How To Tune an Evo
thats the joys of adjusting voltages
lol
id start with small increments... .050 for the ones that are way out... id add that to the voltages starting around 11 i think it is all the way to the end. Then reset your battery and let her idle
you also may want to play with the scaling a little bit. Maybe try 650 or something closer to 600 and see how that effects things
lolid start with small increments... .050 for the ones that are way out... id add that to the voltages starting around 11 i think it is all the way to the end. Then reset your battery and let her idle
lol
Thanks alot man this has been driving me nuts
I tried the mitsulogger today and viewed the logs in the data log lab, kinda nice
ok so if the values are flipped with evoscan. I messed with under 11 just barely and got as follows.
fuel low 80.469%
fuel mid 54.688%
fuel high 100%
The idle seems better so I will continue to tinker with it
where I'm at now put injector scaling to 670
4.6875
7.03125
9.375
11.7188
14.0625
16.4062
18.6768
6.12
4.128
0.888
0.672
0.408
I'm getting closer right
and should the first # really be that high?? Also I have 272's btw
fuel low 80.469%
fuel mid 54.688%
fuel high 100%
4.6875
7.03125
9.375
11.7188
14.0625
16.4062
18.6768
6.12
4.128
0.888
0.672
0.408
Roger that
Stock is 3.312 ...I've got it at 4.104 now should I lower it down somewhere in between?
Again thanks for the help
im using evoscan 0.99 btw so I hope that means they flip the values
edit: I've got the fuel trims all at 100 now ..well in evoscan and mistulogger
settings:
scaling at 650
3.912
3.192
2.592
1.32
0.888
0.672
0.408
I'm sure I'll still have to play with things but im getting there the idle isn't all super rough
settings:
scaling at 650
3.912
3.192
2.592
1.32
0.888
0.672
0.408
Please keep working on that as I have the same injectors as you and would like a benchmark to start with.
My car is all over the dang place and I would like to start all over and see if I can't tune this thing myself...
Cheers-
Erich
Cheers-
Erich
Roger that
settings:
scaling at 650
3.912
3.192
2.592
1.32
0.888
0.672
0.408
settings:
scaling at 650
3.912
3.192
2.592
1.32
0.888
0.672
0.408
make sure you post your final numbers in the scaling thread that you were asking about these in
I hear ya thats how my car was to start with and its getting better. I'm just going to continue to try bumping it up and down just little by little. When I'm done I'll get some numbers for you to start withgood work man... im glad i could help you a little bit. Once you nail the idle trims down, now you get to go cruising and get those together. im not sure why, but everyone seems to have problems with the 780's. maybe its because they arent too common it seems... everyone seems to jump to 880's just in case they go bigger than they are.
It's hard to remember what my idle was like with the cams because its always been lop lop lop. Ilde bounces between 700's to 800's I just don't like it when it dips down below that and sounds like its going to choke.
Right now I think I've got it 100 all trims idling and just barely under 100 when cruising I'll check these numbers around lunch...sorry its early and I haven't had a coffee yet
just raise your idle a bit to help with the dying down stuff as well as raise the timing up a bit in the idle cells depending on what it is at.
but yes, you should be at 100 for cruise as well
Try your injectors at 619 and see what you get... Thats where my car was with the RRE tune from the previous owner and tuner. I think you're headed to the 6(teens) area pretty soon...
Thanks so much for wanting to help me by giving me a benchmark area to start with. It's guys like that that make this forum worthwhile.
Cheers-
Erich
Edit: I meant 609 but you got it spot on at 622...
Cheers-
Erich
Here we go guys
100% low,mid.high idle and cruise
scaled at 622
3.864
3.456
2.856
1.32
0.888
0.672
0.408
Now should I bump up timing a pinch at idle to keep any lil dip away? I've got the desired idle at 1000
Screenshot attached!
scaled at 622
3.864
3.456
2.856
1.32
0.888
0.672
0.408
You rock out with your (you know what) out!!
Woot Woot!!
Now this has me aggravated... I cannot change the values of anything OVER 7 volts in the voltage table...
Woot Woot!!
I just hit the = then enter the value or you can hit the + key too
where does your car idle rpm wise? I think I want to bump mine up slightly
