economy tuning
Old Jul 2, 2008 | 08:52 PM
  #181
mrfred's Avatar
+3 deg of advance over 0 to 100 load and 1500 - 4000 rpm definitely improved power at loads of ≤ 100 without any knock. I've now added another 2 deg at loads from 60-100. Still no knock but not sure yet if there is any more power. At these load loads, don't know yet if E85 is knock proof and can go right past MBT, or whether I still have yet to reach MBT.
Anyone have any thoughts?
Attached Thumbnails economy tuning-m65_e85_v8_cruise-timing-2-deg-60-100-load.gif
Old Jul 2, 2008 | 09:23 PM
  #182
tephra's Avatar
I would post up my timing table, but I don't want to taint the discussion.
I am running more than you but am experiencing some intermittent knock...
Old Jul 2, 2008 | 10:27 PM
  #183
mrfred's Avatar
Post up your table. I'm curious to see. What does the knock sum look like? Sharp spike or low level 2-3 knock sum?
Old Jul 2, 2008 | 10:33 PM
  #184
RazorLab's Avatar
I've logged 42* at cruise with no knock, however I am also on 100.
Soon to be dabbling in E85 though...
Old Jul 2, 2008 | 10:34 PM
  #185
tephra's Avatar
Old Jul 3, 2008 | 10:41 AM
  #186
inco9nito99's Avatar
I'd like to see a 93octane map. I'll post mine in a few hrs with +3 on 93.
Old Jul 8, 2008 | 10:43 AM
  #187
mrfred's Avatar
I'm back to pump gas for a few days. Decided to try tuning my ignition map while on pump gas. Getting good results with the same map that I used for E85. Knock free except a very occasional knock sum of 2 for a few entries when accelerating through a load of 70-80. Responsiveness and power are much better. I can stay in vacuum for cruising 95% of the time, whereas before I would often have to go slightly into boost to get acceptable acceleration. Torque at low rpms is much better too. I can lug around at 1800-2200 rpm very easily now. I may try pushing up the timing even further in selected areas.
Would definitely be interested in seeing other people's pump gas timing maps.
Old Jul 8, 2008 | 11:29 AM
  #188
Why the block of 14 during idle? A little much no?
Old Jul 8, 2008 | 01:49 PM
  #189
mrfred's Avatar
Working fine for me. Give it a try. Nothing will blow up. :-)
Old Jul 8, 2008 | 01:58 PM
  #190
nonschlont's Avatar
is this w/ the stock cams?
Old Jul 8, 2008 | 02:47 PM
  #191
mrfred's Avatar
Yes.
Old Jul 8, 2008 | 03:13 PM
  #192
Chabada15's Avatar
do you think it would effect a cammed car?
Old Jul 8, 2008 | 03:28 PM
  #193
nonschlont's Avatar
I thought that peeps were advancing the timing in the idle area to compensate for a loopy idle... Apparantly not...
Old Jul 8, 2008 | 03:42 PM
  #194
RazorLab's Avatar
no misfire codes with 14* at idle mrfred?
Old Jul 8, 2008 | 04:19 PM
  #195
mrfred's Avatar
Nope. Been using 14* for two years now.
