sucks, I thought STU would represent in Ohio similar to Wilmington, but oh well. Seems like STU has *just* made a class at every Pro this year. Might be time to move to STR...
If we could get one more in class, I have a buddy who's going who would be willing to co-drive my car. Not sure I want to have to do that again, but I guess we'll see. Maybe I'll pick up a co-drive with someone else and just ride out/back with them to save money. That might be a really good option.
Old Jun 26, 2013 | 07:41 AM
  #184
Bassicfun's Avatar
Toledo surface is very unfriendly to STU pax... even Pallotta had his fill of that garbage. :P
If we are likely not to make a class.. I may save my weekend dollars for something else, or to ensure I head out to Lincoln this year. was looking forward to running vs. you and know what gap i have to the top talent, but bump class.. humbug.
Old Jun 26, 2013 | 11:36 AM
  #185
piknockout's Avatar
That's what Wilmington will be used for...besides, Shane is the droid you're looking for.
Old Jun 26, 2013 | 12:09 PM
  #186
Bassicfun's Avatar
Droid!? Oh... now I see why the wheels are green
Old Jun 26, 2013 | 01:42 PM
  #187
qucifer's Avatar
Barbato isn't going to Toledo.
Justin just signed up in BS as a placeholder until he finds another ride.
There are only three of us left in BS after that. Definitely going to bump.
-Bryan
Old Jun 27, 2013 | 07:03 AM
  #188
piknockout's Avatar
So bump would be effectively BS/STU. Talked to Aaron Shoe and he mentioned that the two HS boys were probably going to save Hoosiers and run RTF.
Old Jun 27, 2013 | 07:26 AM
  #189
Bassicfun's Avatar
rather it be with an RT class
Old Jun 27, 2013 | 09:39 AM
  #190
DougM's Avatar
I had quotes of $400 for labor from a few places that were well-respected locally. so I figure $1000 all in labor, parts, fluids, etc, every 3yrs or so, if I continue to have good luck with the car.
with two drivers I'm calculating to get about a year and a half, so maybe 3 years is reasonable to assume.... with four drivers... it wasn't good
Old Jun 27, 2013 | 09:50 AM
  #191
DougM's Avatar
same for us, we just got them mounted up last night, and paired with a new set of Z2's. We have a weekend of casual testing planned in Packwood this weekend, along with some on-site BBQ'ing (+)
Old Jul 17, 2013 | 08:00 PM
  #192
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
Hey, STU hasn't been screwed with in a while.
http://scca.cdn.racersites.com/prod/...%20Minutes.pdf
CHANGE PROPOSALS
Street Touring
#10437 Cars Move to STU Proposal Package
The STAC has provided the following package of proposed changes to introduce additional cars into the STU class. One
portion of this group of changes would involve adding unclassed cars to STU (if the package is recommended); the other portion would involve moving a group of currently-classed cars into STU.
Proposed new listings added into STU (via Tech Bulletin):
Corvette (1997-2004) (Non-Z06, Non-FRC)
Genesis V6
Infiniti G37
Subaru BRZ/STI
Proposed 2014 re-classing (via listing change proposals, in conjunction with the above):
Ford Mustang (N/A)
Chevrolet Camaro (N/A)
Pontiac Firebird (N/A)
350Z non-NISMO
Infiniti G35
Genesis (2.0L Turbo) (2010-13)
Per the STAC: In response to the declining participation in STU, the STAC is recommending a package of RWD cars be
moved into the class. The STAC believes this will provide a much wider variety of competitive options and encourage a
renewed interest in the class.
The cars chosen include previously unclassed vehicles, as well as a few currently classed in STX/STR. One thing they all
have in common is the ability, and need, to fit more tire than allowed in the lower classes. Additionally, this proposal deals
with numerous requests for the STAC to allow additional tire width for the RWD pony cars (solid axle RWD) currently in
ST. The 350Z has also been reclassed in response to member request.
The C5 Corvette may appear out of place at first glance, but the STAC has done extensive analysis and does not believe it to
have a competitive advantage due to its poor gearing. The C5 Corvette puts far less power to the ground at typical autocross
speeds than other vehicles in STU. Further, the C5 is a very inexpensive car and the ST allowances provide the ability to
correct its poor seating and create a competitive, fun, dual purpose vehicle.
Tire width limitations remain the same at this time.
I don't even know where to start. I'll be doing some research and will post the letter when I'm done.
edit: I don't get why they couldn't just list them all in one batch, but someone high up has clarified elsewhere that nothing would take effect til 2014 even for the not previously classed cars.
Old Jul 29, 2013 | 05:37 AM
  #193
Bassicfun's Avatar
Yeah, I have no use for them changing a class that WORKS with a bigger variety than STC does.. F with that class first, please STAC/SEB!?!?
On a positive note... WILMINGTON!??!?! WOOHOO Will be a blast, can't believe how EVO intensive STU used to be, now we are the serious minority... Ran on the surface saturday, much better than Toledo (I live between the two and will enjoy running both though)... Great grip, smooth, large... only 'issue' will be the employee parking lot is where we will paddock, and the walk/ride to the pad isn't small.. makes Peru seem like it is one continuous lot.
Old Aug 2, 2013 | 11:49 AM
  #194
Butt Dyno's Avatar
Here's my letter. #12038. Please please please write in. At least one STAC member has said they think the C5 is going to be very quick in STU.
