how-to: ECU-based direct boost control
Old Jun 20, 2011 | 10:14 AM
  #991
afgtrackstar's Avatar
i would love ecu controlled boost!!
  #992
Raptord's Avatar
Originally Posted by D-VO
I though when it is when you have wgdc zero'd you get full boost. Meaning the wastegate is is not being used at all. Isn't that the way it works?
It's the opposite. 100% WGDC means the gate stays completely closed. 0% means the gate stays open.
Old Jun 22, 2011 | 05:46 PM
  #993
F0RSAKEN's Avatar
Any way to change the dimensions of the TPS Correction map (i.e. instead of only having 6 or 7 points of adjustment, adding a few for better resolution)?
Old Jun 22, 2011 | 05:51 PM
  #994
Dynotech Tuning's Avatar
Curious Why?
-Jamie
(aka jack_of_trades)
Old Jun 23, 2011 | 07:14 PM
  #995
F0RSAKEN's Avatar
Better resolution for smoother WGDC transition.
Old Sep 18, 2011 | 07:43 AM
  #996
mrfred's Avatar
Second post has been updated to include instructions for JDM Evo 8 96260009 ROMs. It will not work with 96260007 ROMs.
Old Sep 18, 2011 | 12:39 PM
  #997
ziad's Avatar
thanks mrfred
Old Sep 18, 2011 | 02:53 PM
  #998
mrfred's Avatar
Originally Posted by ziad
thanks mrfred
Old Sep 18, 2011 | 03:08 PM
  #999
211Ratsbud's Avatar
quick question, maybe Im gettin greedy, and Im not opposed to tuning load based boost: 885807XX, AUDM IX v7 rom, no map sensor present in rom, but I do have a 4 bar in my USDM car, is it a complicated implication/impossible mission, or has it just been unrequested etc. AFAIK, there may have been some EDM roms that dont come with MAP sensors that had this implimented. JW..
Old Sep 18, 2011 | 03:49 PM
  #1000
mrfred's Avatar
Its no more difficult for me to work out than the others. Takes about 3-4 hours of my time.
Old Sep 18, 2011 | 10:33 PM
  #1001
dparrish's Avatar
Thanks mrfred!
I've updated the xml for 96260009 on code.google.com/p/ecurom to include the correct direct boost tables.
Old Sep 21, 2011 | 04:56 PM
  #1002
Joshua Warren's Avatar
Thanks to all those who have developed the shi# out of this! Scribed
Old Sep 21, 2011 | 05:11 PM
  #1003
evo_gerard's Avatar
any direct boost control for 90550001?
Old Oct 1, 2011 | 04:34 PM
  #1004
211Ratsbud's Avatar
Im pretty sure I have checked every thing and I cannot get my ecu to make corrections to the WGDC. In evo scan this just reads zero in the WGDC corrections all the time, and I have all the values filled in, (stock values, stock solenoid). Also, the max upward correction table is scrambled
Is this a sign of any thing obviously wrong with my v7 rom.
Old Oct 1, 2011 | 04:47 PM
  #1005
Raptord's Avatar
The v7 ROM that you downloaded has an omission in the definition which results in the max upward WGDC correction table not displaying properly. Right click on the table on click "edit map". Make sure everything in there looks like this:
Attached Thumbnails how-to: ECU-based direct boost control-tps.gif
