Cobb AP for 2011 Evo X?
Old Feb 26, 2012 | 08:24 AM
  #1156
4b11ftw's Avatar
what should i run with just a k&n panel filter and turbosmart bov?
Old Feb 26, 2012 | 11:18 AM
  #1157
EvoX777's Avatar
Originally Posted by rodeopunk_je87
Did you bother to look at the second link? This one?
http://www.mediafire.com/?eg6qbap1koxc3
These are all stage 1
Those are for the mr I have a gsr I have known all those were made by Bakanuchi quite some time ago. Cobb has failed to support stage 1 gsr intake specific maps if they have released something let me know but what your showing me is for an Mr.
Old Feb 26, 2012 | 04:29 PM
  #1158
MisterHappy's Avatar
Here are the maps for the GSR http://www.mediafire.com/?5bupofiny2ug7
Old Feb 27, 2012 | 08:11 AM
  #1159
ericjai113's Avatar
If you look at the file name of each map in the Stage 1 folder, they are all for MR, no support for GSR....
Old Feb 27, 2012 | 01:38 PM
  #1160
GSXRiderK6's Avatar
Running an Ultimate Racing Dual CBE w/resonated TP and Spectre (for now...) air filter on stock MAF housing on my '11 GSR. I am currently using a Stage 1 91oct OTS map...I want to run the Stage 2 91 oct OTS, but not sure if I should and if so, should I remove boost pill?
Old Feb 27, 2012 | 02:59 PM
  #1161
user 629782012's Avatar
the instructions for stage two cobb maps show the removal of the top side boost pill .
but as far as i'm aware it's also based on other factors.. altitude is one. but i'm not sure what the others are.
Old Feb 27, 2012 | 04:13 PM
  #1162
GSXRiderK6's Avatar
I see, that's what I thought. Since there are no out-of-beta Stage 2 maps, there are no real instructions to follow other than for the previous EvoX's. I'll stick with Stage 1 for now, unless someone chimes in to say that running Stage 2 is fine with or without the boost pill. Thanks.
Old Feb 27, 2012 | 05:06 PM
  #1163
I am currently running the stage 2 WITH the pill still in. Hitting around 26 lbs of boost and zero problems.
Old Feb 27, 2012 | 06:50 PM
  #1164
BakaUnchi's Avatar
Stage 1 maps are for stage 1 cars for 2011+
Old Feb 28, 2012 | 07:25 PM
  #1165
mr2evo8's Avatar
Any info on 2011 gsr map stage 2 like an aem intake or an e85 map?
Old Mar 4, 2012 | 03:51 PM
  #1166
laxplayer14's Avatar
any suggestions on which beta map to run with an ets intake? this is ridiculous tho at how long its taking cobb, just saying
Old Mar 4, 2012 | 10:36 PM
  #1167
BakaUnchi's Avatar
I don't see OpenEcu else with "OTS" ETS maps for 2011 either ..... just sayin
Old Mar 5, 2012 | 12:49 AM
  #1168
mirkendargen's Avatar
They also don't market their product with the statement "comes with pre-installed maps that are optimized for common performance modifications". I own an AP and like it, but be fair now.
Old Mar 5, 2012 | 01:23 AM
  #1169
BakaUnchi's Avatar
How "common" is an ETS intake?
As ive probably said about 40 times so far in this thread
use the Cosworth maps i posted it should supply enough fuel. Then do a datalog (using the methods i posted here ) and put it in that thread ill try to take a look and see where its at
Old Mar 5, 2012 | 03:33 AM
  #1170
so because one company, that doesnt even advertise ots maps like mirkendargen said, doesnt have ots maps make it an excuse for cobb to not have it either? i dont think so. especially on a model thats been out for over a year now. i bought the ap for my 2010 a few years back after reading how easy it is to use, why cant it be the same for my 2011? ets is a common brand for an evo x, just like ams and cosworth
