Cobb AP for 2011 Evo X?
Old Jan 15, 2012 | 01:23 PM
  #1126
Oh My Evo X's Avatar
And that's stock turbo? If it is, turn that down a bit haha. That's ridiculously high for the mods that you have, at least IMO. And I know a majority of the people who run the stage 2 maps right from cobb, But honestly I'd take it to a shop and have them tune it for you with the AP. They can solve a lot of things, and more then likely your problem that you are facing.
Old Jan 15, 2012 | 04:19 PM
  #1127
sonic_evox's Avatar
I want to use my accessport already!! but i need my test pipe, the one i received didn't fit properly, cant wait to go stage 2
Old Jan 15, 2012 | 04:36 PM
  #1128
What test pipe did you get?? ^^^
Old Jan 15, 2012 | 04:57 PM
  #1129
sonic_evox's Avatar
I got a tomioka test pipe the thing is that the stock cat has a curve to it, i didnt think it would affect the exhaust until i installed it, since it didnt have a curve the test pipe hit the aluminium under the car and made my exhaust hit my rear bumper, i need one like this ATP test pipe
http://www.importimageracing.com/atp...for-evo-x.html
and i cant go stage 1 since i drive a 2011 gsr and i got an injen intake and exhaust
Old Jan 16, 2012 | 11:15 PM
  #1130
digitalskillz's Avatar
I hate to make this thread any longer with such a simple question, but couldn't find the answer by searching the forums.
Will the 2011 GSR stage 2 beta maps work with a 2012 GSR's ECU? I kmow there's speculation that the 2012 ECU *should* be the same, but I want to know definitively.
Thanks!
Old Jan 17, 2012 | 06:12 AM
  #1131
Kracka's Avatar
Give it a try and let us know
Old Jan 17, 2012 | 09:10 AM
  #1132
Thanks!
I don't see why not. If you don't want to try it contact COBB. They might be in development with a new firmware release for 2012's, but I don't think there is a big difference from 2011 to 2012
Old Jan 17, 2012 | 05:51 PM
  #1133
rodeopunk_je87's Avatar
Thanks!
There is no way in hell I would ever do this without talking to Cobb first. There are just so many variables that even a small change can produce catastrophic results.
Old Jan 22, 2012 | 05:49 AM
  #1134
laxplayer14's Avatar
so im no longer in my 2010 ob x and now in a 2011 gg gsr, i read up to page 20 in this forums and it was still waiting to be in release (2011 ots maps) and i simply can't read anymore haha have the maps been release yet? im assuming so and if they are where can i find them cause they aren't showing on cobb's website. i still havent hooked my ap up to my comp yet tho so it may just be there and havent seen it just yet.
Old Jan 22, 2012 | 05:58 AM
  #1135
Grimshaw's Avatar
Originally Posted by MisterHappy
Having a few issues with my 2011 GSR. Have had the cobb on for a while, and the other day running on the highway i was attempting to see what my boost was hitting at (just got a new boost gauge so i was playing around with it). I took off out of first pretty quickly and ran throught the gears, i turned onto the high way in 3rd, pushed the pedal to the floor, and everything is going smoothly, i then hit 4th pushed it back to floor watched the boost and it hit 28 psi... at this time the car sorta jerked like it was losing alot of power. Would this a slipping clutch or something to do with my tune. It doesn't do this often and only once in a while when i am running it hard in 4th or 5th.
I think it is a fuel cut issue. It seems more common on the MR's since the gears change so fast at WOT. I ended up switching to Stage 2 and it seemed a lot smoother. BTW I'm stock except Cosworth air filter and it seems to work great. Boost hitting 25psi. I haven't been experiencing any problems with it.
Old Jan 22, 2012 | 09:26 AM
  #1136
MisterHappy's Avatar
Thanks i might give that a try, are the stage 2 maps out for the 2011s from cobb, or did you get it from a outside source?
Old Jan 28, 2012 | 08:33 PM
  #1137
aaronshuevox's Avatar
Ok, realy trying not to ask the same questions over and over but I want to get this right. Will be getting a pro tune in may but untill then I've been using the maps that baka very very kindly made available. Have a turbo back (test pipe) and a k&n typhoon cold air intake on my 11 gsr. For the last month or two I've been using the cosworth stage 2 93 and it seems ok but I just realized its for a panel filter. Cant get the normal stage 2 to download onto my ap or I'd run it and put the stock intake back on. What should I do? Is the injen stage 2 93 closer to what Im telling my MAF? Sorry, Im learning. What map is best for me? And the 2011gsr injen 93ptm. map doesnt say stage 2 but I assume it is? Thanks
Old Feb 8, 2012 | 11:27 AM
  #1138
EvoX777's Avatar
When are the 2011 stage 1 intake maps coming out someone said they were suppose to be out late december early january ? I just hope we dont have to wait another year.
Old Feb 8, 2012 | 01:36 PM
  #1139
jthompson8692's Avatar
Originally Posted by RAPTR
2011 MR here and on the Stage 1 v301 ACN and I get 23.9mpg driving to work.
Is there a noticeable increase in power?
Old Feb 8, 2012 | 01:38 PM
  #1140
Really tempted to try this as I just ordered the AP. But worries as stage 2 should not work with a stock car.
