Throttle hang and the Idle Stepper Table
Old Apr 14, 2008 | 06:03 AM
  #271
gogolio's Avatar
Thanks guys. Everything seems great now. Appreciate it.
Old May 17, 2008 | 09:19 PM
  #272
biggie5252's Avatar
I tried this to fix my throttle hang issue, but now my car won't idle at all. I start it, it'll idle about 1800rpm for about 10 seconds, then drop down to about 1400 for a few seconds then to about 1000rpm for a little bit, then it drops down to about 300 and I have to give it gas. My oil temp gauge at the time said 67 degrees, so I imagine water temp wasn't too far from that. After I drive for a while it's fine. My ISCV initial step position AC off - neutral table was modified by a mail in flash (assuming for cams) which was when my throttle hang became noticeable/a pain in the ***. I changed that back to stock at the same time I did the stepper table mod. Since then I have changed the ISCV table back to what it was before with no luck, so I'm thinking it has something to do with the stepper table. Any ideas? Thanks.
Old May 17, 2008 | 11:59 PM
  #273
tephra's Avatar
any your idle stepper table looks like ...?
Old May 18, 2008 | 09:12 AM
  #274
biggie5252's Avatar
Like this. . .Thank you.
Attached Thumbnails Throttle hang and the Idle Stepper Table-idlestepper.jpg
Old May 18, 2008 | 04:46 PM
  #275
tephra's Avatar
so you only changed the 41deg column... which means your cold start shouldn't be affected..
Old May 18, 2008 | 05:46 PM
  #276
biggie5252's Avatar
Yes, that's what I thought. The only time it will maintain idle is if it's hot. Even if I run into the gas station real quick it won't idle after I come back. I've changed everything back to stock for now. . .it was nice not having the the throttle hang. I have the extra throttle control tables if that has any effect. I tried raising those, but it only changed the intial idle after start, but it still did everything else the same.
Old May 18, 2008 | 10:26 PM
  #277
fostytou's Avatar
EvoM Community Team
Make sure your table is defined properly... I think it was defined wrong in v1.34.1435 for my rom
Old May 19, 2008 | 05:27 AM
  #278
biggie5252's Avatar
what's the correct definition cuz that's the version I'm running. Thanks.
Old May 19, 2008 | 06:04 AM
  #279
tephra's Avatar
perhaps start a new thread and post your problem + what happened when you changed things..
perhaps this is masking another problem?
Old May 26, 2008 | 05:23 PM
  #280
shadow1's Avatar
Why does the stock 05 Idle Stepper Look-up table have all the same values going across the x-axis? It makes the table kinda pointless....
Old May 26, 2008 | 06:11 PM
  #281
tephra's Avatar
post an image of what you mean.
Old May 26, 2008 | 06:44 PM
  #282
shadow1's Avatar
Originally Posted by Max Power
In the last table, all the values are the same going across the x-axis regardless of TPS (which actually should be coolant temp).
Old May 26, 2008 | 07:09 PM
  #283
Jersey Dino's Avatar
i know this may be a bit redundant, and while I am learning more about this as knowledgeable people post up, can anyone say if the fix is in? EVO IX hangs like a mother when you drop a gear or let of any higher then 3-3500k... who has actually solved their issue and what year and ROM does your car have?
Old May 26, 2008 | 07:43 PM
  #284
biggie5252's Avatar
Seems to me everyone else got there's to work except for me.
Old May 26, 2008 | 08:02 PM
  #285
dam dude sorry to hear that. I guess I will just have to get a minute and try it out...I will probably get to it on wednesday. I will let you konw how I make out. hey biggie what mods do you have done?
