Let's see your fully tuned timing maps
Old Nov 17, 2012 | 05:24 PM
  #1936
Raptord's Avatar
That map looks pretty good to me Ramonski. What does your load curve look like?
Old Nov 17, 2012 | 10:14 PM
  #1937
nightwalker's Avatar
That's a lot of load for just a 9 turbo. If you scaled down you would have more resolution in crucial areas and might even be able to run more timing.
Show us a map tracer
Old Nov 18, 2012 | 10:29 AM
  #1938
Ramonski's Avatar
^^^I Pm'd you asking some questions. I am fairly new to all of this so I'm still getting the hang of making changes.
Old Dec 3, 2012 | 07:33 AM
  #1939
Lancer_Evo_8's Avatar
So since 3-4 weeks i try to tune, remap my own EVO 8. I would like to hear your opinions...
My first own MAP (98 octane)
3" FP Intake Pipe
FP White
Buschur ported Manifold
3" Megan Elbow
Okada Plasma
GSG Stage1 268° with springs
3" TBE
100 Cell High Flow cat
Carbon-Airbox
ETS LICP
Forge BlowOff
ACT SS Clutch
ACT HD Pressure Platte
ACT Streetlite Flywheel
255 l/h Walbro
Old Dec 3, 2012 | 09:51 PM
  #1940
jdm-vr4's Avatar
And your car is taking this timing on 98RON ?
That is a lot of timing both peak load and up the top.
Old Dec 3, 2012 | 11:07 PM
  #1941
Yes right, this map is for 98 Octane.
Sorry, but what do you mean with "lot of timing both peak load and up the top"
Old Dec 3, 2012 | 11:40 PM
  #1942
Biggy VIII's Avatar
3" FP Intake Pipe
FP White
3" Megan Elbow
Okada Plasma
3" TBE
Carbon-Airbox
ETS LICP
Forge BlowOff
ACT SS Clutch
255 l/h Walbro
I would say the map generaly looks fine if it doesnt knock. but what peak load do you hit?
Old Dec 4, 2012 | 01:12 AM
  #1943
if it doesnt knock
Since i installed the Okada Plasma i have no knocks. (for the moment)
Maybe i`m missunderstand you sorry, but my peak load is 350. Or do you mean something different?
Old Dec 4, 2012 | 04:24 AM
  #1944
jdm-vr4's Avatar
Without knowing exactly what loads you are hitting when loging with evoscan its hard to say exactly how much timing you are running but I know that fp white can hit 320ish load at 3750 on non mivec 2.0l. So looking at those columns and timing you are at around...6-4* at this point and I also know that fp white in 1 particular car wouldnt take more then 11* at 260-270 load at 7000 and you are running 18-16*?
Best is to see your log but that timing to me is really high for 98 octane which relates to 92-93 US
Old Dec 4, 2012 | 04:48 AM
  #1945
Here is the last Log i did befor i installed the Okada Plasma. I think the Injectors i have to change....
Old Dec 4, 2012 | 05:11 AM
  #1946
Spec-Ops1's Avatar
Injectors are fine... evoscan will read to about 115% before the injectors are at a true 100%...
Old Dec 4, 2012 | 06:09 AM
  #1947
domyz's Avatar
I completely agree with jdm-vr4. Timing seems too high if it hits these loads. BiggyVIII you run suprinsingly a lot of timing on your map with Russia 93 but I don't think others will get as high on US 93 octane. You run something very uncommon.
Lancer_Evo_8, your knock could be timing related, as it is overly agressive. Try raising timing smoothly to 13-14* by 7000RPM and see if that solve knock. And try to run a flatter AFR. There is no need to run 10.7 at redline.
Old Dec 4, 2012 | 07:37 AM
  #1948
nitai3g's Avatar
hey guys I've read and learned a lot on this forum and thread. I would like to share my progress with my evo turbo setup on my eclipse.
00 eclipse rs.
4g64 block with sohc. stock motor
evo8 turbo 9.5 (boost set at 12psi for now.)
3" TBE
stock evo8 intake pipe.
2.5" UICP & LICP
1g crushed BOV
evo8 injectors and fpr
walbro 255 pump
hallman MBC
aem wideband
so its kinda like a stock evo8 turbo setup.
here's my most recent maps
peak load is 289 at 4250rpm... kind of high??
at 6250 is at 220 load.
let me know what you guys think.
Attached Thumbnails Let's see your fully tuned timing maps-eclipse-timing-map-12412.jpg   Let's see your fully tuned timing maps-eclipse-fuel-map-12412.jpg
Old Dec 4, 2012 | 08:09 AM
  #1949
Biggy VIII's Avatar
I agree about US 93, but Lancer_Evo_8 is from Switzerland. I believe european BP Ron98 is about the same as we have here in Russia.
Anyway 6500+ RPM seem to be too high to me. But if it doesnt knock, I can only envy that... )
350 is the maximum load in your map.
What maximum "Load 1Byte" or "LoadMUT2Byte" do you see during the run? Could not see that in your log. You should log it.
Old Dec 4, 2012 | 08:13 AM
  #1950
Biggy VIII's Avatar
Here is the map of Evo8 2.0 CR9 + Kelford 272 + lots of supporting mods + CBRD BBK Full ported. The car runs 25psi tapering to 23 at redline, making 470hp 530nm. BP RON98 pump gas. No knock at all. Road racing tune.
It is wierd, but peak load at this level of boost is 240. I traced it and marked the cells so you could see what timing does it run.
