PATCH: CEL Flash on Loaded Knock
Old Aug 14, 2007 | 10:38 AM
  #106
Charlie_B's Avatar
Quick question...Which light is the CEL light? Is it the "Service Engine Soon" (on the left) light? Or is it on the right, in the "Lancer" guage? Ive replaced my "Lancer" gauge with my voltmeter, and wondering if I can still do this mod.
-CB
Old Aug 14, 2007 | 10:54 AM
  #107
Pd1's Avatar
Pd1
-CB
It's the SES light, formerly known as the Check Engine Light (CEL).
Old Aug 14, 2007 | 12:03 PM
  #108
FuelsResearch's Avatar
9642007 bump
Old Aug 14, 2007 | 05:24 PM
  #109
msukach's Avatar
Originally Posted by msukach
I updated my 88590015.xml with patch code but I'm getting weird values...the "Cel Flash on Knock" dialgue box on my current flash compared to the one on the right from the file provided from this thread. Not sure why ECUFlash is reading the patch rom correctly and not my current flash...any help?
I'm assuming I can just change the values using Set Value e.g., 0x1 for "Flash CEL on Knock?" Right?
Attachment 110166
Didn't get a chance to test the CEL function but did find some differences in the stock ROM and the patched ROM at various addresses...just interested in what is "patched." Not that I know what any of this means...just trying to see what it is I'm uploading to the ECU.
Attachment 110218
Old Aug 14, 2007 | 05:28 PM
  #110
tephra's Avatar
If your interested in known what was patched and how it works get IdaPra...
Basically I insert a hook in the IO_Setup route (controls LED's + relays), then do my load/knock check then update the CEL memory address with on/off for the flashing bit...
Old Aug 14, 2007 | 05:55 PM
  #111
msukach's Avatar
Hey, thanks...I'll give it a shot.
Old Aug 14, 2007 | 07:42 PM
  #112
recompile's Avatar
Thanks alot tephra, no issues with 88590015 and works great!
Old Aug 15, 2007 | 05:43 AM
  #113
MR's Avatar
MR
any knock cel patch for this usdm evo9 - 88840016 ecu?
Old Aug 15, 2007 | 05:52 AM
  #114
tephra's Avatar
did you look @ the first post ?
Old Aug 15, 2007 | 10:10 PM
  #115
ziad's Avatar
hass anyone noticed that it takes longer to flash the rom, if i make just a few changes in the timing map.
Old Aug 16, 2007 | 02:22 PM
  #116
msukach's Avatar
Just a note while we're testing this patch...but after uploading the patched ROM, I could no longer log w/EVOscan...EVOscan would engage but wouldn't log any data...I tried uninstalling/reinstalling EVOscan but still had the same result...after removing XML code an uploading my original ROM, I was able to log again. I can only suspect that I must have done something wrong w/the patched ROM--although it seemed to work upon my first few runs...I've got intermitent spikes of > 3 knock at upwards of 5900+ RPM under load.
I'm going to try the patch again and see what I get...
Old Aug 16, 2007 | 03:48 PM
  #117
mplspilot's Avatar
^xml would not matter.
Specify your rom id.
Old Aug 16, 2007 | 04:18 PM
  #118
msukach's Avatar
ROM ID 88590015
Of course, you're correct, removing the xml code that informs what ECUflash displays/reads wouldn't have any effect--or shouldn't, right...but, for troubleshooting, I eliminated any extra data that was getting uploaded to the ECU--and, of course, these extra line were present after reflashing without the "patched" ROM. As it turns out, EVOscan worked after I reflashed without the patched ROM...even though the patched ROM worked, I'm assuming I did something incorrect which prevented me from loggin data w/EVOscan.
Old Aug 16, 2007 | 09:06 PM
  #119
Whoop_ass's Avatar
i have this mod and i log evoscan no prob
Old Aug 16, 2007 | 09:54 PM
  #120
mchuang's Avatar
When is 94170014 coming please hook a brotha up lol
