Let's see your fully tuned timing maps
Old Jul 15, 2008 | 09:21 AM
  #391
SPAWN's Avatar
Originally Posted by bas_evo
here is my timing map
this one is for a 03 evo 8 with exhaust, air filter, ams licp, walbro fuel pump
and ebc 25 psi on 93 octane
what do you guys think
i hope you didn't upload the complete Ralliart rom , nice effort though , why did you change the timing between 0% to 40% load this is only idle???
Old Jul 15, 2008 | 10:49 AM
  #392
gsrboi80's Avatar
Sometimes with cams ive seen it necessary for tuners to bump idle timing a little but agreed with first hand experience that too much idle timing will cause a P0300 code
Old Jul 15, 2008 | 10:51 PM
  #393
3star2nr's Avatar
ahh ok So I am understanding it right then basically advance before boost then dial it back as the boost comes up?
Old Jul 24, 2008 | 04:14 PM
  #394
John F's Avatar
My car is a Euro spec Evo 8. Mods are:
AEM intake
APS intercooler
stock turbo with 10.5 housing
Stainless o2 housing
3" TBE with sports cat
around 23psi to 6000rpm then dropping to 20psi.
Tephra V5.1 96530006
99 RON fuel (93 or 94 US octane)
The first map is with GSC S1 cams. I always got inconsistent knock with these cams. I could have a clear run then one with 6 counts then one with 4 counts etc.
My tuner recommended I try good old HKS 272s as he always had consistent results with these. The second map is with the HKS 272s and resulted in a 35 lbft and 20hp increase and never more than the odd 1 or 2 knock counts. Look how much more timing I could run with the HKS cams.
The 3rd map is with the HKS 272s with 50/50 water/meth, 29psi at 4000rpm dropping to 22psi. This gave a further 50lbft and 25hp.
Attached Thumbnails Let's see your fully tuned timing maps-26-t.png   Let's see your fully tuned timing maps-102-2.png   Let's see your fully tuned timing maps-102-4.png
Old Jul 24, 2008 | 06:00 PM
  #395
nothere's Avatar
wow that is a load of timing with 50/50. what system do you inject with and how much?
Old Jul 24, 2008 | 06:35 PM
  #396
RazorLab's Avatar
Well now we know why all the UK guys think they need built motors.
That is a serious arseload of timing, with 29psi even!
Old Jul 24, 2008 | 08:34 PM
  #397
PeteyTurbo's Avatar
Yeah thats pretty crazy lol
Old Jul 25, 2008 | 03:00 AM
  #398
John F's Avatar
I use the AEM water injection kit with 630cc/min nozzle. Here is a dyno graph. I don't know how these numbers would relate to US dynos but power wise, without water injection, my car is about the same as other similarly modified Evo 8s. I don't know of anyone else in the UK using water injection so I can't compare these figures with anyone.
Old Jul 25, 2008 | 04:47 AM
  #399
tkklemann's Avatar
AEM intake
APS intercooler
Why is it you always have some "funki-ness" going on in the 140-180 load column timing? Seems like with the way your map is set up, you would floor it, feel the acceleration rate slow down a bit, then all the sudden take off.
Me personally, in the 50/50 map, I would smooth that out, a lot. Maybe you have it set-up like that on purpose?
Old Jul 25, 2008 | 06:12 AM
  #400
John F's Avatar
I am new to tuning with water/meth but I figure the AEM is a progressive pump system so I can start to increase timing as the water/meth injection rate increases. I think having the standard timing map in the pre 200 load gives the water injection a chance to come on stream when the throttle is floored so helps to reduce the chance of knock. I do see a few oddities in the 140-180 columns now that you have pointed them out. I'll fix them. Thanks.
Old Jul 25, 2008 | 08:56 AM
  #401
honki24's Avatar
I run more cc/min than that and I can't run near that timing... even on 25psi. Not to say that it can't be done... but I'm a bit skeptical.
Here's what I'm going to VIR with tomorrow:
Thats 23psi, 11.2ish AFR, WI, FMIC, I/E/cams. (full mods found on website in sig)
Still workin' on my MBC/GM BCS hybrid. Works nominally so far but this blasted taper is still getting to be too much for me.
I'm having a hard time keeping my 5* timing near peak torque even when I'm seeing no knock so I had to block it a little bit. Whenever I get some time I need to check my timing against a timing light... I can't afford to run 0* or negative timing any more... melting my exhaust system was no fun.
Old Jul 25, 2008 | 10:49 AM
  #402
bigric09's Avatar
your timing in the map you posted is pretty close to what i run on pump at 24 psi
Old Jul 25, 2008 | 12:12 PM
  #403
John F's Avatar
I would be skeptical too but here's the evoscan log from the dyno graph. Not on the log is AFR as we were using the dyno wideband. AFR is 12 from 3500 to redline.
Old Jul 27, 2008 | 04:26 AM
  #404
Oracle1's Avatar
I can believe that! It's the water/methanol allowing you to run that much more timing. I'm running mental timing on pump fuel alone.
Old Jul 29, 2008 | 07:17 AM
  #405
ecuflasher's Avatar
Any big turbo or big cams timing maps?
