Cobb AP: ?s on product, features, and various maps incl Perrin maps go here [merge]
Old Mar 29, 2009 | 07:49 PM
  #256
Mendo's Avatar
Originally Posted by Excalibur
I'm new to the ap, but I was wondering if the ap could control the boost through the oem ecu in the same manner as evoflash?
Also, I work in Abiline which has only 91 octane, but ultimately live (homeowner) in Converse/San Antonio which has 93; do I need 2 different custom tunes or would one suffice?
I live in Lubbock! I am in the same situation, here there is 91oct but when I travel to Houston for the summer, there is 93oct there. But pre-loaded onto the AP there are maps for each stage on both octanes so its an ez switch from one to the other.
About the boost I have no idea, I've only been playing with mine for 1 day hahah. I will say when I tried to monitor my boost pressure, it read 0.0 psi which I know is deff wrong. All the other monitoring things worked fine, just the boost one wasn't working. Maybe some programing issue??
Old Mar 29, 2009 | 07:54 PM
  #257
Excalibur's Avatar
Let me know if you come down to Abiline sometime. I will be ordering my ap soon.
Old Mar 29, 2009 | 08:36 PM
  #258
mrMTB's Avatar
Mendo, the Exxon station at 67th and Frankford has 93 octane. You might also check out Barry's Super Fuels (are they still around) for some 100 octane.
To Excalibur's point, though, if your mods necessitated moving past one of the staged tunes, then yes, you would need to have custom tunes for each grade. If you were going to be within the parameters of a staged tune, then I'd recommend getting the custom tune with 93 octane, and use the out-of-the-box 91 octane tune appropriate to your mods when you are in Abiline.
And yes, the AP can control boost for you- no need to go with a boost controller (just remove the pill for Stage II+).
Old Mar 30, 2009 | 11:04 AM
  #259
Rob@cobbtuning's Avatar
Originally Posted by gullie667
I have an access port and am installing a new map. When reading the map notes it talks about ensuring that the car is within an Air Fuel Ration of +/- .4 of the graph they show.
My question is, what live data output am I looking at for this number? I don't see a specific one for A/F. Do it need to take 2 values and to the math myself?
Thanks!
Gullie
Hi Gullie,
The Evo X does not have a sensor accurate to the level needed for checking the AFR during a WOT pull. As long as your modifications fit within what the map notes specify, your fueling should be spot on.
Let me know if you have any other questions.
Thanks,
Old Mar 30, 2009 | 02:55 PM
  #260
gullie667's Avatar
I have the Ultimate Racing Turbo Back Exhaust w/ the metal high flow cat and the downpipe w/ the O2 housing. That is ok right?
I want to make sure that the O2 housing / Cat that Ultimate Racing is selling is with in the parameters of your Stage 2 93 Octane map.
Here is a link to the O2 Housing:
http://www.ultimate-racing.com/Produ...ousingDP.shtml
Here is a link to the Cat:
http://www.ultimate-racing.com/Produ...at-Metal.shtml
And here is the Cat Back Exhaust:
http://www.ultimate-racing.com/Produ...lCatback.shtml
Old Mar 30, 2009 | 03:45 PM
  #261
Excalibur's Avatar
Thanks.
Old Mar 30, 2009 | 03:57 PM
  #262
goofygrin's Avatar
I've got the ceramic HFC, but otherwise the same exhaust as you. I'm on a custom stage 2 map.
You'll be fine with that exhaust.
Old Mar 30, 2009 | 05:16 PM
  #263
Q15H's Avatar
I noticed what appears to be erratic datalogging of intake cam timing. In the following snippet, intake cam timing varies from +69.38 to -80. That's a LOT of cam movement!
Sec RPM PW Intake CA Exhaust CA
148.55 2676 2.3 67.5 14.38
149.32 2656 1.54 -80 4.38
150.05 2650 1.54 -80 1.25
150.82 2611 1.54 -80 1.25
151.61 2578 1.54 -80 1.25
152.36 2553 1.54 -80 1.25
153.11 2524 1.54 -80 1.25
153.88 2495 1.54 -80 1.25
154.61 2467 1.54 -80 1.25
155.36 2435 1.54 -80 1.25
156.07 2415 1.54 -80 1.25
156.8 2385 2.05 -80 1.88
157.51 2376 2.05 -80 2.5
158.26 2367 2.05 -80 3.12
158.97 2363 2.3 -80 5.62
159.72 2356 2.3 64.38 7.5
160.47 2346 2.3 41.25 8.75
161.2 2343 2.56 18.75 11.25
161.93 1790 3.07 69.38 11.25
162.68 1796 2.82 -65 10
163.41 1786 2.56 -78.75 8.75
164.18 1785 3.33 30.62 8.75
164.93 1782 3.33 30.62 8.75
Old Mar 31, 2009 | 03:07 PM
  #264
qu evox's Avatar
Cobb Economy mode with a drop in filter?
Hey all. Im just wondering if i can swithc to the economy mode even though i have the Works drop in air filter. Let me know what you guys think, if ill throw a code. etc. Thanks.
Old Mar 31, 2009 | 06:15 PM
  #265
amrock88's Avatar
do it...im doin it with a cobb intake and its all good.....
Old Mar 31, 2009 | 07:28 PM
  #266
qu evox's Avatar
sounds good. Im gunna try it out. Hopefully it works.
Old Apr 1, 2009 | 10:29 AM
  #267
lewvsal's Avatar
what kind of mpg are you seeing in economy mode?
Old Apr 2, 2009 | 06:28 AM
  #268
AirRazorDH's Avatar
I'm in Edmonton, AB and looking for an AP. Anybody know of any dealers close by that I can just run down and pick one up at or am I gonna have to order it online?
Old Apr 2, 2009 | 05:00 PM
  #269
iriejigga's Avatar
I just got my Cobb AP and love it! I have a K&N drop-in filter, Cobb downpipe and High Flow Cat, I'm running the stage2 +sf for 93 octane, since I'm down in south fla. I got all my stuff thru RaminiSports, when Carlos dyno the car it was making 320awhp and 297torque . I thought that was pretty impressive!
Oh! I also got the u0184 code (when read it says airbag), everyone here so far says it has to do with communication with the OEM radio? I have a pioneer dvd and alpine amp, but oem sub in the car, so could be from that, anyway super happy. I was going to go with the Vishnu reflash, but couldn't deal with the down time.
Cobb, RaminiSports & Carlos Ramirez
Old Apr 2, 2009 | 08:03 PM
  #270
lowkey's Avatar
Registered User
Originally Posted by iriejigga
I also got the U0184 code (when read it says airbag)
Cobb indicated they disable/suspend communication on the CAN-bus to other components during the flash, resulting in this type of code. They have a fix, although I'm not sure if it will fix all CAN codes across the board or if it's specific to certain codes. This code was not listed, so hopefully they will get around to this one too, if the fix is code specific.
