Let's see your fully tuned timing maps
Old Oct 9, 2020 | 03:43 PM
  #2881
NP's Avatar
NP
5 Year Member
Originally Posted by Lumpy Sticks
^^^^ Too much timing in boost!
Thanks for the input Lumpy. Thats what worries me. It was suppose to be a conservative tune to.
Old Oct 9, 2020 | 04:02 PM
  #2882
Lumpy Sticks's Avatar
5 Year Member
By no means is that conservative. Its overkill. What RPM and load # are you seeing full boost?
Old Oct 9, 2020 | 05:54 PM
  #2883
NP's Avatar
NP
5 Year Member
That im not sure, havent logged or done any pulls after getting the car tune. Dont really want to mess up the motor until i can get it sorted out.
Old Oct 9, 2020 | 08:49 PM
  #2884
evo8vz's Avatar
Got tuned on a dyno. Need opinion on E85 timing map.
built block
about 30 psi
stock frame gtx3576
E85 fuel
too much timing needs about 3-4 degreee less
Old Oct 10, 2020 | 03:52 AM
  #2885
NP's Avatar
NP
5 Year Member
Thanks Evo8vz. it does seem a bit much.
Old Oct 12, 2020 | 09:24 AM
  #2886
foxbat's Avatar
built block
about 30 psi
stock frame gtx3576
E85 fuel
If you have a built block then it's ok, why would you ask for a conservative tune when using E85? What type of con rods do you have?
Old Oct 12, 2020 | 04:51 PM
  #2887
evo8vz's Avatar
E85 doesnt knock
because it feels good doesnt mean its correct
Old Oct 13, 2020 | 12:12 AM
  #2888
foxbat's Avatar
E85 doesnt knock
So you are aware that E85 doesn't knock yet you're asking him to reduce timing, care to elaborate why? I've been tuning Evos for 11 years now & I'd say that the above table is on the conservative side considering it's E85. My concern, if any, would be the connecting rods, that motor better have good rods & good rod bolts at that boost level x turbo size.
Old Oct 13, 2020 | 09:30 AM
  #2889
KingTal0n's Avatar
Whoa wtf. What does having a built block in this context have anything to do with how you tune an engine?? LOL
Just because the pistons are forged and can withstand a BEATING and ABUSE doesn't mean you need or should ABUSE and BEAT them !!
Old Oct 13, 2020 | 09:51 AM
  #2890
LetsGetThisDone's Avatar
Way too much timing. Go too a different tuner. You shouldn't be seeing 10* unitl like 6000rpm. You have it 4500 where it should be like 2*. You're just beating the rod bearings out of that poor thing.
Old Oct 13, 2020 | 10:10 AM
  #2891
foxbat's Avatar
So you would tune both a stock motor & a built motor the same?! Are you a tuner yourself? Or are you even aware of the concept of 'Torque'?
Old Oct 13, 2020 | 10:13 AM
  #2892
You have no business tuning an Evo, or any car really, if you think that timing map is ok.
Old Oct 13, 2020 | 10:30 AM
  #2893
foxbat's Avatar
By your logic then it would be negative degrees this if this were a 93oct tune.
Old Oct 13, 2020 | 10:54 AM
  #2894
5 Year Member
Umm no. Boost levels would be down compared to E85 so the timing values would be about the same besides up top.
Old Oct 13, 2020 | 11:42 AM
  #2895
Abacus's Avatar
These cars have old engines that don't need a lot of timing to run. The only trophy you get for a high timing score is an expensive one.
I've run my car 70+ pulls on the dyno . There isn't a huge change from pump gas to race ethanol for timing with a small turbo/backpressure.
You can just about start off at 2-3* at 3500 and build an easy ramp to 5-8* at 5500 then to 13-15* + on most of these cars. A larger turbo with less back pressure may be able to run more but never get carried away. If you have higher or lower then stock compression that also plays a big role.
The real test is putting it on the dyno and running it back to back to see what timing yields decent results . You don't just keep adding timing to chase small gains. Looking at plugs and smoothness is also a good idea.
