Air Filter Shootout Test - Results!
Old Jan 13, 2009 | 07:52 AM
  #196
evane's Avatar
it would be a good idea to test the full intake system, along with the aps cold air intake and the arc intake box
Old Jan 13, 2009 | 08:05 AM
  #197
scheides's Avatar
EvoM Moderator
If you want to send those to us for a test against the current setup, please do. If you want to do the test yourself, please do. If you want to post up ideas that are outside the scope of this test, even though we already said that it is just an air filter test over and over and over and over then please......ugh, nevermind.
Old Jan 13, 2009 | 08:15 AM
  #198
Wicked E's Avatar
Originally Posted by MR Turco
wicked, did you re-oil your perrin filter, i didn't just wondering if most people are.
Negative...
-E
Old Jan 13, 2009 | 09:50 AM
  #199
shadow1's Avatar
If you do not re-oil the foam, the Perrin filter is not going to filter well.
Old Jan 13, 2009 | 09:54 AM
  #200
MR Turco's Avatar
While i don't disagree i have seen no evidence on filtering quality for oiled vs unoiled.
  #201
Wicked E's Avatar
There's enough oil remaining on it to filter. Thank you very much...
-E
Old Jan 13, 2009 | 10:03 AM
  #202
shadow1's Avatar
If the filtered worked well enough unoiled, then Perrin, K&N, etc, would not hassle with oiling their filters.
Old Jan 13, 2009 | 10:08 AM
  #203
MR Turco's Avatar
i guess it is all about your perception of "filters well enough".
I know many domestic guys that run the K&N unoiled as well.
Old Jan 13, 2009 | 11:12 AM
  #204
KazzEvo8's Avatar
Old Jan 13, 2009 | 11:15 AM
  #205
MR Turco's Avatar
Originally Posted by KazzEvo8
Care to comment?
Old Jan 13, 2009 | 02:12 PM
  #206
Kracka's Avatar
I do not suggest running an oiled air filter w/o oil for the sake of degraded filtering ability and increased dust/dirt/sand ingestion. Regarding the Perrin, it definitely comes soaked in oil so there is no harm in removing the excess like I did by blotting with a paper towel. I know CBRD actually sprays the filter down with some Simple Green and then rinses the filters before use. To me this is a bit excessive, but it seems to work well for him. If someone prefers to run a dry air filter, I suggest the Amsoil.
Old Jan 13, 2009 | 02:25 PM
  #207
KazzEvo8's Avatar
Care to comment?
Need I? Running a K&N unoiled? Their filters are certainly not known for their dry performance. They're actually known for excellent performance when wet and somewhat dirty...
Old Jan 13, 2009 | 02:31 PM
  #208
Kracka's Avatar
Not to start an argument here, but K&N air filters really aren't excellent at anything; they are on the low end of the power spectrum and their filtering abilities falls somewhere in the middle. I've run them on a lot of cars with no complaints, but now I just see too many better options.
Old Jan 13, 2009 | 03:06 PM
  #209
shadow1's Avatar
No where on this thread was there a test of filtering ability. I'm not a K&N fan boy but it seems like a lot of folks have jumped to the conclusion that Perrin and Amsoil filter best. Most of the Amsoil claims come from the guy selling them, and even he has not actually published any data on filtering (no bashing intended). I personally am not making any claims as to filtering superiority but I just had to say something about this topic.
Old Jan 13, 2009 | 07:52 PM
  #210
Oil Doc's Avatar
Exactly Correct !
Not only do they need to be oiled to filter at least half-assed, it is not just any oil and a filter oil must be used.
-E
If the filter has been washed, there is not enough oil on it.
It is there engine that is getting sanded.
Saying many do it, certainly doesn't make it right. Many people jump off bridges, doesn't make it right and I for one am not going to follow them.
That is the perfect way to get the proper amount of oil on the filter. Any type of cleaning or using a chemical will dilute the filter oil thus reducing it's efficiency.
Even K&N states that the filters work better the dirtier they get.. So does my fuel filter until it clogs up. For the rest, see S2kracka's post that I copied below.
From AMSOIL Corporate Data
Absolute Efficiency
AMSOIL Ea Air Filters are the most efficient filters available to the car/light truck market. Ea Air Filters’ synthetic nanofiber media removes 5 times more dust than traditional cellulose filter media alone and 50 times more dust than wet gauze filter media. AMSOIL Ea Air Filters have a service life of 100,000 miles or four years, whichever comes first.
Information is also available comparing Bracket Foam Filters and Challenger (K&N) in aviation use... Same medias but I figured some people would say, in a whiney voice, "But that's for a Plaaaane", same same..
I use to work for a company that sold K&N, AEM, RACOR and various other performance filters along with AMSOIL.
I had a chance to go to a several day school at RACOR who builds some of the top filtration systems. Some of RACOR's marine filters are wetted gauze made by K&N and say right on the box, "For Marine Use Only". I had the opportunity to ask some questions so I asked "Why Marine Use Only?" The answer ... "There is virtually no dirt on the water, we just have to worry about the big chunks in the engine compartment and arresting flames"
Doc