This letter is in response to the proposal to add new cars to STU.
I am just focusing on the 350Z / G35, and the C5 Corvette. I think the other cars discussed will not upset any applecarts.
350Z first:
At the Lincoln tour this year, i.e. the surface that matters most, a good driver in a 350Z beat last year's STR national champion by almost seven tenths. Even if you remove the cones, it was still five tenths. If you define "competitive" as "a good driver in a well prepped car has a fair shot at a good finish", that clearly means to me the 350Z is currently "competitive" in STR. One datapoint but a very important one given the caliber of drivers and the surface. Put simply, if people aren't running them in STR despite those results, they won't run them in STU either.
C5 Corvette:
I think the Corvette, when prepped, will be substantially faster than the current STU.
There are only three weaknesses for the Vette in STU that I can see:
* It's wider than the cars in the class right now - about 6" wider than an E36 M3 and 3-4" wider than an Evo
* It might have problems putting power down on street tires
* The STAC has claimed the gearing is not great for autocross
In response:
* Width certainly matters in slaloms, but it matters less in other course elements, and the car has strengths in slaloms that the other cars in the class don't, namely that it is 9-10" shorter than an Evo and 5-6" shorter than an M3 and has better geometry than both
* It will be able to run a lot of wheel. You might be thinking that people have tried to run stock-class Corvettes on street tires and not had good luck putting power down, but those cars are on stock springs - an STU C5 will have a lot of options at their disposal to mitigate this including adding enough spring to keep the other end of the car on the ground, and upgrading the rear diff to something fancy and expensive.
* The Vette makes a lot of torque everywhere, and it will never have any turbo lag like the buggies will. They come stock with 275-40-18s in the rear, and they will almost certainly be running 285-30-18s in STU, which is a substantial shortening that should make the gearing awfully good for autocross.
There are a bunch of advantages though:
* It should have more torque than anything in the class, especially with E85 going away, and it makes that torque at a lower RPM than the boost buggies do
* It will be able to run a ton of wheel, which will mean it can take advantage of 285's in a way that nothing currently competitive in the class can
* They are much lower than anything in the class (ten inches shorter than an Evo 9, 5-6" shorter than an E36 M3)
* They not 60% nose heavy like the buggies
The weight is probably going to work out about the same as the buggies, thought the M3 will still be the lightest competitive car in the class.
What do the boost buggies do better? They put power down better at corner exit, but by the time the wheel is mostly straight again, this advantage will be pretty small.
In my opinion, the BEST case for this proposal is a substantial amount of course dependency because the C5 is so different than the existing cars. The worst case is that the car is in the mix on asphalt and dominates the existing cars on concrete.
Proposal overall
The Fastrack starts with: “ In response to the declining participation in STU...”
I am very curious why STU gets this treatment.
In Lincoln in 2012, STU was one of the biggest open classes (28) only eclipsed by:
SS (41) DS (31) STC (37) STS (39) STX (50) STR (51) ESP (33) CP (39) RTR (36)
I am skimming here, so apologies if I missed one, but my math has STU as the tenth-most popular open class at Nationals last year. Yes, most of its ST* friends are doing better ; yes, the numbers have dropped a bit over the years. But, pre-registration for this year’s nationals:
* STF: 15
* STC: 19
* STS: 19
* STX: 43
* STU: 17
* STR: 43
That’s completely consistent with the other ST classes, except for STR and STX which are obviously huge success stories. It’s cool that those classes are doing well. That doesn’t mean that another 28-car STU field is some sort of failure. It’s not. Remember that last year was the first time a non-buggie had won. That should be and IMHO has been a sign that a non-buggie can get it done.
And as a pre-empt, I know that the west course was very E36 friendly, but Tristan was right in the mix on the east course also. IIRC, he was only 2-3 tenths off the fastest boost buggy time, on a course that was very evenly balanced. And he was a nationals rookie, and I don't think he would contend his car was fully prepped, and I think Heikotter proved that there is still more speed in the E36s as he was faster than Tristan on 1 or both days.
Fastrack continues with “...the ST allowances provide the ability to correct (the C5’s) poor seating and create a competitive, fun, dual purpose vehicle.” The Evo, STi and M3 are all competitive, fun, dual purpose vehicles. Let’s remember that last year, STU had three different cars in the top 3, and four in the top 4 if you count the Evo 8 as a separate vehicle (open front diff and less power than the 9). The boost buggies make fantastic all-year cars that in a way that the C5 never will (in anything other than warm climates). All of those cars are substantially more practical than the two-seat, huge-hood C5 Corvette is.
If we are talking fun, dual purpose vehicles, we currently have TWO classes devoted to 20 year old cars that may or may not have A/C and airbags and sure as heck aren’t family cars (STC, STS). And we have one class devoted to cars that aren’t fun on the street OR much fun for autocross (STF, as demonstrated by the general lack of entries, though nationals pre-reg is not as bad as last year).
In short, I don’t understand why the tenth most popular class at Nationals last year is seemingly getting singled out when it seems to me there are bigger fish to fry in ST*.
Thank you for your time and for your volunteering to serve on the STAC.
Old Aug 2, 2013 | 03:33 PM
  #195
griceiv's Avatar
there is always ASP...
sorry i just had to say it.
