Evo IX 2-byte Load & Lean Spool for Dummies
Old Apr 23, 2008 | 10:27 PM
  #196
nonschlont's Avatar
Heres the definition for "2ByteLoad" for 88590015
<table name="2 byte load high bit" address="3EE86" category="Misc" type="1D" level="1" scaling="uint16" />
<table name="2 byte load low bit" address="3EE8A" category="Misc" type="1D" level="1" scaling="uint16" />
when u open up ecuflash (make sure ur in developer mode) and for
2 byte load high bit = 27458
2 byte load low bit = 27459
Old May 4, 2008 | 02:44 PM
  #197
racer135's Avatar
Originally Posted by TouringBubble
Is there some negative effect for disabling lean spool? It would seem that Mitsu wouldn't just put it there for no reason ...
I would also like to know the answer to the question above. I went through the whole thread and no one answered this question.
Old May 8, 2008 | 02:17 PM
  #198
h101171's Avatar
Any experience on EDM 88840013 ROM for address of 2 byte load?
Marcel
Old May 8, 2008 | 02:46 PM
  #199
JoeBee's Avatar
maybe you can update to 88840017 more you can find here:
https://www.evolutionm.net/forums/sh...light=88840017
than you can use this variables:
https://www.evolutionm.net/forums/sh...d.php?t=327185
Old May 8, 2008 | 04:08 PM
  #200
tephra's Avatar
yup update to 17... should be ok
Old May 10, 2008 | 12:20 PM
  #201
rallykid's Avatar
how can I be sure leanspool is dissabled?
Old May 12, 2008 | 04:05 PM
  #202
racer135's Avatar
If I disable the lean spool, does that mean that I will need to redo all the fuel map from 2500 till redline because all the values will now be on the rich side? That also affects the low octane maps?
Does it makes sense to just turn off lean spool past redline so you never hit it and maybe start the turn off on 2000 instead of 2500 and have almost the whole map in disable mode? Will this be easier to tune in the sense that less cells need to be redone?
Old May 13, 2008 | 01:28 PM
  #203
xpro's Avatar
on my car when leanspool is enabled and if i make any changes to fuel map,my afr stays the same and always runs on the lean side,wierd??
But when i disable lean spool my afr changes a lot peak boost around 12 and then tappers to 11.3 at redline,and car seems to run much better and with very little knock,1-2 knock only coming onto boost.
Old May 13, 2008 | 10:10 PM
  #204
SeanV's Avatar
NM, Problem sorted out
Old Jun 10, 2008 | 07:10 PM
  #205
racer135's Avatar
Originally Posted by Max Power
Since this is the most active lean spool conversation, I wonder if anyone else has noticed the following trend:
https://www.evolutionm.net/forums/sh...3&postcount=39
I am a bit leary with the fear that something odd will happen like this. I currently have enable/disable both at 2500. I guess I'll log IPW a bit and see if that happens... and if anyone has a better on/off setting let me know (these are the only things I've touched for this goal).
Have anyone else seen this issue or any other weird thing after disabling lean spool?
Old Jun 10, 2008 | 07:26 PM
  #206
tephra's Avatar
if, when you put the XML in for leanspool, the stock values are NOT 2500 and 7000 then you have entered the wrong XML.
Old Jun 12, 2008 | 08:17 AM
  #207
racer135's Avatar
That’s OK but what about the halving in injector pulse width at high loads have anyone else seen that or is that an isolated case or perhaps related to a wrong implementation of the lean spool disable. If the halving occurs it sound like it would not be safe to disable lean spool.
Old Jun 12, 2008 | 04:50 PM
  #208
tephra's Avatar
what halving? never heardof that
Old Jun 13, 2008 | 12:15 PM
  #209
racer135's Avatar
Check out the link on post $205. That's what I am asking about.
Old Jun 13, 2008 | 09:30 PM
  #210
xtremeIX's Avatar
Question Factory Settings for Lean Spool
I recently added the Enable/Disable lean spool definitions to my ROM but I'm not ready to start messing with them yet. Can somebody tell me what the factory settings are for these fields? Right now LeanSpoolEnable = 80 and LeanSpoolDisable = 255.
