Going turbo but got some questions
Old Apr 15, 2011 | 12:47 AM
  #241
burner67's Avatar
what are you doing for oil feed/return? i scored a oil and water kit for $55 just needed the 3/8npt to 4an fitting for the feed and 1/2 to 5/8 and tube for the return...
otherwise comes with all the other bolts and washers u need!
Old Apr 15, 2011 | 01:03 AM
  #242
burner67's Avatar
actually for the return im going to weld this http://cgi.ebay.com/ebaymotors/10-Mi...ht_2507wt_1165 on my oil pan from the inside. then get a 10an 45 degree female to hose. http://cgi.ebay.com/ebaymotors/ws/eB...#ht_1381wt_939
Old Apr 15, 2011 | 06:47 AM
  #243
HornstarBU's Avatar
people suggest this a lot, and it's such a good alternative to what I and some others did....just threading a barb into the pan. The one concern I have, is that what you linked is steel, and I'm fairly sure the pan is aluminum. On other things, I have tried welding non-like metals, and I never could make it happen with any reliability. You might make sure it will work, or perhaps get an aluminum bung (After you confirm that's what you need...don't take my word as anything but a slight suggestion)
As far as tuning goes, didn't spike say you could flash teh evo rom? Any access to ecuflash via nearby friends to confirm or deny that it works?
Old Apr 15, 2011 | 07:55 AM
  #244
burner67's Avatar
:/ aw man i thought it was for sure steel!! who knows this??!?!?!
Old Apr 15, 2011 | 08:08 AM
  #245
slatermvp's Avatar
I haven't tried it yet. I actually haven't even saved my stock rom yet. I'm hoping I do that this weekend.
Old Apr 15, 2011 | 09:46 AM
  #246
RoadSpike's Avatar
Just stick a magnet on it then and find out if your unsure.
Old Apr 15, 2011 | 10:04 AM
  #247
Green_Bandit's Avatar
If you need an aluminum one go to treadstoneperformance.com
Old Apr 15, 2011 | 01:41 PM
  #248
slatermvp's Avatar
what size hose was it again that is needed for the return and feed?? or does anyone have a link??
Old Apr 15, 2011 | 02:49 PM
  #249
steven121's Avatar
mine is a 10 an line for the return, the feed should be a -4an with a female end
Old Apr 20, 2011 | 09:36 AM
  #250
HornstarBU's Avatar
For the return I used one of these http://www.amazon.com/Earls-984410-A.../dp/B000CN7FLM along with some steel braided 5/8" hose....like this, but not the exact link http://www.merlinmotorsport.co.uk/pr...S&currency=USD
for the feed, I have a ...I think, -4AN Straight 90 Degree Stainless Turbo Oil Line 42", is what my e-mail from them says. so basically, it's a 90 degree on one connector, and straight on the other end. I put the 90 degree on the adaptor used in the hex screw above the oil filter (So if you oil sandwich, you don't really want this 90 degree).
Old Apr 20, 2011 | 10:58 AM
  #251
http://www.treadstoneperformance.com...pply+Feed+Line
Dude I'm telling you. tread stone performance.com. They have everything you need for your oil stuff. Go look at that link for the oil feed.
Old Apr 20, 2011 | 01:50 PM
  #252
syntax182's Avatar
^Damn, they do have everything for the oil lines. Ha ha. Thanks for the link.
Old Apr 20, 2011 | 07:11 PM
  #253
slatermvp's Avatar
awesome link bro. Imma order my stuff from there.
Old Apr 20, 2011 | 07:14 PM
  #254
slatermvp's Avatar
So I went out and tried to read my stock ROM but I was unable. This are what came up:
The ecuflash home page:
after clicking on the read ecu icon:
The folder in ecuflash is set up to read off the mitsubishi/lancer folder in OpenECU where the definition files are saved. User level is set to developer on ecuflash as well.
Is there not a definition file for my ECU, it's a 2005 ES automatic.
Old Apr 21, 2011 | 07:58 PM
  #255
RoadSpike's Avatar
Hmm...
In that first screen shot you will notice that its throwing errors for the file evo7base.xml probably from the lancer folder in rommetadata. While I can't say for sure its possible the program just stopped reading xml's including the read templates folder becuase of these errors.
Copy the evo7base.xml from the evo folder into your lancer one and see if that first screen shot doesn't throw any more errors.
BTW you'll want a copy of my read templates as well to get the whole 512kb rom off your ecu.
https://www.evolutionm.net/forums/at...ancer_auto.zip
I think it puts the wrong flashing method in for some cars but that wont stop it from reading.
If you got trouble with it I can just make a specific OCP method one for it
