Let's see your fully tuned timing maps
Old Oct 15, 2012 | 08:07 AM
  #1876
Raptord's Avatar
Certainly a lot better than Al's tune, peak load timing might still be a bit high for pump.
Old Oct 15, 2012 | 08:09 AM
  #1877
kaonashi's Avatar
Which area's would you suggest I drop them? WOT afr stays in low 11's so its def running way better than before. How's this look?
Old Oct 15, 2012 | 08:21 AM
  #1878
Raptord's Avatar
Originally Posted by kaonashi
Which area's would you suggest I drop them? WOT afr stays in low 11's so its def running way better than before was in mid 10's
By judging from everyone else's timing maps, should I drop them to 38 & feather them down from that instead of 40?
I was referring to peak load timing, as in around 3500-4500 rpm, and probably ~260 load? 5 might be a bit too aggressive.
Old Oct 15, 2012 | 08:25 AM
  #1879
kaonashi's Avatar
Ahh, ok strange that it didn't have any knock counts even with Al's nasty tune...
After I fix my laptop I'll get some new logs, seems that its not blowing out the spark now.
Old Oct 28, 2012 | 12:50 AM
  #1880
stunt2's Avatar
I know it's far from good map, still working on it and would like to hear suggestions
22-23 psi peaks at 290-310 load @ ~3.8-4 K rpm
picture hosting
Old Oct 28, 2012 | 10:02 AM
  #1881
211Ratsbud's Avatar
Heres where I keep ending up. I have to pull so much spool timing or I just get a bazillion knock counts.
I still have a knock count at 3750-5k under light accell I cant get rid of.
Do yoou think my Skunk 2 ported intake manifold GSC s2 cams are bottlenecking from the stock exhaust manifold and causing low spool timing?
300 load down to 260 roughly 18 psi
Old Oct 28, 2012 | 11:37 PM
  #1882
project_skyline's Avatar
Complete mod list?
Old Oct 29, 2012 | 02:39 AM
  #1883
EvocentriK's Avatar
Rats can we see a load trace please so we can follow through the map, and that colour scheme O.o
Old Oct 29, 2012 | 04:37 AM
  #1884
211Ratsbud's Avatar
Yup I've changed some things around since this morning and it got better disabled FAA 10 and I didn't check my timing but I didn't see the knock light
Ill load one or two after work
Old Oct 29, 2012 | 05:39 AM
  #1885
211Ratsbud's Avatar
Originally Posted by project_skyline
Complete mod list?
S2 cams with ti retainers a and their springs.
Skunk 2 STM ported
Stock exhaust mani
Fbm 70mm
Pte1000cc
Muse o2 dump
Straight no muffler tbe
Stock wga preloaded to about 16-20
Greddy type s with single spring mod top port only
Fp 71 hta
Old Oct 29, 2012 | 06:26 AM
  #1886
domyz's Avatar
What is the octane level? And do you have an AFR log on spool up?
Edit: I see that you have a problem in targeting the right cells in your timing map. Solve this before because the timing map posted isn't the timing your car run when it's knocking. Is your 1 byte load factor the same in Ecuflash AND Evoscan?
(Saw your post here: https://www.evolutionm.net/forums/ec...-vs-log-4.html)
Old Oct 29, 2012 | 06:42 AM
  #1887
211Ratsbud's Avatar
Yes 1.5 for both . I didn't notice the FAA 10 being enabled so most of my issues lay below 4000. Took a log this morning with an old map and noticed that it was better off . It's like 3deg higher in the low end
Not sure on the octane level
Old Oct 29, 2012 | 01:39 PM
  #1888
211Ratsbud's Avatar
Ok, this is the upgraded timing map I put on late last night and tested this morning. Theres a map trace with my analog out from my AEM, the precision is leaving some to be desired IMHO there and finally the log.
Note the SD seems to be a little inconsistent with AFR's and we've had drastic weather changes here latley. I havent touched up the VE map
Attached Thumbnails Let's see your fully tuned timing maps-snio.png   Let's see your fully tuned timing maps-timing-map.png
Old Oct 29, 2012 | 01:59 PM
  #1889
todd6027's Avatar
needs leaning out big time
Old Oct 29, 2012 | 02:15 PM
  #1890
211Ratsbud's Avatar
I'm just happy to see timing map coincide with timing advance
Ill lean it out once I sweep up the 17-18 psi mark for timing. I've seriously been banging my head for a while.
