Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
what's the best and quickest way to launch an evo from rest?
Old Jan 25, 2007 | 11:56 AM
w00tev0's Avatar
i keep hearing different opinions on how to best launch my nearly stock evo from rest. do you drop the clutch at 4000, 4500? is that too hard on the clutch / transmission? how much can the stock clutch take?
Old Jan 25, 2007 | 12:00 PM
sonicnofadz's Avatar
flash your ecu to enable a two step launch limiter. Set it around 5000-6000 rpms. Floor the gas pedal, bounce of rev limiter, dump clutch. Have fun breaking things!
Old Jan 25, 2007 | 12:02 PM
Chemwarrior's Avatar
That's messed up. Why do you want to set the guy up for failure like that?
Old Jan 25, 2007 | 12:05 PM
Warrtalon's Avatar
Probably because he didn't bother to search or get any real info before posting as a newbie without going to the drag racing forum or newbie forum, which is against several rules.
Old Jan 25, 2007 | 12:08 PM
Srt-4 Turbo 7's Avatar
I am a newb just like yourself "wootevo" but searching is your friend. Get a tune and set your 2-step to 5,500-5,800 rpms whatever you choose. Floor is and bounce off of your 2 step. Give the clutch a QUICK slip and then hold on. Do NOT just dump the clutch, unless you have a s**t load of money sitting on the side to replace your transfer case and clutch all the time. Go to the bottom of the forums and click on the "Drag Racing" section. Do a search there and you will find all of your answers.
Old Jan 25, 2007 | 12:09 PM
KOEvo's Avatar
Or because it isn't setting him up for failure at all, because that IS the right way to launch an Evo. If you're going to "actually" launch an AWD car, things will break...
Old Jan 25, 2007 | 12:16 PM
That was kind of my point KOEvo. Why would a noob (yes I realize I am one as well) want to launch his car without properly researching the correct way of doing it. I wasn't questioning your methodology.
Old Jan 25, 2007 | 12:18 PM
ThunderOZ's Avatar
Have you checked the Driving Techniques section. Or the Drag section? There's a lot of helpful info there...
Old Jan 25, 2007 | 12:19 PM
w00tev0's Avatar
got it. noob mistake, my bad. i'll check out those other sections and do this so called "searching" next time.
Old Jan 25, 2007 | 12:22 PM
bluebyu36's Avatar
arrest that man !!!!!he did not search!!!!!
Old Jan 25, 2007 | 12:23 PM
ThunderOZ's Avatar
He hasn't been here long... He'll learn.
Old Jan 25, 2007 | 12:24 PM
Smike's Avatar
Do not drop the clutch...and please search...
Advance search quick slip and Warrtalon, Clay has a nice write up and video on how to launch w/o the 2step
When/if you get flashed for the 2step, here is my 2step tech (as a bit more in it but the 2step is in it):
https://www.evolutionm.net/forums/sh...75&postcount=4
Old Jan 25, 2007 | 12:57 PM
fastgt350's Avatar
nice
Old Jan 25, 2007 | 01:06 PM
In my opinion this is the quickest way to launch a near-stock Evo. It just happens to be the most damaging for your drivetrain =)
Old Jan 27, 2007 | 03:37 AM
moreryce's Avatar
if ur gonna drag u should get a AWD launch club card from ACT clutches.. lol
TRDHarrier
Driving Techniques
171
Dec 28, 2015 12:55 PM
CarPhoto.net
Driving Techniques
122
Aug 12, 2011 12:15 PM
shunderwunder
Jan 17, 2008 03:23 PM
Derek888
Nov 5, 2004 07:45 PM
alright by me
Oct 21, 2004 07:30 PM
