Let's see your fully tuned timing maps
Old Aug 19, 2011 | 02:28 PM
  #1291
todd6027's Avatar
Originally Posted by GregM
Interesting, I checked a log from earlier this month and it was about 4500rpm. I'll check the shaft play when I get a chance. Might be time for a new turbo, more $$.
check the actuator preload
Old Aug 19, 2011 | 03:31 PM
  #1292
wizzo 8's Avatar
Just because its not knocking doesn't mean its not. E85 and Meth hide knock. You have to look at mbt.
Old Aug 19, 2011 | 04:58 PM
  #1293
1UpMoto's Avatar
Ive been using virtual dyno so I think im good.
Old Aug 19, 2011 | 06:06 PM
  #1294
GregM's Avatar
ok, I'm a noob. I fitted a 18psi actuator before I started increasing boost and just fitted it. I didn't set pre-load. It only ran to 14psi off the actuator and it was slow to spool up. I saw the video on FP's site on how to set it, so hope its the same as my actuator. I did 3 full turns in from when it fitted fine.
Old Aug 19, 2011 | 09:01 PM
  #1295
killerpenguin21's Avatar
well im about done for now.
smoothed the top a tad since this screen grab. running 4* at peak torque and 17* at 7200, 37* at cruise for easy passing while staying in vacuum (nice 25mpg with a bad front o2). Occasional 1 count of knock, car consistently makes 330/300 on VD on peak of 24psi.
according to my wideband im running 11.9ish afr, more than likely a tad off though. got the idc's up to 102 and couldnt dropt it any. time for 1050's, a fuel pump and o2 housing and up the boost.
Old Aug 20, 2011 | 08:25 PM
  #1296
evo_q8's Avatar
This is the first time I do this and its a big thanks to everyone posting here...
Need your suggestions on how to make this better
Evo 8
Intake/exhaust/ebcs - 24ish psi
Old Aug 20, 2011 | 08:34 PM
  #1297
Ian0611's Avatar
What peak load are you hitting? What turbo and peak boost? You can probably take out the load cells above 300 or 310 and add some resolution to the spoolup areas 100-180. Other than that it doesn't look too bad. Just try to smooth it out a little more and maybe get rid of that big block of 7s. Also, make sure there are no areas where timing is going up, down, and then back up again.
Old Aug 20, 2011 | 09:20 PM
  #1298
evo_q8's Avatar
its stock turbo. Max load calc shows 245ish max.
6* at peak boost and 11* by 7500..
220 load - 5250 rpm - value 12
200 load - 5500 rpm - value 12 .. just saw these... will fix em!
wow posting here makes it clearer.. i need to go sleep
Need to know, ive seen maps with 3's 2's and 1's in the high load areas. What are those for?
Old Aug 20, 2011 | 09:42 PM
  #1299
Raptord's Avatar
What fuel are you on evo_g8? 6° at peak load might be a bit harsh on the motor if it's on pump gas.
Old Aug 21, 2011 | 01:49 AM
  #1300
evo_q8's Avatar
93 octane. I've made some new maps. Will post them here in a few..
Old Aug 21, 2011 | 08:25 AM
  #1301
chetrickerman's Avatar
Veteran: Army
Evo 8
holy **** you need resolution in the 100-180 range!
you dont need anything above 320, and get rid of the 310.
i would go down to 4-5* during peak load to be on the safe side.
what is your boost at redline?
Old Aug 21, 2011 | 08:12 PM
  #1302
Veteran: Army
quick question, what fuel are you running with this map?
Old Aug 21, 2011 | 09:13 PM
  #1303
93 pump, do you think something looks good/bad?
im also at a max elevation of like 200 feet above sea level, and i see your in colorado.
Old Aug 21, 2011 | 09:58 PM
  #1304
Veteran: Army
no, it looks great. i was just wondering for comparison to my own map. im trying to find how high i should push my timing in the high rpms.
im running 91, but my 6000 ft altitude allows me to run a little more aggressive timing than 91 at sea level, but i do travel to sea level, so im trying to find a map that is safe at sea level too.
the only thing is that my car is very resistant to knock. it ONLY knocks in the 6600-6900 rpm range, but that is regardless of if im running 11* or 18*, it just knocks 2 counts.
this is on stock block, stock turbo, pretty much all the bolt ons. peak 23.5psi tapering to 16 psi
Old Aug 21, 2011 | 10:12 PM
  #1305
211Ratsbud's Avatar
Rather, i find that your timing map looks different than ive been seeing trend in maps, call it a bit chunky. is that still in progress?
ive gathered from this thread that a smoother more transitioning shape is better, although my implication may be wrong you'll see., granted im on big maps
